Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 6, 2017 at 8:46 PM
    #5561
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    I like to slam into hard downshifts rather than brake. :eek:
    Bigfsur likes this.
  2. Aug 6, 2017 at 10:34 PM
    #5562
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  3. Aug 7, 2017 at 6:34 AM
    #5563
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
  4. Aug 7, 2017 at 7:49 AM
    #5564
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    The manual transmission is the original fidget spinner..In this day and age you can now take it with you.
    specter208 likes this.
  5. Aug 7, 2017 at 8:11 AM
    #5565
    su.b.rat
    su.b.rat broken truck
    thanks for this. if a SC is coming then there's only one more piece to wait on before i can play... need a Posi for that power on this one legger. well that and about 10k$. :p
  6. Aug 7, 2017 at 9:29 AM
    #5566
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    1st gear WTFO, then dump clutch.
  7. Aug 7, 2017 at 10:32 AM
    #5567
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Technically, you should always be in A gear when in motion. You shouldn't coast unless you're almost at a stop. But in your situation, I would have double clutched into first gear.
  8. Aug 7, 2017 at 10:39 AM
    #5568
    natural_nativ
    natural_nativ Well-Known Member
    2024 TRD Sport MT
    Serious question: Can you explain why you should always be in a gear when moving?
  9. Aug 7, 2017 at 10:43 AM
    #5569
    TBV
    Oakland CA
    2017 TRDOR 6MT
    Coasting isn't safe. No ability to accelerate quickly if needed. Also less control over the vehicle because engine/drivetrain are disconnected from the road.
    pinochle likes this.
  10. Aug 7, 2017 at 10:45 AM
    #5570
    pinochle
    NNJ
    Well... it's because you're in more direct control of your vehicle. For example:
    You're coasting to a stop and a car starts pulling out towards you as you're passing by and could hit you. Because you're in neutral, you can't step on the accelerator to pull away. However, if you were in gear, you could step on the pedal and accelerate and maneuver to the side.
  11. Aug 7, 2017 at 10:47 AM
    #5571
    natural_nativ
    2024 TRD Sport MT
    Makes sense. I was thinking there was something to do with wear on the vehicle that I wasn't aware of.
    Thanks.
  12. Aug 7, 2017 at 11:56 AM
    #5572
    su.b.rat
    as a student of driving i agree, although the effect on the truck is pretty minimal, maybe hence the "technically..." comment. in a car with a higher power to weight ratio, bumping the gas when off throttle while the drivetrain is engaged (not costing) will cause torque to push the drivetrain down into the road increasing traction and control. in race cars you live and die by that control. on the road you just may need that unexpectedly one day.
  13. Aug 7, 2017 at 2:18 PM
    #5573
    RedBeard1
    Red
    No posi needed... Just tap your traction control switch and put it in auto LSD and your good. One feature these trucks have that really works well use it off road in 2wd pretty regularly.
  14. Aug 7, 2017 at 2:26 PM
    #5574
    su.b.rat
    nope, the auto lsd is a low speed traction solution you can't get any use of with normal on road 2hi tarmac driving.
    if i ever put high power on this truck then I'll be planning to use it, which means i need a high speed usable traction solution. and I'll have to give up the low speed auto lsd to get it. i would not get real power here and be stuck with power on a one legger and a single E rate tire. not for me.
    the only thing now is that there isn't a posi for the 8.7 rear yet. probably another 1-2 years for that if Eaton does their thing.
  15. Aug 7, 2017 at 4:10 PM
    #5575
    smdcbr
    smdcbr Well-Known Member
    Passaic county, NJ
    2016 Blue TRD Sport AC M/T
    I'm late to the party as usual, but to me it depends on the situation. If I was in a 25mph residential area or somewhere I was taking my time, I'd just lug it in 2nd for a bit. Otherwise, rev it and hit 1st.
    specter208[QUOTED] likes this.
  16. Aug 8, 2017 at 12:58 PM
    #5576
    brain_the_av8or
    brain_the_av8or Member
    Bryan
    Hello all!
    I'm brand new to Tacoma world. Maybe you guys could offer me some good insight. I plan on buying a 2018 TRD Off-Road when I return home from my deployment in early 2018. I have done a lot of research and know exactly what options/package I want, except I keep debating whether to get the manual or auto. I've owned two manual cherokees with the bullet proof tacoma AX15 5-speed and absolutely loved them. I prefer driving a manual but the thing that is causing me to debate possibly getting the auto is that the manual is not available in the double cab w/long bed, only the double cab w/short bed. I really like the utility of the long bed and crawl control is kind of cool. What would you guys suggest? Is the 5 foot bed sufficient or would an extra foot make a big difference and is it worth the trade off of losing the manual transmission?
  17. Aug 8, 2017 at 12:59 PM
    #5577
    TBV
    Oakland CA
    2017 TRDOR 6MT
    I know what advice you're going to get in here.
    You can get a long bed in the Access Cab Sport 6MT config.
  18. Aug 8, 2017 at 2:26 PM
    #5578
    specter208
    California
    You won't know exactly what you'll want until you try out both the auto and manual. As for wanting a DCLB OR in manual, that configuration is currently unavailable with a MT. You'll have to buy the auto and custom install a MT yourself, or get the DCSB. Another option is the TRD Sport Access cab which is available with a MT and can be modified with OR suspension parts which can be found cheap here on TW.
    Do you plan on doing a lot of gear hauling. You may also purchase a bed extender which will afford you a little extra space in a short bed model.
  19. Aug 8, 2017 at 2:28 PM
    #5579
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Test drive for Sure! I gave up the long bed so that I can have an off road manual
  20. Aug 8, 2017 at 4:23 PM
    #5580
    brain_the_av8or
    Bryan
    Any regrets?
