Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 6, 2017 at 9:39 AM
    #4341
    eon_blue
    Azusa, CA
    Didn't "slushbox" originated as a term for older automatics that were notoriously slower and less reliable than manual transmissions? These days we all know that autos are technically "better" (faster shifting, more efficient, etc.), but nothing will ever beat manually throwing your own gears. Manuals have more smiles per mile and always will :D
    Of course @hilux22re said it best, "automatics are for fat people".
    ecgreen and Spare Parts like this.
  2. Apr 6, 2017 at 10:01 AM
    #4342
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Possibly. Doesn't seem likely, though, because I've always heard it referred to as a car having a slushbox, not being a slushbox.
    shakerhood likes this.
  3. Apr 6, 2017 at 10:53 AM
    #4343
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Slush box....because in order to operate is slushes the fluid around from here to there. Technically the slushing more or less happens inside the torque converter ;)
  4. Apr 6, 2017 at 12:13 PM
    #4344
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Actually, someone did a side by side of exact same Tacoma except for transmissions and the auto beat out the manual in an 1/8 mile race IIRC.(2nd gen). The auto just shifts faster and has a better take off I guess. I still love my manual and I'd probably beat an auto with the same mods at this point, but stock trucks will benefit from autos.
  5. Apr 6, 2017 at 12:26 PM
    #4345
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I'll ride the bus before I'll own an automatic (should I actually be forced to own one my out will be "the bus doesn't go where I want to go").
    By the time the additional initial cost, expensive maintenance and repair are factored in the gas mileage won't make the auto come out ahead.
    An automatic transmission is an expensive black box just waiting to have an expensive failure that I don't know how to fix. I've rebuilt several manual transmiossons and changing the fluid is straightforward and easy.
    Oh and I don't like driving autos.
  6. Apr 6, 2017 at 12:40 PM
    #4346
    Noelie84
    Noel
    Wales, Maine
    Depends. A properly-maintained automatic is easily good for over 200k miles, and all that's really involved in properly maintaining one is a $70 fluid and filter change every 60-70k. Adding 3 of those services together still comes to less $$ than it costs to replace a clutch or a bad throwout bearing. :notsure:
    Of course, obviously if you don't like driving an automatic, then that's enough reason not to.
  7. Apr 6, 2017 at 1:04 PM
    #4347
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    I've done it to mine no problem, just put it in 2nd and let the clutch out.
  8. Apr 6, 2017 at 1:08 PM
    #4348
    Noelie84
    Noel
    Wales, Maine
    If the battery is flat enough, it's true that a push start won't work with a modern vehicle. But it has to absolutely, completely dead. If you've got even enough juice left to ding the door chime, it should start.
    nevadabugle[OP] likes this.
  9. Apr 6, 2017 at 1:16 PM
    #4349
    BallsDeep09
    True
  10. Apr 6, 2017 at 1:17 PM
    #4350
    Noelie84
    Noel
    Wales, Maine
    Theoretically, at least. I haven't had an opportunity to try it in person yet.
  11. Apr 6, 2017 at 2:40 PM
    #4351
    VolcomTacoma
    Jeff
    NorCal
    What @Noelie84 said. They are sealed transmissions and the fluid supposedly good for 100k miles (I'd change it every 50k though). If you're some die hard manual fan, good for you, but auto's really aren't what they used to be 20 years ago. As I said, its literally been proven that the autos are quicker and stronger than manuals these days. Yeah when an auto finally goes out, it goes out with a bang. But if you factor in the cost of changing the manual fluid over 200k miles, plus clutch/flywheel/TO bearing replacements, the auto comes out on top, again. Having come from a 2011 automatic Tacoma to my 2015 manual tacoma, I'm glad I made the change, but I hadn't found the one I have now I'd have ended up with an Auto and still been happy. Probably would have ended up spending way less money lol
  12. Apr 6, 2017 at 2:43 PM
    #4352
    VolcomTacoma
    Jeff
    NorCal
    I was gonna say...this. Really you just need enough power to get the injectors spitting and the ECU firing. If your dash lights come on, you should be able to push start it. If your shit is dead to the world, go buy a new battery or get a tow lol
  13. Apr 6, 2017 at 6:12 PM
    #4353
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    My very first car was a 1946 Dodge 5 window business Coupe with a straight 6 flathead and a IIRC "fluid drive" transmission. What that was, was a chamber after the clutch and before the standard 3 speed manual that was full of hydraulic fluid. That chamber had an impeller and a propeller and allowed you to stop and start in any gear without using the clutch), albeit rather slowly. I believe other manufacturers had similar systems. These are the origins of the term slush box.
  14. Apr 6, 2017 at 7:25 PM
    #4354
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I've had plenty of automatics with problems. Didn't want to deal with them anymore. Manuals are simpler, easier, and cheaper to repair.
  15. Apr 7, 2017 at 6:49 AM
    #4355
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
  16. Apr 7, 2017 at 7:10 AM
    #4356
    Zoop
    Zoop Well-Known Member
    The question is which one of us will be the first to push start it and confirm lol
  17. Apr 7, 2017 at 7:26 AM
    #4357
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    as soon as I am on a hill and remember I will try it. I would rather know now before i need it and have to push it.
    Zoop[QUOTED] and shakerhood like this.
  18. Apr 7, 2017 at 7:28 AM
    #4358
    Noelie84
    Noel
    Wales, Maine
    Your truck will start fine as long as the battery's not dead.
    If you want to conduct a thorough test, park on a hill with the lights on until the battery is flat. Then try a push start.
    shakerhood and MOC221_ like this.
  19. Apr 7, 2017 at 7:30 AM
    #4359
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Except when you need it, your battery will have significantly less "juice" in it.. presumably. May not be a valid test for any other condition than a charged battery.
    Frank
  20. Apr 7, 2017 at 7:30 AM
    #4360
    MOC221_
    Frank
    This.. although probably not particularly good for your battery!
