Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 3, 2017 at 2:40 PM
    #5721
    su.b.rat
    su.b.rat broken truck
    do you think no other Tacomas could survive this? think about what the worldwide population of Tacoma trucks has to deal with. I'm not taking about people on TW who think about their trucks when they first wake up, you know.
  2. Sep 3, 2017 at 2:42 PM
    #5722
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Well it wasn't the first time I've experienced what happened.
  3. Sep 3, 2017 at 2:45 PM
    #5723
    su.b.rat
    you should spend some time in a proper work truck for a day with someone who treats it like a work truck.
    that'll set you at ease about your Tacoma.
    btw, i baby the shit out of my truck. i do things like run full condensation cycles for long engine life. I'm neurotic, what can i say? but i don't lose sleep over my truck taking some hits. it's designed and built for way more than you're describing.
    TeecoTaco and specter208 like this.
  4. Sep 3, 2017 at 2:50 PM
    #5724
    specter208
    California
    Been in plenty of those actually. But i agree I overthink a lot. Thanks!
    su.b.rat[QUOTED] likes this.
  5. Sep 3, 2017 at 2:54 PM
    #5725
    su.b.rat
    just don't forget the warranty has your back, at least long enough to find manufacturing faults. i treat my stuff right with proper warmup, service, quality fluids, all that, but if you don't run her hard at times you'll not know what you've got and how well it works under load or stress. find out during your warranty period... just my 0.02, don't be afraid to run the machine
    just do it wisely.
    specter208 likes this.
  6. Sep 3, 2017 at 7:40 PM
    #5726
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    i am still struggling with shifting smoothly in this truck. I love everything about it but sometimes my shifts are good and a lot are not. Quite frequently get the clunk when switching gears. I have an 89 Toyota pickup that I shift smoothly all the time. I have close to 1000 miles on it so feel like I should be used to the clutch by now. I have been having good luck in the higher rpm range with shifting and then it's like I'm doing the same thing but get the clunks all the time. Is this due to the bit of slop I get if I'm under the truck in neutral and can move the shaft back and forth in the rear diff has about 1/4 inch of clearance either way. I don't want it to but it's starting to get on my nerves a little. I can't afford a OVtune after buying this truck. Thanks for any advice and anything that will soothe my concerns.
  7. Sep 3, 2017 at 7:41 PM
    #5727
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've just come to terms with the fact these trucks drive like dump trucks (at least both my second gens do). If I don't pay attention to it and just drive, it's usually smoother.
  8. Sep 3, 2017 at 8:03 PM
    #5728
    JARStacoma
    Alaska
    Yah. I feel like when I really start to try and make it smooth I have more issues. I just feel like if I'm constantly having clunky shifts how detrimental that would be in the long run. This is my first brand new vehicle. I have always bought used before and want to make this one last.
    EatSleepTacos and specter208 like this.
  9. Sep 3, 2017 at 8:29 PM
    #5729
    Razgriz1
    Razgriz1 Well-Known Member
    Southern California
    2017 Toyota Tacoma TRD Pro Cement 6MT
    I just give it some gas during shifting now. Really helps when you're not revving the engine super high and just putting around town. I know that's probably gonna cause extra wear on the clutch but without it I get clunks and having to wait for the RPMs to drop to the correct range is a pain in the ass.
  10. Sep 3, 2017 at 8:32 PM
    #5730
    JARStacoma
    Alaska
    Same experience her with applying more gas through clutch transition but curious about how detrimental this would be to the clutch.
  11. Sep 3, 2017 at 8:36 PM
    #5731
    specter208
    California
    my guess, perhaps 80,000 miles instead of 100,000.
  12. Sep 3, 2017 at 8:37 PM
    #5732
    specter208
    California
    I find if you clutch and release throttle together at the same time, the revs drop quicker. I've also noticed that if the AC is running, it helps drop the rpms quicker.
    Razgriz1[QUOTED] likes this.
  13. Sep 3, 2017 at 9:46 PM
    #5733
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have owned nothing but Manuals over the past 35 years and this truck is near the top for ease of use, the shifter is buttery smooth and l can shift gears with just my thumb and forefinger, except for Reverse which sometime refuses to go in.
    m603holden and nevadabugle[OP] like this.
  14. Sep 4, 2017 at 7:00 AM
    #5734
    JARStacoma
    Alaska
    I agree with the ease of the stick. I'm talking about the clutch engagement and adding of throttle being smooth transition instead I always get the clunk in the drivetrain and I am not new to manual shifting.
  15. Sep 4, 2017 at 9:53 AM
    #5735
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Is this your first manual transmission 4wd truck though? There is a lot more slop in the driveline. You can be off on a little sports car by a lot and no clunk. The trucks not so much. Same with my 2000 wrangler, if the shift is not close to perfect you will get a clunk/clank.
    You can try going a little slower through the transition point or pausing for a tad bit longer at it. While the Tacoma felt pretty tight, it was still noticeably a truck transmission.
    I also noticed the truck was a lot smoother shifting at higher RPMs. It did not like being shifted at lower RPM's (like around 2-2.5k). Clunk on clutch in (unless really slow), clunk on engagement, then no torque available.
  16. Sep 4, 2017 at 10:21 AM
    #5736
    shakerhood
    Southern Ohio
    I noticed the higher RPM too, if you take 1st gear to about 4 grand and shift very quickly to 2nd with very minimal loss of Revs it will move you along pretty good and be smooth, it's letting the Revs drop where there is no torque when it feels out of place.
  17. Sep 4, 2017 at 1:10 PM
    #5737
    su.b.rat
    when I'm getting on it this is how i go 1 -> 2.
    agree, and this makes it fully rewarding to get it right, at speed like mentioned above. one day soon i may go for a SS kit, but the long travel & tricky aim make it a fun challenge for driving this truck. i so love driving this thing.
    jayuu and shakerhood[QUOTED] like this.
  18. Sep 4, 2017 at 7:09 PM
    #5738
    JARStacoma
    Alaska
    This is all great to hear and makes me feel good about the Truck. I love it and will continue trying to master it. Thanks TW!
    shakerhood likes this.
  19. Sep 4, 2017 at 8:52 PM
    #5739
    F1nsfan
    F1nsfan Member
    Mark
    Exit 11 off the NJ Turnpike
    2016 MGM DC/SB/MT TRD Sport
    on my 6th toyota, first 3 were the lx, no tacomas back then. all, including my current 16, were manuals.
    nothing against auto, just prefer man. just hate switching to my wifes truck. almost hit the windshield throwing the non exsisting clutch down only to hit the breaks.
  20. Sep 4, 2017 at 8:56 PM
    #5740
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I love manual transmissions so much I flipped my manual taco just so I could rebuild it and convert a fully running and driving auto taco to manual. Just wanted to spread the love. But actually though I am doing all that more or less, just put my clutch MC in the auto shell...
