Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 22, 2017 at 9:47 PM
    #4581
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Not funny.
  2. Apr 22, 2017 at 9:54 PM
    #4582
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Should have gotten AT with crawl control.
  3. Apr 22, 2017 at 9:57 PM
    #4583
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Damnit no wonder I'm single, they always leave when I try to use my underwear.
  4. Apr 23, 2017 at 1:52 PM
    #4584
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Hmm.. I've not tried it, but the brakes should not change when the engine is not running - as long as the key is still on. He has an OR like me, we have the electric brake booster (a pump, vice vacuum assist). Meh, I'm gonna leave my truck running anyway, cause power steering is nice!
    :thumbsup:
    Frank
  5. Apr 23, 2017 at 3:18 PM
    #4585
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Even with the engine off, in gear it is still spinning the motor so you do have power steering.
  6. Apr 23, 2017 at 3:25 PM
    #4586
    worthywads
    Anyone that wants to test this it is pretty simple.
    While driving above 2000 rpm and in gear let off the gas, at some point between 1500 and 1000 rpm it will kick the injectors back on which is the problem people don't want when crawling.
    Now do the same thing except after letting off the gas turn the key from ON to ACC. You will continue to coast with engine breaking but the injectors won't kick in. Tach and other gauges won't work but you'll have power steering.
  7. Apr 23, 2017 at 4:49 PM
    #4587
    MOC221_
    Frank
    I was out wheeling today and experienced the loss of engine braking as described first hand. 4Hi 1st gear, going downhill and holding back nicely from 2000 down to about 1300 RPM.. then it just "let go". I didn't try shutting it off. Too bad Toyota couldn't cause this function to be disabled when selecting 4Hi - or at the very least 4 Lo.. Anyway, something to be aware of.
    Frank
  8. Apr 23, 2017 at 6:03 PM
    #4588
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    It's because you're in to high of a gear at that point, if you're really engine braking you should have shifted to a lower gear once you hit about 2k rpms and revmatched properly. Engine braking is probably pretty nil at 1500 rpms or below. Crawlers are usually in 4LO and aren't really gonna be down that low in rpms since you want constant power on the wheels to keep the torque up. Shit I'm at like 3k rpms at about 5 mph in 1st gear in 4L0
  9. Apr 23, 2017 at 6:28 PM
    #4589
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah I've given up on 4HI most of the time now even in snow, unless I'm being a total boss bombing dirt roads. To be safe, you gotta stay in 4LO and just start out in 3rd if you need to
  10. Apr 24, 2017 at 3:06 AM
    #4590
    MOC221_
    Frank
    Was this reply for me? What you maybe don't get is that the engine will hold back from 2000 all the way down to about 1300, then it will change "modes" and seems to free run all the way back up to 2000. Rinse. Repeat. I wasn't in 4Lo because I didn't need to be, just on a downhill section of logging road.
    It's weirdness because it gives you inconsistent engine braking, regardless of which Tcase range you're in.
  11. Apr 24, 2017 at 6:12 AM
    #4591
    Shellshock
    Iowa
    After a 2 month wait I'm finally back in the third pedal club. 200 miles already in the first two days I've had the truck and zero regrets.
  12. Apr 24, 2017 at 6:56 AM
    #4592
    greenjeans
    greenjeans Member
    Joseph
    New Taco
    I was driving some local logging roads yesterday (saddle mtn area) and enjoying the shit out of my new taco & I noticed a few things..1st off since day one driving the manual trans and being used to conventional engine response, like letting off the gas and the engine compression slowing you, the 3.5 has some different ideas, at slower speeds/RPM's I noticed it will act like a "normal" engine around 2000rpm unless your going down a steep hill then it wants to let go to about 3k rpm, then begins to feel like compression is slowing it down, it is different but not annoying or anything, in 4 lo it crawls along slow & steady. Anyone else notice this, & what do you think about it? One thing is engine complication factor/ more tech more fail points. I trust it...it's a Toy.
    MOC221_ likes this.
  13. Apr 24, 2017 at 11:16 AM
    #4593
    MOC221_
    Frank
    Yes a few of us have noticed this, I think Nevadabugle started it off a few posts back...
    Frank
  14. Apr 24, 2017 at 11:18 AM
    #4594
    MOC221_
    Frank
    Love that colour, no regrets on the M/T here either!
    Nice truck man, have fun :cheers:
    Frank
  15. Apr 24, 2017 at 11:28 AM
    #4595
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Anybody ever get a harmonic resonance sound when slipping the clutch? Every once in awhile when I have to slip the clutch a bit to get moving I hear a strange harmonic type sound. I can't tell if it's a heat shield vibrating or something with the clutch?
    MOC221_ likes this.
  16. Apr 24, 2017 at 12:55 PM
    #4596
    nevadabugle
    Elko, NV
    Seems strange. I've not heard of anything like this.
  17. Apr 24, 2017 at 2:15 PM
    #4597
    HotZTrain
    HotZTrain Active Member
    Paul
    92 Toyota 4x4, 3.0
    EGR removed
    I think Toyota underestimates the demand of manuals. I think if they made twice as many as they do they would sell every one of them...................................
    That’s exactly what the salesman told me at Desert Toyota in Tucson, AZ. I just bought a 2017 TRD 4x4 with a 6-speed manual, access cab. Had to order it and wait 90 days. The sales dept says they have to take what ever they are sent.
  18. Apr 24, 2017 at 3:46 PM
    #4598
    su.b.rat
    su.b.rat broken truck
    i don't know what you mean "bounced". can you expand on that?
    scottalot, TeecoTaco and shakerhood like this.
  19. Apr 24, 2017 at 5:13 PM
    #4599
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    wiggled?
  20. Apr 24, 2017 at 6:16 PM
    #4600
    VolcomTacoma
    Jeff
    NorCal
    Probably means he shifted at slightly to low of RPMS and got the engine lug bounce. Also may have not given it enough gas. I mean it can happen from a variety of things if you aren't spot on with your shifts and rev matching. I still do it on occasion when I'm shifting slowly and not super paying attention...2nd gear will chug a little bit right after I let the clutch out. Usually cold engine and I'm not really giving it much gas to get going.
