Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jun 30, 2017 at 7:33 AM
    #5161
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll typically hang around 2100 rpm, but it really depends. I just try and cruise with minimal strain on the motor, so sometimes it's as high as 2500, depending on the terrain.
  2. Jun 30, 2017 at 2:28 PM
    #5162
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Has anyone experienced a whistling noise when accelerating in 3rd gear up to 35 mph? No, I don't think this is the LCA noise.
  3. Jun 30, 2017 at 2:50 PM
    #5163
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I have one at 62. And occasionally around 35.
    specter208[QUOTED] likes this.
  4. Jun 30, 2017 at 2:55 PM
    #5164
    specter208
    California
    This came on suddenly and was very easy to hear over quiet music and went away as soon I let off throttle.
  5. Jun 30, 2017 at 4:48 PM
    #5165
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    The what?
    I've been shifting around 3.5K-4K. Burns a lot of gas but the truck drives better.
    shakerhood likes this.
  6. Jun 30, 2017 at 4:53 PM
    #5166
    nevadabugle
    Elko, NV
    There is an ECU tune that was just released by orange virus.
  7. Jun 30, 2017 at 9:12 PM
    #5167
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I rarely even use 5th gear, usually go from 4th to 6th.
  8. Jun 30, 2017 at 9:28 PM
    #5168
    TBV
    Oakland CA
    2017 TRDOR 6MT
    I can only do 6th on open road. Usually in 5th due to changing freeway conditions/traffic.
  9. Jul 2, 2017 at 4:10 PM
    #5169
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Yes I know exactly what you are talking about. Loud high pitched whistle sounds like it is coming from the engine bay. Doesn't happen often but has usually occurred when I'm trying to accelerate hard up a highway on ramp for example. No clue what it is. I know you say 3rd gear but I think it has happened to me in 2nd too.
  10. Jul 2, 2017 at 5:24 PM
    #5170
    nevadabugle
    Elko, NV
    Yep. I thought it was the rear end but the more I have listened it definitely comes from the front of the truck.
    specter208 likes this.
  11. Jul 2, 2017 at 5:42 PM
    #5171
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Oh good I'm not crazy. I had it looked at, but you know the drill.
  12. Jul 2, 2017 at 8:15 PM
    #5172
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Ok. Had the truck almost two weeks and just trying to get a handle on this manual tranny. Should I be hearing a bit of noise from tranny while shifting. I seam to get a hollow knock or small rattle every time I shift 1st through third most notable. Almost sounds empty. I know that the autos had low fluid issues. Any one here have low fluid on manuals. Just want to make sure these noises are normal. I know my 89 Toyota makes small noises while moving through gears but nothing like this. Thanks for the input.
  13. Jul 2, 2017 at 8:55 PM
    #5173
    aero90
    Mine makes noise and 3rd gear especially is pretty "notchy" to the point where I can hear it click/clunk into gear
    BassAckwards and specter208 like this.
  14. Jul 2, 2017 at 11:25 PM
    #5174
    JARStacoma
    Alaska
    alright. That's good to know. I am loving the truck but want to make sure these sounds are the norm. Thanks for your input.
  15. Jul 3, 2017 at 5:52 AM
    #5175
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Got this in mine as well. It's not like a grinding feel as if you don't have the clutch in, but just a clunky feel. Usually get it going into 2nd and 3rd. Think I'm going to swap out the gear oil and see if that helps any.
  16. Jul 3, 2017 at 6:23 AM
    #5176
    specter208
    California
    Same, 3rd is a little raspy for me too.
  17. Jul 3, 2017 at 7:59 AM
    #5177
    JARStacoma
    Alaska
    So mine is pretty smooth at the stick. It just makes this noise when depressing the clutch in and out. It's not hard to move the gears.
  18. Jul 3, 2017 at 8:08 AM
    #5178
    specter208
    California
    What kind of noise is it. Is it like a spinning bearing type sound or more of a quick chatter when the clutch disc separates?
  19. Jul 3, 2017 at 8:50 AM
    #5179
    JARStacoma
    Alaska
    More like the latter. It sounds like things are engaging which would make since. Just want to see off others here it too. Clutch in shift acceleration clutch out in that movement is where the noise occurs.
  20. Jul 3, 2017 at 9:17 AM
    #5180
    specter208
    California
    I get those noises all the time too. Most of the time I don't care but If I slow down my shifting as in waiting a second or two before pressing clutch somewhat slow I avoid those noises.
