Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 22, 2017 at 10:44 PM
    #5641
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    I bought this cheap shifter on eBay for super cheap a long time ago for my 2nd gen taco, the TRD imprint got super dirty over time so I colorfilled it. Came out good. Cheap and fast $3 mod.
    mcharfauros likes this.
  2. Aug 22, 2017 at 10:50 PM
    #5642
    TacoBurgh
    TacoBurgh Well-Known Member
    Pittsburgh
    2014 MGM DCSB 6sp
    Bilstein 6112's set at 2'' up front Bilstein 5160's out back Headstrong 3 leaf AAL Goodyear Wrangler Duratracs 265/70/17 on SCS Matte Dark Bronze Ray 10's.
  3. Aug 24, 2017 at 7:27 AM
    #5643
    uberschall
    uberschall Member
    2017 TRD Off-Road
    Dealer: would you consider an automatic?
    Me: absolutely not.
    24-7, TACK, Eagleperry338 and 3 others like this.
  4. Aug 24, 2017 at 10:35 AM
    #5644
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Does anyone else get the squeaky spring sound from underneath the truck when they press in the clutch? Seems to happen when it's humid.
  5. Aug 24, 2017 at 10:47 AM
    #5645
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Are you sure the sound is under the truck and not the pedal assembly? If it is the pedal assembly then use some disc brake grease on all the pivot points and that should take care of that old barn door sound.
  6. Aug 24, 2017 at 10:51 AM
    #5646
    replica9000
    2019 T4R ORP
    I get that squeak sometimes too. This one is definitely underneath.
    shakerhood[QUOTED] likes this.
  7. Aug 24, 2017 at 11:05 AM
    #5647
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I do too but I haven't investigated it yet.
  8. Aug 24, 2017 at 11:39 AM
    #5648
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    It is probably the slave cylinder pushrod squeaking. You'll have to remove the slave cylinder and grease the tip.
  9. Aug 25, 2017 at 10:09 AM
    #5649
    biker921
    biker921 Well-Known Member
    Austin
    '17 TRD Pro
    MT is the only way to go! Drive the AT TRD PRO and hated it! No balls behind it. At least with my MT, I can get a little tire chirp shifting to second. Lol
  10. Aug 27, 2017 at 8:55 AM
    #5650
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I've been interested in how the 2nd gen 6MT performed in those trucks. I've heard the 6MTs in those tucks were very problematic. Are the late model 13-15 year 6MT better than earlier model Trans. Also, how does 2nd gen compare to the 3rd gen 6MT.
  11. Aug 27, 2017 at 8:58 AM
    #5651
    shakerhood
    Southern Ohio
    I had an 08 and a 15 and never had any issues or problems, my 17 shifts much smoother with much less effort.
    specter208[QUOTED] likes this.
  12. Aug 27, 2017 at 9:01 AM
    #5652
    specter208
    California
    What RPMs would your trucks be at on the freeway going 65 in 6th gear. Also, how was throttle response and did they pull harder than your 3rd gen.
  13. Aug 27, 2017 at 9:05 AM
    #5653
    shakerhood
    Southern Ohio
    Both trucks are pretty close in RPMS, the 2nd Gen had much more use able power down low and the 3rd Gen has more power up high.
  14. Aug 27, 2017 at 10:24 AM
    #5654
    orangeracer
    Getting close to 200k miles on my 6spd manual 2nd gen on just oil changes. Comparing to the 3rd gen manual trucks I've driven, my 2nd gen can be driven lazier (less shifting) and has more noticeable pull off the bottom. If the 3rd gens had the 4L engines, I'd jump on one.
    shakerhood likes this.
  15. Aug 27, 2017 at 5:04 PM
    #5655
    specter208
    California
    Anybody hear a faint whistle or air noise sometimes when accelerating in 2nd or 3rd and then it stops when you take foot of the throttle. I hear this at less than 40mph.
  16. Aug 27, 2017 at 5:13 PM
    #5656
    Sil
    Sil Of the Earth
    Georgia
    2017 Tacoma SR MGM i4 5 speed 4x4 aka. Vulcan
    Pending..
    Were you able to get this installed this weekend? If so, how is it driving?
  17. Aug 27, 2017 at 5:18 PM
    #5657
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    I have not heard this noise on mine. Just the noise of the clutch when let out at a stop.
  18. Aug 27, 2017 at 5:29 PM
    #5658
    specter208
    California
    How about on hill starts, sounds like engine occasionally crackles.
  19. Aug 27, 2017 at 6:07 PM
    #5659
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    No crackle. I do have an AFE intake making noises more noticeable but nothing out of the ordinary.
    I pull the e-brake since so I will not roll back. Off roads do not come with the hill start.
  20. Aug 27, 2017 at 6:11 PM
    #5660
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    Where is the crackle coming from you think? Internally in the engine.
    specter208 likes this.
