Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 4, 2017 at 10:35 AM
    #4301
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    Me too. All those creaking noises! Found out it was ME. I'm 67 and I now make those noises. Thought it was the truck.
    Dannyblues
    Mountain Minstrel likes this.
  2. Apr 4, 2017 at 11:22 AM
    #4302
    akTacoBlanco
    akTacoBlanco Well-Known Member
    Omaha, NE
    2017 White Tacoma TRD Off Road M/T
    Stock.
    Haha nope, not even close. Anchorage Alaska. There's only one Toyota dealership in Anchorage but they push out so many vehicles it seems like they can get pretty much anything.
    Dannyblues[QUOTED] likes this.
  3. Apr 4, 2017 at 11:34 AM
    #4303
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Good to hear! I haven't had the sticking problem in mine yet. Hoping it stays that way...
  4. Apr 4, 2017 at 12:00 PM
    #4304
    Dannyblues
    Danny
    Lucky guy. It would be a tad too long to drive from northwestern Connecticut to anchorage Alaska to find a manual but if it came to it I'd fly out and drive my new manual home. What a drive! I'd be sure to tour BC and seskatchewan along the way if they had roads. Maybe next time. My dealer found mine in Connecticut with 14 miles on it and traded for it then drove mine 96 miles back to my dealership. It was black with manual and already had wheel locks. Black running boards and weathertech mats. And towing package with upgraded etune audio. Everything I wanted but no more in the color I chose. Dannyblues
  5. Apr 4, 2017 at 12:06 PM
    #4305
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    If the battery is totally dead the alternator will never generate power no matter how fast you push it.
    MOC221_ and Dannyblues[QUOTED] like this.
  6. Apr 4, 2017 at 12:08 PM
    #4306
    Dannyblues
    Danny
    I'm sure if you didn't have the stuck in gear issue from the start you never will. It occurs after an hour of highway driving usually when you've been in one gear for at least 15 minutes, usually fifth or sixth. Man it's frozen. Takes a good yank to get it out. I had the shop drain and inspect my transmission fluid for particles left behind from damage resulting from this issue. Fluid was immaculate. Not even the expected break in shavings. Replaced it with fresh fluid I was told but my gut tells me they just refilled with my filtered original fluid. I'll change all fluids when I get a chance this summer. Maybe next as my mileage is now just 12,000 after nine months and I'll be using my 87 Chevy Nova mostly once the weather warms up. Dannyblues
  7. Apr 4, 2017 at 12:08 PM
    #4307
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeeeeaahhhhhh could probably better off rolling it to around 30-40 and popping it in 2nd or 3rd. A) I doubt the tranny would let you even get it into 1st at that speed (if you aren't already) and b) your engine/transmission would gredane lol. Please don't do that :D. The idea is sound though, I'm sure at 50+ if you drop clutch in 4th or so and let it wind out it might rotate enough to get a charge on the battery
  8. Apr 4, 2017 at 12:08 PM
    #4308
    VolcomTacoma
    Jeff
    NorCal
    Also this though.
  9. Apr 4, 2017 at 12:09 PM
    #4309
    Dannyblues
    Danny
  10. Apr 4, 2017 at 12:10 PM
    #4310
    VolcomTacoma
    Jeff
    NorCal
    Doing my fluid now again, Had a shop do my clutch about 15k miles ago. I had MT90 in there and asked that they put it back in, he said he didn't reuse the old stuff even though it should have been fine with like 500 miles on it, but he said they went to the auto parts place nearby and got some. We'll find out if that's true or not, but I've got a bunch of new MT90 to put in today. Will also be able to find out if all my hammering on the clutch has created any extra particulate or anything.
  11. Apr 4, 2017 at 12:11 PM
    #4311
    Dannyblues
    Danny
    As long as your battery craps out at the top of a mountain! Poor guys in Kansas or Texas would have to push it to Montana! Dannyblues
  12. Apr 4, 2017 at 12:16 PM
    #4312
    Dannyblues
    Danny
    Did you mean hydraulic clutch fluid or transmission fluid. I doubt the clutch fluid that's like brake fluid gets affected by much. It's just a smooth slave unit that replaced the old dry clutch units of old and eliminates all the noise and chatter feel. Dannyblues
  13. Apr 4, 2017 at 12:25 PM
    #4313
    VolcomTacoma
    Jeff
    NorCal
    Trans fluid...
  14. Apr 4, 2017 at 12:26 PM
    #4314
    Dannyblues
    Danny
    Nope. No gear grinding. Only some chatter and resistance when downshifting into first coming up on a stop at a slow roll. I found double clutching eliminates this but now I come to a complete stop when going down to first.
    Sometimes I cheat. I leave it in second and drop to a very low speed maybe even 2-4 mph. Often as I'm still rolling but soooo slow i put in the clutch in second at that speed before the engine Boggs down and out then release it slowly and roll away no problem. It's called a rolling stop. It's technically illegal but done right it looks like you came to a near stop. Avoids the downshift into first and the chatter that comes with it when downshifting into first at low speed. My Tacoma likes a complete stop unless as I said I double clutch down into it
    Dannyblues
  15. Apr 4, 2017 at 12:27 PM
    #4315
    Dannyblues
    Danny
    I thought so. Dannyblues
  16. Apr 4, 2017 at 3:34 PM
    #4316
    Dannyblues
    Danny
    Does that mean it's impossible to push start my 2016 TRD? Dannyblues
  17. Apr 4, 2017 at 3:36 PM
    #4317
    Dannyblues
    Danny
    Now that's something I'd like to see!!! Fasten your seatbelt well. I guess I have a touch of sadistic humor
    Dannyblues
  18. Apr 4, 2017 at 3:42 PM
    #4318
    Dannyblues
    Danny
    By do your clutch do you mean replace it???? Wow. How many miles on the Tacoma when that happened. You have that modified super Tacoma with supercharged engine plus right? Is that when you had the stage three clutch installed? How does a stage three feel ? Years ( and years ) ago I knew someone who had a racing clutch installed in a 67 cougar. Parallel parking was a nightmare as that clutch was like full on or full off plus he had the engine modified and replaced with some hot large cubic inch motor. It really wasn't a street car in NYC. Dannyblues
  19. Apr 4, 2017 at 3:44 PM
    #4319
    su.b.rat
    su.b.rat broken truck
    according to @nevadabugle, yes, it's not possible to push start. i haven't looked for that in the manual myself, but he tried a push start and it didn't bite.
  20. Apr 4, 2017 at 3:45 PM
    #4320
    Dannyblues
    Danny
    Second post. How much do you think it costs to replace a stock clutch with pressure plate, throw out bearing etc for a complete clutch job on a 2016 stock Tacoma? What did you pay for the stage three clutch plus installation?
    Dannyblues
