Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 1, 2017 at 12:13 PM
    #4201
    mict450
    mict450 got heel toe?
    northeastern California
    2017 TRD Sport AC MT BBP
    A long, long time ago, before the internet, all the Toyotas I owned, as well as friends and family, had that squeaky clutch. It wasn't a big deal for us. Corporate has had over 40 yrs to fix it and they never have. Is it a big deal for me today? No. Could it turn into a problem? Don't know, especially since a lot of metal parts in the clutch linkage have been replaced by plastic in the name of the bottom line and fuel efficiency.
    Dannyblues[QUOTED] likes this.
  2. Apr 1, 2017 at 12:26 PM
    #4202
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I'd downshift to 1st. 1200 rpm isn't enough if you need acceleration, 2000 rpm minimum at low speed. I don't believe there's anything wrong with your truck, mine is the same.
  3. Apr 1, 2017 at 12:27 PM
    #4203
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Clutch on my 95 would squeak in warm weather. 17 no squeaks so far at almost 1K miles.
  4. Apr 1, 2017 at 12:28 PM
    #4204
    cosmicfires
    David
    Everett, WA
    My 5 speed doesn't want to go into 1st gear when moving unless I double clutch. Don't have to match rpm exactly just bump it up.
  5. Apr 1, 2017 at 12:35 PM
    #4205
    cosmicfires
    David
    Everett, WA
    I believe it's a pollution control thing, if the throttle snaps shut quickly it causes more pollution. Back in the carburetor days throttles had a damper to keep them from closing quickly.
  6. Apr 1, 2017 at 1:19 PM
    #4206
    cosmicfires
    David
    Everett, WA
    I learned to drive on 1960s Mercedes with 4 speed on the tree.
  7. Apr 1, 2017 at 1:43 PM
    #4207
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Check back at 3 to 4 k
    Dannyblues likes this.
  8. Apr 1, 2017 at 1:53 PM
    #4208
    cosmicfires
    David
    Everett, WA
    My Tacoma's clutch has never squeaked.
  9. Apr 1, 2017 at 2:43 PM
    #4209
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    Never even heard of one of those. I guess it was high tech at the time. At least the column shift let you enjoy the benefits of a full front bench seat. Great for the additional person capacity in front but even better for snuggling with your girl as you drive ( hence the expression of the two headed driver ). Those were the days. You didn't even have to get her to take the leap in trust to jump over into the back seat!! Dannyblues
  10. Apr 1, 2017 at 2:48 PM
    #4210
    Dannyblues
    Danny
    Wow that's a long time for a company like Toyota to eliminate an annoying problem. I doubt it requires more than a dab of grease in the right spot to eliminate it too. I wonder what past owners have done?? You know way back when cars were so noisey that a small clutch squeak was probably not even noticeable. But things like whistling fly windows were annoying and near impossibility to correct and stay corrected for any length of time. Dannyblues
  11. Apr 1, 2017 at 2:49 PM
    #4211
    Dannyblues
    Danny
    Now that's different Dannyblues
  12. Apr 1, 2017 at 2:53 PM
    #4212
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I plan on hitting the new 17 with disc brake grease before it ever has a chance to start that noise!
  13. Apr 1, 2017 at 2:58 PM
    #4213
    Dannyblues
    Danny
    That's funny ( to me, not your knuckles! ).
    My last vehicle that didn't have the same e brake location as my new 2016 TRD was a 1969 Buick Le Sabre. It had a left foot actuated foot peddle to push down and engage it with a T handle release hand pull.
    The old 51 Merc and I think my 57 Chevy and most other cars I've owned in the past had the T handle pull and release on the left side by the drivers leg if I remember correctly. Since everything I owned back then were automatics I only relied on park especially because it was in advisable to use the e brake in winter. I've been under one of my old card more than once with a butane torch trying to warm up and free a frozen emergency brake on the rear wheels.
    Dannyblues
  14. Apr 1, 2017 at 3:10 PM
    #4214
    Dannyblues
    Danny
    Sounds like a good idea. But lube where? At the connection inside ? I guess I'd have to assume the squeak is inside maybe where the clutch peddle attaches to the next linkage ? Good luck. Thankfully I don't have that problem.
    I remember a 67 GTO with tri power carbs. It was a cream colored convertible. I was surprised that a convertible had no wind noise when closed that cold winter night a friends dad owned and was driving us somewhere. It was brand new. Incredibly quiet. Barely a rumble from the stock dual exhaust ( but we were riding locally in a neighborhood). The only sound was a small squeak each time the clutch was depressed. I liked it as I knew it meant a gear change. So quiet and smooth. I'm sure on the track it was loud and fast. Dannyblues
  15. Apr 1, 2017 at 3:17 PM
    #4215
    Dannyblues
    Danny
    I bought my 2016 TRD early last July. No noises at all anywhere. But I did have the stuck shifter problem. Resolved now. At 9 months and 12,000 miles no noise anywhere. Except in the morning mostly when at idle; noisey engine. Sounds like a bad lifter.
    I've been told that bad lifter sound is from the injector pump and is a typical sound on all Atkinson/ Otto engines. Though I did drive one loaner automatic TRD that didn't have that bad lifter sound I was concerned at first until I heard it was normal.
    Dannyblues
  16. Apr 1, 2017 at 3:36 PM
    #4216
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    So, here's a question I'll ask here rather than start a new thread about...cuz, I'm stealthy about my newness on the forum.
    I've read extensively in TW about the squeaky clutch deal...i even watched the video, its great...the ups, the down...the Denouement even.
    So...
    Do any of you have lateral movement at the pedal...like just rest your toe on it and wiggle side to side...mebbe 3/4" in play or so?
    Doesn't bug me, just wondering if it's a common thing or am I gonna be gear floating home one day?
    Dankje
  17. Apr 1, 2017 at 3:47 PM
    #4217
    su.b.rat
    su.b.rat broken truck
    first use of "Denouement" on TW... you get the daily biscuit.
    mine has a bit of lateral play, maybe 1/8"at most, probably less than 1/8"actually. but i still hate it. if there was an aftermarket clutch pedal assembly with quality built in i would have already bought it.
  18. Apr 1, 2017 at 3:52 PM
    #4218
    TeecoTaco
    SW Ontario
    Crap dood, ya made me search...you're right lmao...worth more than a biscuit methinks, especially a daily one...I counter haggle with a biscuit, a million bucks, and the letter M stricken from the English language
    Ya, can't say I hate it per se, but I DID notice it
  19. Apr 1, 2017 at 3:56 PM
    #4219
    su.b.rat
    just knock on wood that you don't get the squeak. that's not so easy to ignore.
  20. Apr 1, 2017 at 4:34 PM
    #4220
    TeecoTaco
    SW Ontario
    Every once in a while, under a lot of use (stoopid Toronto light synchronization) I'll get a slight, weak creak, not squeak, and absolutely not like buddy arc welder's video of "the squeak"
