Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jun 6, 2017 at 8:37 PM
    #5041
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I failed when i tried it in my 2016. I had done it many times in my 1996 (Yes first gens had problems too).
    With that said some on here claim it works with a 3rd gen. I believe there has to be enough battery left to run the ECU.
    jkm25[QUOTED] likes this.
  2. Jun 7, 2017 at 1:36 PM
    #5042
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    I've push started mine, it was easy get a lil roll going put the key in ACC mode put it in 2nd and let the clutch out
    jkm25[QUOTED], TeecoTaco and su.b.rat like this.
  3. Jun 7, 2017 at 3:59 PM
    #5043
    su.b.rat
    su.b.rat broken truck
    really glad to know about this. thanks.
  4. Jun 7, 2017 at 6:16 PM
    #5044
    NewWheeler
    NewWheeler Well-Known Member
    Gus
    Fort Worth, TX
    2017 Quicksand DCSB TRDOR 6MT
    I don't have my truck yet but, I think that you may have misspoken. You would need the key in "Run" to push start the truck.
  5. Jun 7, 2017 at 8:43 PM
    #5045
    Deplorable
    Deplorable Active Member
    SF Bay Area
    GTI 6-speed
    Interesting. I own a VW GTI manual, and I've read that push starting it, while feasible, is going to damage the computer or something.
  6. Jun 8, 2017 at 10:55 AM
    #5046
    BallsDeep09
    Yea whatever mode it is, the position where all the electronics are on.
  7. Jun 8, 2017 at 11:34 AM
    #5047
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    I figure this would be the best place to share this.
    I recently replaced my clutch at 140k with an Aisin OEM replacement. The "old" clutch was operating fine, but there was a rattling or rustling noise when I depressed the clutch pedal. I thought it was a throughout bearing, but considering I have a 4 cylinder, I wasn't quite sure. Even though I didn't want to, the only way to know exactly what the problem was was to replace the clutch. Also, I didn't really like it's feel, so I decided I would replace it with another OEM quality clutch to see if there were any changes.
    It turns out a spring had broken off in the clutch disc and was rattling around against the other components. It also turns out that it wasn't an OEM clutch that I was replacing - it was a Centerforce that the previous owner had installed! I think if I had known that it was an aftermarket clutch, I would have expected a different feel and therefore would have understand why it felt like it did. I just wasn't expecting the stiffness and short take up/friction point in a stock clutch.
    Anyways, just my random experience replacing my clutch. I would have like to have kept the centerforce in, had I known it was there, but the replacement was also necessary.
    Hope y'all enjoyed!
    su.b.rat likes this.
  8. Jun 8, 2017 at 2:25 PM
    #5048
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    But on the OEM clutch, metallic rattling is a factory installed feature (at least on 3rd gens)!
  9. Jun 8, 2017 at 3:40 PM
    #5049
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    I love my truck.
    TeecoTaco likes this.
  10. Jun 8, 2017 at 4:01 PM
    #5050
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Fitting
  11. Jun 9, 2017 at 8:21 AM
    #5051
    JudgeJosephDredd
    JudgeJosephDredd I AM THE LAW!
    Crestucky, FL
    2017 TRD Off Road DCSB, 6 spd
    Stuff and Things
    question concerning the clutch start cancel: why? can't imagine a scenario in which I would use this. the best I could come up with would just me being lazy to start my truck. any info would be greatly appreciated.
  12. Jun 9, 2017 at 8:27 AM
    #5052
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I use it when I get back to the trailhead with muddy boots, or down to the parking lot in ski boots. Get the truck started and warming up before taking off boots and getting in. Pretty handy.
  13. Jun 9, 2017 at 8:41 AM
    #5053
    UTBoatFanatic
    UTBoatFanatic Well-Known Member
    Don
    Midvale, UT
    2017 Dark Grey Tacoma Double Cab Off-Road - Manual Transmission
    Leer Shell
    One possible scenario is a situation where let's say you're in 4-low, on a trail or in a situation where you don't want to risk rolling back as you start the truck. The truck will start easily enough in 4-low and 1st gear in most cases. Kind of a replacement for having the brakes have some sort of "hill holder" function. My expectation is the one or two times in the lifetime of owning the truck that you need to use that button, you'll thank whatever engineer decided it was worth putting it in, but you could also go the entire life of owning the thing and never use it.
  14. Jun 9, 2017 at 8:41 AM
    #5054
    Cold_Toad
    Cold_Toad Well-Known Member
    It's for when you are in a scenario where your truck is shut off and you can not afford roll backwards while you operate the gas/brake/clutch at the same time when you start it. You press that button while in 4lo and let the starter pull you ahead while cranking and starting the engine.
    @UTBoatFanatic beat me to it, but what he said
  15. Jun 9, 2017 at 9:08 AM
    #5055
    JudgeJosephDredd
    Crestucky, FL
    Stuff and Things
    Ahhhh that makes sense. When I was researching the truck I thought it was funny that the auto had the hill start assist but not in a manual. appreciate the info!
    protaxidermist likes this.
  16. Jun 9, 2017 at 11:05 AM
    #5056
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Certain Manual Tacoma's also have Hill Start Assist, glad my OR does not.
    MOC221_, RedBeard1 and su.b.rat like this.
  17. Jun 9, 2017 at 12:05 PM
    #5057
    yourestupidforasking
    yourestupidforasking Member
    Sean
    North San Diego County
    2015 TRD Off-Road 4x4 DCSB
    Wheeler's Off-Road 1.5" AAL Custom Half-Rack Roof Rack w/RotoPax mount Tepui Autana XL RTT
    I'm pretty sure that there's a TSB for that.
  18. Jun 9, 2017 at 3:18 PM
    #5058
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah tell that to my service guy
  19. Jun 9, 2017 at 4:38 PM
    #5059
    Sean
    No, seriously. I was just at the service center on Wednesday grabing some stuff and I asked the guy at the counter if he knew of any issues with the new clutches. He pulled up the TSB and there's one in there about a rattling from the clutch. Fix was a new clutch.
  20. Jun 9, 2017 at 4:43 PM
    #5060
    nevadabugle
    Elko, NV
    Hmmm...im listening. Anyone else know about this TSB?
