Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 12, 2017 at 11:05 AM
    #5821
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Probably because you no longer have to drive with tunnel vision :rofl:
  2. Sep 12, 2017 at 11:06 AM
    #5822
    ak49watson
    ak49watson Cuts Right
    Alaska
    2017 Barcelona Red Tacoma TRDOR DCB 6MT Tech
    Yeah. I was used to it though. The way I adjusted my mirrors to see around the car drove my girlfriend nuts when she drove it. She's only ever driven trucks.
    The first time she drove my Tacoma, she butchered shifting too. Used to the Camaros quirks.
  3. Sep 12, 2017 at 11:57 AM
    #5823
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I adjusted mine Sunday. The e-brake holds much better now. Still doesn't hold well on very steep hills though.
    EatSleepTacos[QUOTED] likes this.
  4. Sep 12, 2017 at 11:58 AM
    #5824
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How exactly did you adjust it? Just tighten that nut to pull the line more taut?
  5. Sep 12, 2017 at 12:02 PM
    #5825
    replica9000
    2019 T4R ORP
    There are two 12mm nuts tightened to each other. Just release the e-brake, loosen the nuts, turn the inner nut to tighten the slack in the cable, then tighten the outer nut against the inner nut.
  6. Sep 12, 2017 at 12:03 PM
    #5826
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dang, that really is super easy. How did you know how tight to go? Or just trial and error.
  7. Sep 12, 2017 at 12:05 PM
    #5827
    replica9000
    2019 T4R ORP
    I'm not sure if there's supposed to be any slack in the cable at all, so I tightened it till there was very little with the brake disengaged.
  8. Sep 12, 2017 at 12:05 PM
    #5828
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks for reporting back. I'll knock this out this week.
  9. Sep 12, 2017 at 12:06 PM
    #5829
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the Toyota Spec for tightness was by counting the number of clicks.
  10. Sep 12, 2017 at 12:07 PM
    #5830
    eon_blue
    Azusa, CA
    12-18 clicks on a 1st gen, not sure if it's the same for you guys. If I get to around 15 clicks the brake feels really loose and doesn't hold well.
    shakerhood likes this.
  11. Sep 12, 2017 at 12:08 PM
    #5831
    replica9000
    2019 T4R ORP
    I had the same number of clicks before and after, about 15.
  12. Sep 12, 2017 at 1:20 PM
    #5832
    su.b.rat
    su.b.rat broken truck
    where is this on the truck, please?
  13. Sep 12, 2017 at 1:28 PM
    #5833
    replica9000
    2019 T4R ORP
    Under the cupholders, on the manual tacos.
    su.b.rat[QUOTED] likes this.
  14. Sep 12, 2017 at 3:07 PM
    #5834
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    5-7 clicks pulling at 44 lb Ft.
  15. Sep 12, 2017 at 4:07 PM
    #5835
    replica9000
    2019 T4R ORP
    Before I adjusted the cable, only the last several clicks had any real tension on them. After adjustment, same amount of clicks, but tension starts right away.
    I had replaced the very worn shoes several months ago, didn't help the e-brake much at all.
  16. Sep 12, 2017 at 5:19 PM
    #5836
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Hello MT folks! This is my first Automatic Toyota truck and I've had many over the years. My last Tacoma, a 2006 TRD OR. AC was MT and to be honest, I thought it was weak. It was when pulling away with a heavy load, if I gave it lots of gas, the transmission would slip and I'd have to ride the clutch to accelerate. Of course it's possible the clutch needed replacing but it was only in that situation it would slip. Has anyone else have the same problem? My new truck with the 5 speed auto has no problem breaking traction with lots of tongue load. What are your thoughts on this?
  17. Sep 12, 2017 at 5:21 PM
    #5837
    will_smith
    will_smith Well-Known Member
    Rob
    San Diego, CA
    2017 OR MT
    For those that have trailers, how do you work with engine braking? The reason I ask is, I was going down a 8% hill in 2nd gear and reached around 45mph and 4k RPM without a trailer. Is this normal? It seemed unusually high from my 2nd gen tacoma I used to own.
    edit: 6 speed 2017
  18. Sep 12, 2017 at 5:32 PM
    #5838
    su.b.rat
    this topic is being discussed here and there in the Orange Virus ECU tune thread. there's no clear solution yet if this is what you're describing... it's related to ECU controlled fuel cutoff, and it's causing problems like this.
  19. Sep 13, 2017 at 8:53 AM
    #5839
    spiderpig
    spiderpig Member
    TRDOR
    Anybody know how to reset the TPMS on our trucks? (3rd gen '16 OR) Our reset button is under the steering wheel and NOT in the glove compartment. I had one tire i put a spare on and now all four don't register.
  20. Sep 13, 2017 at 9:21 AM
    #5840
    shakerhood
    Southern Ohio
    The Spare does not have a Sensor in it.
