Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 14, 2017 at 4:38 PM
    #5281
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I know right...somehow, it just worx...but that trd jobbie is better lookin
    OffsetPlayer2 likes this.
  2. Jul 14, 2017 at 5:42 PM
    #5282
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Agree on that part. It does fit decently.
  3. Jul 14, 2017 at 8:00 PM
    #5283
    su.b.rat
    su.b.rat broken truck
    on the drive home after delivery i couldn't deal with that Pro knob. i replaced it the next morning, and about every couple months after that until i found the winner.
  4. Jul 14, 2017 at 8:39 PM
    #5284
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Like...first week of owning the truck, swapped to this. Might need to pull the handle off soon and give it a good scrub lol, but love every second of it
  5. Jul 15, 2017 at 3:37 AM
    #5285
    OffsetPlayer2
    Haven't seen one of those in a while
  6. Jul 15, 2017 at 4:00 AM
    #5286
    VolcomTacoma
    Jeff
    NorCal
    Saw it a buddies truck a while back, figured it was worth the $30 or so to find out if I liked it. Plus it was a "Hurst Core Short Shifter" so I figured I might as well match the handle to it. I love it alot more than a ball shifter. Definitely gives me something more to grip when I'm slamming through gears (beating third gens LMAO)
  7. Jul 15, 2017 at 4:31 AM
    #5287
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
  8. Jul 15, 2017 at 7:30 AM
    #5288
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    How do the 2nd gens shift compared to our 3rds.
  9. Jul 15, 2017 at 7:57 AM
    #5289
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    3rd Gen shifts much smoother compared to 2nd Gen
  10. Jul 15, 2017 at 8:13 AM
    #5290
    su.b.rat
    used to have one of those connected to a 468ci overbore Chevy BB on a modified Turbo 400. 1970 LeMans Sport with a $11,00 racing suspension. young man's game back in the day. i can still feel that Hurst in my hand.
    nevadabugle[OP] likes this.
  11. Jul 15, 2017 at 12:00 PM
    #5291
    Clay
    Clay Well-Known Member
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    I went from a 2010 5-speed to a 2016 6-speed....After getting used to the fact that reverse is now 6th...I was OK. As for smoothness - That got better with time (I have 31K on it now). I am not in favor of the way they handled reverse ...(Just spring tension) all too easy to put it in reverse when you are looking for first. My Camry manual has a superior system - A ring on the shift lever that you have to pull up with your fingers to get it into reverse - Too bad they did not do that with the Taco - Just VERY thankful I did not get the automatic.
    BassAckwards likes this.
  12. Jul 15, 2017 at 12:20 PM
    #5292
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    It takes considerably more effort to put the 6-spd into reverse than 1st on a 2nd gen. It would be highly unlikely someone could accidentally go from 2nd to reverse while driving.
    samiam and shakerhood like this.
  13. Jul 15, 2017 at 12:29 PM
    #5293
    Clay
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    Maybe I should have been more clear ....My issue with Reverse is when you are - STOPPED - It's very easy to ignore the spring tension and the little beep and slide it into reverse. The big sign that you did it wrong is the backup camera display tells you that if you let the clutch out you are going to back up. I had that happen a couple of times when I first got it. My solution to making sure that this is not an issue is to, when stopped, always shift to 2nd and THEN to 1st. If I didn't have the Camry with a manual I would have not known that Toyota had a better, more positive, means of dealing with the issue. You are not likely to find reverse if you are in motion and downshifting from 2nd to 1st as that's a straight forward motion of the stick...The issue is when you are pulling the stick to the left and then up, you can easily pull it left too far.
  14. Jul 15, 2017 at 12:36 PM
    #5294
    replica9000
    2019 T4R ORP
    I understood what you said. I was just saying on the 2nd gens, even while stopped, it's difficult to mistake reverse for 1st. I guess Toyota didn't carry this over to the 3rd gens.
    EatSleepTacos likes this.
  15. Jul 15, 2017 at 12:46 PM
    #5295
    specter208
    California
    I haven't once mistaken reverse for 1st in any situation. You should be more relaxed when selecting your gears.
    Krogen likes this.
  16. Jul 15, 2017 at 1:27 PM
    #5296
    shakerhood
    Southern Ohio
    Mine is plenty difficult to put in Reverse and I've never come close to accidentally engaging it instead of 1st Gear in any of my 2nd or 3rd Gens.
    TeecoTaco and specter208 like this.
  17. Jul 15, 2017 at 1:49 PM
    #5297
    TeecoTaco
    SW Ontario
    Dood, evrytime this topic comes up I think of you lol...and picture you two handed wrestling your MT into reverse...lmao....sorry dood.
    :rofl:
    STacoS and shakerhood[QUOTED] like this.
  18. Jul 15, 2017 at 2:00 PM
    #5298
    shakerhood
    Southern Ohio
    Seriously, it would be funny if it were not true!
    TeecoTaco[QUOTED] likes this.
  19. Jul 15, 2017 at 5:58 PM
    #5299
    su.b.rat
    when your shift knob is 733g it can have a mind of its own if your aim isn't damn perfect. and you can be totally chill while that's happening.
  20. Jul 15, 2017 at 7:13 PM
    #5300
    VolcomTacoma
    Jeff
    NorCal
    Beautiful. I love it. Nothing like being able to fully grab that hand and pull it down for those fast shifts.
