Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 29, 2017 at 11:13 AM
    #6081
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Correct. I was making a joke about the truck driving up the wall...
  2. Sep 29, 2017 at 11:14 AM
    #6082
    su.b.rat
    su.b.rat broken truck
    yeah without throttle modulation like in the at's.
    specter208[QUOTED] likes this.
  3. Sep 29, 2017 at 1:02 PM
    #6083
    asperry
    asperry Member
    No swapping out of the dealer's region - apparently Oregon and Texas are in different regions. However, I'm heading to Oregon in mid October to pick up this truck. My local dealer, from whom I've purchased 6 Toyotas was unable get one despite my order and deposit being in the works since February. I'm looking forward to a little 1300 mile journey home with it.
    Stopmithering and tonered like this.
  4. Sep 29, 2017 at 1:19 PM
    #6084
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    It's amazing. The FlyFoot technology with grippy/sticky hairs that come out of the tires are mind boggling. ;p
    TBV[QUOTED] and cosmicfires like this.
  5. Sep 29, 2017 at 1:42 PM
    #6085
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Make sure you vary your RPMs along the way for the 1st 500 miles to properly break in your engine. Avoid cruise control as well.
  6. Sep 29, 2017 at 1:44 PM
    #6086
    asperry
    asperry Member
    Will do - thanks for the reminder.
  7. Sep 30, 2017 at 9:09 AM
    #6087
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Finally secured my shift boot down with a 3/4 grommet from Home Depot. I bought an extra in case I botched the surgery on the first one; fortunately all went well.
    Someone PM me if they want the extra one for free!
    OA
  8. Oct 2, 2017 at 4:47 AM
    #6088
    specter208
    California
    Hi friends, would a double clutch downshift require me to shift into gear at exactly the correct RPMs or can I shift as soon as I blip the throttle and RPMs are above the desired target rpm.
    pinochle likes this.
  9. Oct 2, 2017 at 10:58 AM
    #6089
    Explosively
    Explosively Well-Known Member
    Rob
    The closer you are to the correct rpm the better it is for your syncros. You're already double clutching to (I assume) save wear so might as well go as close as possible.
    But no you don't have to be at the precise rpm when shifting back in, just keep learning and getting as close as you can. Consider this - you can shift into neutral while moving now and then shift into another gear without issue no? That's all double clutching is, it's not something special just because you're doing it quickly.
  10. Oct 2, 2017 at 4:29 PM
    #6090
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Wait, is it bad to hold the clutch in as you're downshifting? I don't release in neutral and depress again.
  11. Oct 2, 2017 at 4:32 PM
    #6091
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    You're fine.
  12. Oct 2, 2017 at 4:33 PM
    #6092
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    You must release the clutch in neutral before you blip the throttle, then depress it again. This is where the term "double clutching" comes from.
  13. Oct 2, 2017 at 4:35 PM
    #6093
    jtmiller2011
    Okay, I was taught to just depress, go into neutral, blip throttle, back into lower gear. release clutch.
  14. Oct 2, 2017 at 4:36 PM
    #6094
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    No
  15. Oct 2, 2017 at 4:40 PM
    #6095
    TeecoTaco
    SW Ontario
    jtmiller2011[QUOTED] likes this.
  16. Oct 2, 2017 at 4:53 PM
    #6096
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Guy swapped me a TRD short throw shifter complete with TRD shift ball a couple of weeks ago and loving it so far. I had been told they were a little more difficult to get into reverse but this one is actually easier than the stock shifter was
    johnnyblender and IndyZen like this.
  17. Oct 2, 2017 at 7:19 PM
    #6097
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    This is how I do it. Many claim you need to double clutch but I have never seen the need on my Tacomas. Now on my 1970 pick up I have to double clutch or it is hard to get it into the gear.
    Casper66 and IndyZen like this.
  18. Oct 2, 2017 at 7:42 PM
    #6098
    TBV
    Oakland CA
    2017 TRDOR 6MT
    Never double clutched ever.:confused:
    Casper66 likes this.
  19. Oct 2, 2017 at 7:49 PM
    #6099
    nevadabugle
    Elko, NV
    Not in my Toyotas...can some one explain why this is supposedly bad? If I depress the clutch go into neutral, blip the throttle, it falls into the next lower gear with zero pressure applied to the shifter. Then let out the clutch and there is zero jerking or reving of the motor. This make a super nice and smooth downshift. How is this bad?
  20. Oct 2, 2017 at 7:52 PM
    #6100
    nevadabugle
    Elko, NV
    And for clarification the depress clutch, hit neutral, blip the thorttle and down shift is one fluid movement. My post above makes it sound like I do one, then the next then the next...the whole process takes less than a second.
