Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 9, 2017 at 11:40 AM
    #5781
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I try to avoid shifting into 1st while moving faster than 4mph. Shifter took about 1 sec to go in this time but Didn't grind or anything. Just want to protect the sychros as much as possible. I'm thinking about swapping to redline MT90.
  2. Sep 9, 2017 at 11:53 AM
    #5782
    eon_blue
    Azusa, CA
    MT90 is good stuff. Redline Shockproof gear oil is supposed to be even better, although more expensive
  3. Sep 9, 2017 at 12:02 PM
    #5783
    specter208
    California
    Awesome, trying to find a place locally that sells redline stuff!
    eon_blue[QUOTED] likes this.
  4. Sep 9, 2017 at 12:09 PM
    #5784
    eon_blue
    Azusa, CA
    Good luck, I tried too but no luck here in LA. I didn't look super hard but the main parts stores (Vatozone, Pep Boys, O'Reillys, etc.) didn't carry it. Had to order it online, found a good price on Amazon a year ago or so
  5. Sep 9, 2017 at 12:13 PM
    #5785
    specter208
    California
    I'll probably order and pick it up at Walmart. Truck is about to cross 4000 miles and I plan doing all maintenance myself.
    shakerhood likes this.
  6. Sep 9, 2017 at 12:18 PM
    #5786
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Thanks for this! It shows R as a shorter gear than first on my 5spd but it definitely doesn't feel like that... I understand the complaints from the 6MT guys on reverse now because it's even worse for them.
    This is also what I and everyone I know has also always done, with no issues. My Mom's Outback probably rolled backwards down the driveway in 1st 20 times lol, the parking brake was terrible. Never any damage or issues.
  7. Sep 9, 2017 at 12:22 PM
    #5787
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good Move! There was a story the other day where a lady dropped her Camaro off at the Dealer for an oil change and later she caught them using her car as they were at the drive thru buying food. She video the mechanics and the owner of the dealership said that is not how they usually operate, lol.
    specter208[QUOTED] likes this.
  8. Sep 9, 2017 at 12:23 PM
    #5788
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I just blip the throttle and get the RPMS up then it goes right in when shifting into first at higher speeds.
  9. Sep 9, 2017 at 1:14 PM
    #5789
    su.b.rat
    su.b.rat broken truck
    @specter208
    hey man, you can start moving in 2nd. many do this in snow & ice, or even a wet road going uphill. sometimes 1st is too low to control wheelspin.
    in fact, in Top Gear some years back, Clarkson made a point by starting off a Vette ZR1 (the 700hp or whatever it was) in 6th gear with a MT just to show how much torque it has. and the thing started moving and went all the way up to something like 180 in a single gear from a stop.
    one day you'll believe us... you'll be fine!
  10. Sep 9, 2017 at 1:16 PM
    #5790
    shakerhood
    Southern Ohio
    Starting off in 2nd in the bad snow was always how I could get going before I had 4wd.
    TeecoTaco and su.b.rat[QUOTED] like this.
  11. Sep 9, 2017 at 4:16 PM
    #5791
    specter208
    California
    I had someone suggest rev up to 2000+ rpm and slip the clutch In second gear if I'm still moving slightly but my muscle memory doesn't permit me to get the revs high enough to avoid growling the engine more than I would like to, the few times that I have tried. I'm just worried about the synchros of first gear.
    TeecoTaco likes this.
  12. Sep 9, 2017 at 4:36 PM
    #5792
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Only rev to what you have to to make a smooth transition to forward movement considering the conditions you're in. Might be 2K, might be more, might be less, the truck will let ya know what it needs. No sense in slipping the clutch with high rpm if you don't need to.
    As for the synchros...they'll let ya know if your doing it right. Finess not force wins the day...if she won't go in, work the throttle a couple hundred rpms and it'll find its way in.
  13. Sep 9, 2017 at 7:52 PM
    #5793
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    Learn to double-clutch and you'll drop right into 1st from 2nd. In ancient times without a synchro 1st gear, you had to do it. Now, it just makes the synchro's job a whole lot easier.
    cosmicfires and pinochle like this.
  14. Sep 10, 2017 at 8:28 AM
    #5794
    specter208
    California
    Is there a known software tune to reduce rev hang. Probably the only thing that annoys me about the truck. Waiting for the revs to drop to shift from 1 to 2 usually ends up with the truck slowing down significantly going up hill creating engine growl and potential lug situations.
  15. Sep 10, 2017 at 8:33 AM
    #5795
    shakerhood
    Southern Ohio
    Just shift and don't worry about waiting, on my 1 to 2 shift I try to shift quick to avoid loss in RPM's because of the lack of low end power.
  16. Sep 10, 2017 at 8:48 AM
    #5796
    specter208
    California
    What speed/RPMs you usually shift at. On flat ground I usually shift at 11-13mph which is about 2100-2400rpm. If going uphill I'll rev a little higher but sometimes the rev hang kills it and I'm back at 8-9 mph on a semi-steep hill.
  17. Sep 10, 2017 at 9:02 AM
    #5797
    shakerhood
    Southern Ohio
    Once my truck is warmed up I take 1st gear to around 4k and shift quickly into 2nd to try to keep the revs up.
  18. Sep 10, 2017 at 9:03 AM
    #5798
    specter208
    California
    Holy crap that's high RPMs. You get a clunk when you press the clutch pedal?
    shakerhood[QUOTED] likes this.
  19. Sep 10, 2017 at 9:05 AM
    #5799
    shakerhood
    Southern Ohio
    With the lack of low end in these trucks it seems like the 1 to 2 shift is the most important, no clunk or noises when shifting.
  20. Sep 10, 2017 at 9:16 AM
    #5800
    shakerhood
    Southern Ohio
    Just try to experiment with the truck until you find a combination that works for you. When I went from my 2000 Tacoma into my 08 I really noticed the Rev hang but after a few weeks I never even thought of it again and that was 3 Tacomas ago.
