Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 19, 2017 at 4:58 PM
    #5921
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    su.b.rat[QUOTED] likes this.
  2. Sep 20, 2017 at 11:50 AM
    #5922
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Was reading a little on a thread about stumble misfire issues with manuals. I had some dead spots when I would accelerate quickly in 2nd but as I have added miles seems to have mostly gone away. Does are a lot of you with manuals experiencing this problem a lot or does it just seem like a few.
  3. Sep 20, 2017 at 12:06 PM
    #5923
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Haven't experienced anything like a misfire myself.
  4. Sep 20, 2017 at 12:19 PM
    #5924
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I've felt something, but I assumed it was the stepped cam timing changes and injection transitions. There are noticeable low RPM flat spots and then bumps later in the RPM band. Its laughable that it ever got out of the ECU tuning lab at Toyota with this power delivery.
    Those with mis-fires.....are you somehow monitoring or datalogging these?
  5. Sep 20, 2017 at 12:33 PM
    #5925
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Its kind of a weird stumble, not sure if misfire would be the correct term.
  6. Sep 20, 2017 at 1:24 PM
    #5926
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Totally random, but do you guys fire up your truck and let it warm up for a minute or two? Or do you guys just fire and go?
  7. Sep 20, 2017 at 1:31 PM
    #5927
    specter208
    California
    In the mornings I crank up and go back into my house for 2-3 mins to comb my hair and grab my remaining things before going to work. I generally wait for the idle to drop to its lowest RPM which is 600-700 before before driving off slowly to finish warm up.
  8. Sep 20, 2017 at 1:33 PM
    #5928
    specter208
    California
    I remember once I floored it in 3rd going maybe 25mph and the truck accelerated slowly then jerked and took off suddenly.
  9. Sep 20, 2017 at 2:55 PM
    #5929
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    For me, above 50° outside, I fire and go. Usually in winter I let it the engine get to 120° (where the needles touches the bottom line). Tranny tends to shift smoother with a warmer engine.
    shakerhood likes this.
  10. Sep 20, 2017 at 4:09 PM
    #5930
    tspencerVA
    tspencerVA Well-Known Member
    Roanoke, VA
    2017 TRD OR DCSB
    TRD Pro Grill, ARE CX HD shell, step bars, Wet Okole, Husky Liners
    Feels almost like the A/C compressor is kicking on/off?
    Been assuming that is just the way the Atkinson cycle feels but not sure now. Was looking over the throttle position sensor threads for leads also.
    shakerhood[QUOTED] likes this.
  11. Sep 20, 2017 at 8:00 PM
    #5931
    JARStacoma
    Alaska
    I let it run for a few minutes if I can.
  12. Sep 20, 2017 at 8:05 PM
    #5932
    Razgriz1
    Razgriz1 Well-Known Member
    Southern California
    2017 Toyota Tacoma TRD Pro Cement 6MT
    You don't need to wait for the engine to warm up, just don't mash on it from a completely cold start.
    The oil actually gets up to temp faster if you use the engine instead of letting it idle for several minutes.
    Idling and waiting for it to warm up is inefficient, both time and gas wise. :burnrubber:
    Stopmithering and Hoop21 like this.
  13. Sep 20, 2017 at 8:09 PM
    #5933
    blksandpearl2010
    blksandpearl2010 Yeah, yeah...
    NC
    2010 LB trdSport
    old man emu, nitrocharger shocks, darkar leaf springs, bbs wheels, access tonneau cover, laufen AT 275/65/18,
    Wish I had a manual in my DCLB, only if Toyota only if....
    :pout:
  14. Sep 20, 2017 at 9:38 PM
    #5934
    shakerhood
    Southern Ohio
    Pretty much same here, fire and go. Winter I let it run while I am scraping the windows and clearing snow off of it.
  15. Sep 20, 2017 at 11:34 PM
    #5935
    jtmiller2011
    I live in Phoenix, don’t really have that problem. I drive about 6 minutes before I hit the freeway and crank around 75mph for the next 14. By the time I even get to the freeway the temps are halfway between hot and cold.
  16. Sep 21, 2017 at 5:15 AM
    #5936
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I have the stumble at around 2000 RPM under load. I have not verified by logging, but I have no doubt that it is misfires. It's just not enough of them to trigger a cell.
  17. Sep 21, 2017 at 10:14 AM
    #5937
    shakerhood
    Southern Ohio
    I think it's in the OV Tune Thread where the guy put up what looked like a fuel map for our Tacoma and compared it to something else like a Mazda or something. The other vehicle was a very smooth map while the Tacoma was jagged with peaks and valleys all over the place which would obviously explain the dead spot or stumbles.
  18. Sep 21, 2017 at 11:41 AM
    #5938
    asperry
    asperry Member
    Have always driven manual transmission Tacomas. A 1990, 1998, currently have a 2009. Ordered a cement 2017 TRD Pro with MT in February of this year and was told by my dealer the other day that I won't get it due to allocations and no more orders being taken for the 2017 model year. I'll see what's available for 2018. I wish Toyota would increase the number of Tacomas manufactured with the manual transmission option.
    shakerhood and specter208 like this.
  19. Sep 21, 2017 at 11:55 AM
    #5939
    specter208
    California
    You can order the 2018 but won't get a cement model. You can order the regular OR model and ask for it to be in Cement with the 6MT.
  20. Sep 21, 2017 at 12:14 PM
    #5940
    Razgriz1
    Southern California
    I had this happen to me when I was shopping for mine, luckily I had deposits with 2 different dealers and one came through. There might be some Cement MTs still unsold in lots around the country, should check it out.
