Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 30, 2017 at 12:19 PM
    #5701
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Anyone getting this clanking on a third gen, or notice this slop in the rear diff?
    I also have this clank and play in the rear gearing. I get a clank over bumps out of gear and while in gear, and a light clunk when shifting into my lower gears.
    Dealer thought it was unusual and called Toyota who gave the standard normal response. I never buy that line after 2 new Toyota's I owned before this required major repairs ($3k+ each) to repair conditions Toyota told me were normal before they actually failed.
  2. Aug 31, 2017 at 10:03 AM
    #5702
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I get clanks too over speed bumps. Feels like something heavy hanging underneath the truck. I also get jerks when I shift from 1 to 2.
  3. Sep 1, 2017 at 6:36 AM
    #5703
    pra4sno
    I confirmed as have others that it is coming from a significant amount of slop in the rear diff. I believe we are seeing differentials that are not preloaded properly, or that weren't set up with the right lashing.
    I'm going back to Toyota within two weeks as this last service appointment was a total joke.
    Something I'm getting used to with them.
    specter208[QUOTED] likes this.
  4. Sep 1, 2017 at 8:43 PM
    #5704
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    I have a 2016 dcsb manual and a LG G5.
    I usually park in reverse with the hand brake engaged.
    Anybody have issues with their phone not hooking up to Bluetooth while starting their truck in reverse (backup camera comes up first) with the clutch pushed in? It seems to work fine while starting it up in neutral/gear with the clutch pushed in (startup/ok screen comes up first).
    It feels like the radio misses the opportunity to connect, when it is first powered on, but as soon as I take it out of reverse it goes to the startup/ok screen and still doesn't connect. I then turn my Bluetooth off and back on, on my phone, and it will then connect.
  5. Sep 1, 2017 at 8:43 PM
    #5705
    specter208
    California
    Does anyone know if it's bad to let weight of the truck sit on the transmission. I took the handbrake off on my angled driveway, felt the car roll back slightly and stop. I thought I was holding the brake but it was actually the clutch barely pressed and being held by 1st.
  6. Sep 1, 2017 at 8:44 PM
    #5706
    specter208
    California
    I've not had that issue.
  7. Sep 1, 2017 at 8:44 PM
    #5707
    Cazzwell
    Stock.
    How steep of an incline?
  8. Sep 1, 2017 at 8:45 PM
    #5708
    specter208
    California
    Between 15-25 degrees. I just remembered I had the wheel chocks set by hand too.
  9. Sep 1, 2017 at 8:58 PM
    #5709
    Cazzwell
    Stock.
    In the long run I would think anything over 20-25 would be extreme to not use the e brake (or chock the tires if your e brake is broke - like my old ranger was. I kept a stick in the truck to press the brake pedal long enough until I could get the blocks in place). I was also taught to put it in the gear opposite of gravity travel depending on which way was up (reverse if grille is down, 1st if grille is up) and/or to point the front tires into a curb.
    But if it only happened that one time, I think you'll be ok.
  10. Sep 1, 2017 at 9:08 PM
    #5710
    specter208
    California
    I edited my first post. It was actually more like 15-25 and I remembered that I had the wheel chocks set. When I tried to pull them, they were wedged under the tires so they may have kept some weight off the tranny. And I do set the parking brake first, then engine off, then 1st gear.
  11. Sep 2, 2017 at 12:39 AM
    #5711
    Clay
    Clay Well-Known Member
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    My wife hates Automatics too - (when we got married 37 years ago she was driving a Mustang with 4 on the floor) We presently have a 2010 Camry with a 6 Speed Manual (took us 4 months to get it) ...Now with only 39,000 on it - She has fallen in love with a 4Runner and is bummed that it only comes with an Automatic. Anyone want my Camry?
  12. Sep 2, 2017 at 10:12 AM
    #5712
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Wow I didn't know you could still get a Camry with a manual.
    BassAckwards likes this.
  13. Sep 2, 2017 at 10:13 AM
    #5713
    specter208
    California
    Not anymore for 2018. I have a cousin that works at a dealership and he says they will rerelease a manual for 2019 but don't take my word for it.
  14. Sep 2, 2017 at 10:59 AM
    #5714
    Clay
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    I believe that 2010 was the last year - Ours is an LE...They may have offered the SE's in a manual a bit longer. Problem is fewer people know how to drive them and the makers would probably like to not make two models of the same car. I know ours was part of a production run on manuals and was a special order. A lot of people are shocked when the see it. It's a 4cyl - Plenty of power and fantastic mileage. Will miss the mileage and the manual...Mama wants to sit higher - Looks like a 4R will soon be in the garage.
  15. Sep 2, 2017 at 11:25 AM
    #5715
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't see that happening.
    HeyNow likes this.
  16. Sep 2, 2017 at 9:47 PM
    #5716
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Con her into getting a taco, or just get her an Outback.
    specter208 likes this.
  17. Sep 3, 2017 at 10:18 AM
    #5717
    specter208
    California
    How strong do you guys think the drivetrain and engine components are on this truck. I consider myself a respectable shifter but like most of you know already, the 1 to 2 shift sucks sometimes. Was turning right at 9mph and shifted to second and the bumpy road caused me release the clutch a little fast and shook the truck up a little more than I would have liked. Since my truck is so new I like to baby it and it pisses me off when I mess up a shift occasionally.
    TeecoTaco likes this.
  18. Sep 3, 2017 at 1:48 PM
    #5718
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Lol Dood...shifting a manual tranny is like landing a plane. No one is ever around when ya grease it onto the Tarmac, but it seems like when ya flub it a little someone is always around to notice.
    I wouldn't sweat a ruff clutch release due to bumps as being hard on the drivetrain...have a little fun and use the no clutch to start button with it in gear and no clutch. Do it in an empty parking lot at first so you have time to react to the unknown if you haven't done such a thing before.
    worthywads likes this.
  19. Sep 3, 2017 at 2:21 PM
    #5719
    su.b.rat
    su.b.rat broken truck
    well, when they spec the parts for mass manufacture, they don't think about your kind. they think about the huge numbers of horrible drivers who won't learn anything and don't care ever, and the warranty that backs their vehicles. you are thinking too much about this. you'll be fine. oh, and lol.
  20. Sep 3, 2017 at 2:36 PM
    #5720
    specter208
    California
    Lol wut. Jk. But really. That clutch pop jerked the shit out of me and the truck.
