Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 11, 2017 at 2:08 PM
    #4421
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
  2. Apr 11, 2017 at 2:09 PM
    #4422
    jake.2016taco
    jake.2016taco ig: jakeys.yota
    Jake
    Redwood City, CA
    2016 Black Tacoma AC TRD Sport 4x4
    each sticker adds 5hp
    yeah i saw that... i figured you still had a Tacoma since youre on TACOMAWORLD
  3. Apr 11, 2017 at 2:14 PM
    #4423
    Noelie84
    Noel
    Wales, Maine
    Nah. I'm just here to stir up trouble.
    Spare Parts likes this.
  4. Apr 11, 2017 at 2:45 PM
    #4424
    su.b.rat
    su.b.rat broken truck
    What could possibly go wrong?
    Noelie84[QUOTED] likes this.
  5. Apr 11, 2017 at 3:21 PM
    #4425
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    some of the best mpgs I have gotten in my 17, was backroads 50 to 60 up and down hills.
    Noelie84 likes this.
  6. Apr 11, 2017 at 3:27 PM
    #4426
    su.b.rat
    that's a weird thing about this motor, or probably more about it's current tune... the mileage often improves with rpm and workload up to a point. or that's how it seems at times.
    Spare Parts[QUOTED] likes this.
  7. Apr 11, 2017 at 3:49 PM
    #4427
    Noelie84
    Noel
    Wales, Maine
    Most modern vehicles are tuned to get their best mileage at a higher speed than the cars of 20-30 years ago. Seems like they've been increasing their 'sweet spot' for at least half a century. My '16 does best in 6th around 60. My '84 does best in 4th around 45. My '69 does best downhill, in neutral, with a tailwind... :anonymous:
    Spare Parts and su.b.rat[QUOTED] like this.
  8. Apr 11, 2017 at 5:15 PM
    #4428
    su.b.rat
    my mileage went from 14-15 to 18.6 after i stopped trying to improve it. then i just started to drive the crap out of her with a pedal commander and the mileage jumped. o_O
  9. Apr 11, 2017 at 6:44 PM
    #4429
    Spare Parts
    Southern Maine
    So can you explain this pedal commander thing. I haven't done any research yet, but would love to have it explained for a cave man.
  10. Apr 11, 2017 at 9:43 PM
    #4430
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have been setting mine to that Mileage Bar and have been fixated on it but notice the complete opposite, seems as mine Revs the mileage bar drops way down, don't think I have been over 4 Grand yet so maybe MPG starts to go up beyond that?
  11. Apr 11, 2017 at 9:51 PM
    #4431
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Who else came for the pic?
    :spy::burnrubber:
    jake.2016taco[QUOTED] likes this.
  12. Apr 13, 2017 at 5:41 AM
    #4432
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Oem Flywheels vs aftermarket.
    Truck: 2001 Tacoma 4WD 5VZ-FE, 250+K miles.
    I will be replacing my clutch soon with one with a heavier clamp load (Exedy #16805) and thought of replacing the flywheel at the same time. The first clutch lasted 150K, now the replacement and throw out bearing is wearing out. Looking at flywheels, I see OEM Toyota flywheels are $400 while standard aftermarkets ones are $50 to $100. Are they that inferior? If my flywheel is in good shape is it better to resurface the original one? The original flywheel weight is fine, I believe it is 22-23lbs. Marlin has a 23lb one for $120, having one in hand will save time going back and forth to the shop, but I don't want to put in anything inferior to what is there.
  13. Apr 13, 2017 at 5:48 AM
    #4433
    Noelie84
    Noel
    Wales, Maine
    If you have the flywheel machined it will still have hot spots, and will be more likely to crack or warp because it'll be thinner. Plus you may have to shim it for proper engagement. If you feel the need to service it while you've got it out, I'd vote to replace it.
    As for a replacement part, flywheels are pretty low-tech. Unless you're really beating on it, aftermarket will work just as well as the Toyota part.
    Edit: And if you're working it that hard, you'd be better off with an aftermarket performance-type part anyway.
  14. Apr 13, 2017 at 5:50 AM
    #4434
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Thanks!
  15. Apr 13, 2017 at 7:43 AM
    #4435
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Tough call. Aftermarket usually has a much higher rate of quality problems due to cheap Chinese manufacturing and (more importantly) lax quality checks. Unfortunately, the flywheel is not something that is very easy to swap out if you find an issue. I would inspect the flywheel you have, and get it turned if its in good shape. If its out of spec, I would search the forums and try to find someone who has had success with the particular replacement you are looking at.
    I had a Subaru WRX with 150K miles on it that had two torn CV boots. One had been torn long enough that the joint was shot. I figured I would go ahead and swap all the shafts out at the time I was replacing struts anyhow. I installed a set from Advance Auto (best they had), and experienced loud clicking sounds from the shafts. Knowing that often NAPA use to carry better replacements, I swapped the AA ones out for the "best" NAPA had. Those vibrated when accelerating. Of course the part is described as meeting or exceeding OEM requirements, but that is marketing hogwash. The low cost Chinese parts simply have very little in the way of quality checks, and the Chinese manufacturers often will cut corners if they believe they won't get caught. Sure, the importers will take the parts back if they are bad, but do you want to yank the flywheel more than once to get the repair right?
  16. Apr 13, 2017 at 3:22 PM
    #4436
    Skeeter42
    Skeeter42 Well-Known Member
    Colorado
    2017 TRD OR DCSB 4WD Quicksand (MT)
    Sorry to be quoting something from over a month ago, but I'm getting a similar issue with my manual transmission. I've driven a manual since I got my license and all other cars I've owned with MT haven't produced the same sounds I'm getting out of this Tacoma (yes I know it's a truck, it will & should squeak/clunk/etc. and I can accept that from other parts of the truck). My concerns are only due to this being possibly drive train related. 1st, 2nd, 3rd & 4th gears I get a clunking, metallic sound when depressing the clutch and switching from one gear to the next. The same sound also seems to occur in neutral over bumps and as I let off and re-apply gas in gear while driving. Any thoughts on what may be causing this?
    I'm wondering if I should check my U-joints for any noticeable slop, though I greased all the zerk fittings I could (not all joints had them) when I got the vehicle. There's no way the joints could see that much wear in 8k miles, is there? I have the 10k service coming up and may have someone from the stealershit ride around with me in the vehicle...
  17. Apr 14, 2017 at 9:12 PM
    #4437
    shakerhood
    Southern Ohio
    My Kinda Woman!
    specter208 and TeecoTaco like this.
  18. Apr 14, 2017 at 10:01 PM
    #4438
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    :eek: I have a thing for girls with tats....im now in love. Wonder if my wife would embrace polygamy? I'm gonna ask...
    shakerhood[QUOTED] likes this.
  19. Apr 14, 2017 at 10:03 PM
    #4439
    nevadabugle
    Elko, NV
    What's the rest of that photo look like?
  20. Apr 14, 2017 at 10:29 PM
    #4440
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Better chance of getting your wife to get that tattoo.
