Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 4, 2017 at 4:10 PM
    #4321
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think URD had a deal going for about $700 for Flywheel and clutch, and maybe the TO bearing? Budget a grand for that just in case. And I lucked out at the transmission place, dude quoted me $500 over the phone, I said I'd be back when I could have the truck down...hit him up a month later, he said ok THEN I told him I'd be supplying my own parts (which I thought I said on the first call but apparently not) and then he got mildly upset because he was gonna charge me probably another $500 or so for a replcement clutch and all that, but he agreed to do it anyways despite adding that "he doesn't install aftermarket parts" and "I must have used some Jedi mind tricks on him to agree to doing it" clutch has been great since he did it, no complaints here. Most place will probably want to charge a grand to $1500 or so for labor and parts. Maybe cheaper, but I'd budget on the high end for that. After looking at how in depth the work is to replace the clutch, I just decided it wasn't something I wanted to learn at that time, plus I had other shit going on and didn't want to have the truck down for several days.
    Dannyblues[QUOTED] likes this.
  2. Apr 4, 2017 at 4:14 PM
    #4322
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    Good idea to look at the owners manual. I'm thinking of buying the original shop manual. It comes in DVD format I think. No more paperback manuals I was told by the Toyota parts dept.
    Anyway my original 88 Harley shop manual is full of yellow highlighter marking only my exact 88 model references with additional papers added with notes and notations all over the pages that have lost their binding and the manual falls apart every time I open it and I'm forever picking up chunks of pages then reinstalling them back in numerical order.
    My Haynes manual on my 87 Chevy Nova is worse. Being in the trunk for 30 years with most of it being outdoors in New Hampshire year round the manual has degraded and gotten moldy.
    I don't need a 2016 shop manual because I plan to do so much work on my now new Tacoma myself. But I plan to do some services myself like changing ALL the fluids, maybe brakes but more importantly I just want to know what the Toyota shop is SUPPOSED to do when I bring it in for service. I know they take shortcuts and skip important things that take time like removal of a metal cover with four bolts that give access to a few driveshaft lubrication points etc and that long checklist of maintenance checks they are supposed to check they often do or only do some. They just check the fifty or so checks and send the truck out.
    I asked if the mechanics at my shop actually do all the required checks on that Toyota customer service paper. I was told yes. I don't believe it.
    Shops make money on quickly turning over cars serviced. Not taking quality time on any one vehicle and the customer isn't allowed behind the wall to watch the mechanic working on your own vehicle--- for insurance reasons I'm always told. So why not a glass window? Why a wall? Not that I myself would like people watching me work for the 32 plus years I worked as a Pepsi mechanic.
    I used to tell customers it was $100 an hour for labor ..... $125 an hour if they watched ..... $200 an hour if they made suggestions or helped.
    Dannyblues
  3. Apr 4, 2017 at 4:17 PM
    #4323
    Dannyblues
    Danny
    Thanks. How does that stage 3 clutch perform. What's the difference between it and stock? A heavier flywheel I'd assume? Dannyblues
  4. Apr 4, 2017 at 4:38 PM
    #4324
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    True story
    Dannyblues likes this.
  5. Apr 4, 2017 at 6:51 PM
    #4325
    VolcomTacoma
    Jeff
    NorCal
    It engages almost instantly. A little stiffer pedal and about 1/2" of pedal movement right at the end of the travel (up not down) is the engagement zone.
    Went with a lightweight flywheel, 18lbs versus the stock 31lb flywheel. Helps increase acceleration at the cost of making it easier to stall. I stalled probably 10 times in the first month before I got the hang of it all.
    The difference I feel is way better engagement with the supercharger shifts. With the OEM clutch, sometimes when I was pinning it in between shifts (beating full size trucks) I'd hear it slipping in between gears for longer and longer. Inexperience and fun burned out the clutch, combined with overpowering the clutch force itself.
  6. Apr 5, 2017 at 8:20 AM
    #4326
    Dannyblues
    Danny
    Lighter. Flywheel! I'm surprised. Originally I thought a lighter one would make you go faster as less weight along the drivetrain to move but then I read heavier was better to my surprise; I guess to keep up momentum? Maybe on very big cubic inch engines? I didn't realize the new clutch/ flywheel would take that much getting used to. Thanks I was curious about the heavy duty clutch operation. Best of luck. I drive nice and easy. I really like the heavier weight of a truck. It absorbs the shift inertia unlike the high revving sports jobs I had for so many years; passengers always being pinned in their seats or propelled forward on shifts. I can make shifts imperceptible in the Tacoma only my wife gets scared when I blip the gas on double clutch downshifts. I still havent been able to consistently rev match with the drive by wire throttle. I don't shift like that often enough to get really precise at it but I guess over time I'll get it down. Dannyblues
    mict450 likes this.
  7. Apr 5, 2017 at 10:36 AM
    #4327
    mict450
    mict450 got heel toe?
    northeastern California
    2017 TRD Sport AC MT BBP
    Do you blip once or twice?
  8. Apr 5, 2017 at 12:23 PM
    #4328
    VolcomTacoma
    Jeff
    NorCal
    The light flywheel does make you go faster because of less rotational mass it has to 'spool' up. However, it makes stalling easier. A heavier flywheel had more rotating mass to keep the engine going whereas a lighter flywheel has less so the engine will stall easier if you slip it to much with not enough gas. Hence why the heavier flywheel excel off-road.
  9. Apr 5, 2017 at 10:23 PM
    #4329
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Hey again guys. Does 3rd feel ever so slightly raspy going in compared to any of your other gears? Thanks!
  10. Apr 5, 2017 at 10:26 PM
    #4330
    VolcomTacoma
    Jeff
    NorCal
    It'll wear in. Mine used to grind and chunk in so much, after a good 10k miles on it, it goes right in now. Every once in a blue moon it'll grind very lightly or not want to go in softly, but usually only when I'm slamming through the gears doing stupid fast stuff.
    specter208[QUOTED] likes this.
  11. Apr 6, 2017 at 5:14 AM
    #4331
    specter208
    California
    Thanks, if you read a a couple posts back of mine. My truck is brand spanking new (barely 600 miles) and I screwed up 2 shifts by not pushing the clutch far enough and I lightly cooked the synchros. It still goes in easy regardless but this is my first manual transmission vehicle and since it's so new it is making me a little paranoid. Thanks.
  12. Apr 6, 2017 at 5:33 AM
    #4332
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    You can definitely put your mind at ease. I had an '87 Nissan pickup in high school that I taught 6 different people to drive stick with, over the course of about 2 months. Needless to say, there was lots of grinding and clutch hopping, and it still shifted fine after all of it. I drove it for another 3 years after that with zero problems. :thumbsup:
    specter208 likes this.
  13. Apr 6, 2017 at 5:47 AM
    #4333
    specter208
    California
    Awesome, this is my truck btw. What is yours like
  14. Apr 6, 2017 at 8:55 AM
    #4334
    Noelie84
    Noel
    Wales, Maine
    :anonymous:....
    And it's a slushbox, lol.
    However, this one has an A833 4 speed (reverse is to the left and up):
    And this one has an NP435 4 speed (reverse is to the right, and down):
  15. Apr 6, 2017 at 9:06 AM
    #4335
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The only Gear that does not go easily in mine is Reverse but all of my previous Tacoma's were that way. When it was bitter cold my 2000 would not go into 2nd gear the first run thru but was fine after that.
  16. Apr 6, 2017 at 9:24 AM
    #4336
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    You'd consider your EcoBoost a slushbox? My dad's 2012 is a pretty hot little number... different transmission or something?
  17. Apr 6, 2017 at 9:34 AM
    #4337
    Noelie84
    Noel
    Wales, Maine
    Slushbox = slang term for an automatic.
    This truck definitely has no shortage of get up and go. :thumbsup:
    But if I want to shift it myself I have to put it in 'manual' mode and push a switch up and down, lol.
  18. Apr 6, 2017 at 9:35 AM
    #4338
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    Hot damn learn something new everyday!
    Spare Parts and Noelie84[QUOTED] like this.
  19. Apr 6, 2017 at 9:37 AM
    #4339
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
  20. Apr 6, 2017 at 9:37 AM
    #4340
    Noelie84
    Noel
    Wales, Maine
    Dunno where it originated from. Probably because an automatic uses a torque converter pumping a thick fluid to drive the vehicle, much like a slushy machine stirring. :notsure:
