Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Oct 2, 2017 at 7:54 PM
    #6101
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Wait? I think I may have misunderstood your emoji...maybe you were saying YOU have never double clutched. In that case disregard my initial quoting of your post....
    Man the internet is hard...
    Casper66 likes this.
  2. Oct 2, 2017 at 8:07 PM
    #6102
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Yeah, sorry. I've never double clutched. No issues either. A bit confused why folks still do.
  3. Oct 2, 2017 at 8:14 PM
    #6103
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Yeah me too. That's why synchros were invented.
    Stopmithering and IndyZen like this.
  4. Oct 2, 2017 at 8:43 PM
    #6104
    Explosively
    Explosively Well-Known Member
    Rob
    Yeah with the clutch depressed you can blip it whenever, that's the point of the clutch. Sometimes I'll sit in the lower gear with the clutch still in if I misjudged my deceleration and blip it when it's time to release.
    As others said double clutching where you release in neutral and blip there (as opposed to "granny shifting" which is what you're describing) is only truly necessary in unsyncronized trannys, like tractor trailers. Some people do it in cars as for serious racers it gives a bit more stability to the shifting (which probably won't be a concern in Tacoma's), to prevent wear on the syncros (which in a modern transmission should last a lot longer than other components assuming you're not constantly forcing the gears in), or probably mainly because that's what they're used to or what they find more enjoyable.
  5. Oct 3, 2017 at 7:16 AM
    #6105
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    What you're doing is just rev matching. Or "blipping".
    When you double clutch, you...
    Depress the clutch and put the shifter in neutral
    Release the clutch and blip the throttle
    Depress the clutch and shift into lower gear
    Release the clutch.
    The point of double clutching over just blipping is that you actually spool up the shafts in the transmission to alleviate the amount that the synchros need to work. Think of it this way. Let's say you're in fifth gear and you're decelerating. If you want to skip a gear and go into third, it's more work for your third gear synchros to speed up your shafts to allow third gear to mesh. If you double clutch it, your gears are already up to speed so the shifter will mesh immediately.
    This is something you can test out on the highway. When you're cruising at speed in fifth or sixth gear, try downshifting to third or fourth (whichever is two gears down from the gear you're in). Without the double clutch, you'll feel resistance going into the lower gear. If you double clutch it will go right into gear because the synchros no longer have to do as much work.
  6. Oct 3, 2017 at 7:17 AM
    #6106
    pinochle
    NNJ
    What he said. :)
  7. Oct 3, 2017 at 8:03 AM
    #6107
    AlbanyTaco
    AlbanyTaco Member
    2017 TRD off road mt
    LED all around
    Tried that route...too much damage.
    Now I have a new tacoma...still was a great car
    pinochle[QUOTED] likes this.
  8. Oct 3, 2017 at 10:19 AM
    #6108
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Thanks for that. I will try it on the freeway. I usually rev match down from 6th to 2nd. I still have yet to get to first smoothly from second. It's hard on this truck unless I'm going 8mph in 2nd and go into first. But I have noticed from 6th to 4th I have to rev to around 3500 rpm at 65 mph when I'm rev matching. I'm assuming you do the same when you put it in neutral and blip to get into 4th, yes?
  9. Oct 3, 2017 at 10:26 AM
    #6109
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Don't over think it. If the transmission snicks smoothly into gear, then that is just fine. My syncros broke in after the first couple hundred miles. All gears are smooth, even skipping on downshifts (like low RPMs in 6th to 3rd).
    If you can't feel the clutch take up in your butt when engaging / disengaging the clutch, then that is just fine.
    Otherwise, if you feel that you are forcing the shifter or the truck is bucking around with your clutch work, then work on that. Get it all good at cruising RPMs then play around at the upper rev range.
    2nd to 1st at slow speeds is the hardest shift. Only do that if you have to, like stop-n-go traffic. For normal driving and stops, slow down in 2nd, clutch in to stop, and shift to first to pull away.
    Edit: When it is all good, you should be able to pull away at the speed of other cars and pretty much keep up with them while shifting. Not forcing anything and being nearly as smooth as a slushbox.
  10. Oct 3, 2017 at 11:36 AM
    #6110
    Explosively
    Rob
    Yup! Just make sure to let the clutch out beforehand or it does nothing haha.
    Also I don't bother going into 1st when coming to a stop in any of my vehicles. First is a takeoff gear, not a stopping gear. I dunno if others disagree but I say just stay in second right up to when the engine would lug then go to neutral. You'll likely be going less than 5 mph by then anyway.
  11. Oct 3, 2017 at 11:42 AM
    #6111
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I use the gears and clutch to slow down. Every gear lift up on clutch slowly and the truck damn near stops it self. Hardly any brakes.
  12. Oct 3, 2017 at 11:42 AM
    #6112
    jtmiller2011
    Thanks guys, I appreciate it.
    that's what I've been doing. I just didn't know if you should go down into first. Damn TW makes you overthink when you read what others post haha.
  13. Oct 3, 2017 at 11:47 AM
    #6113
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Here's a question I was thinking of the other day while passing a slow driver in a 55mph area. What's you favorite gear? (not neccesarily 1st cause you need to it start going, or 5/6th cause it's need to cruise at high speeds.) I'll reword it as, what gear is the most fun or enjoyable for you?
    Mine is 3rd gear (I have 5 gears and a 2.7L first gen). I like it because I can accelerate by using it any where from 25-70 mph which makes me feel like I have a race car within those few seconds. Of course then I shift into 4th and lose most of my pull because of the 33s and steel wheels on a little engine and no regear.
    BillyToy, cosmicfires and Braves95 like this.
  14. Oct 3, 2017 at 11:50 AM
    #6114
    Braves95
    David
    Central PA
    I have 6. And I go in this order to start off. 1st, 2nd, 3rd, 4th, 6th. Slow down 6th, 4th, 2nd, 1st. All lifting clutch till I feel it's not slowing and just a little braking.
  15. Oct 3, 2017 at 11:52 AM
    #6115
    HSmith_11
    Hunter
    Madison, Va
    I just love manuals. Especially when a non-manual driver freaks out that I'm coming up to a red light or stop sign yet not slamming on the brake. I guess they don't understand the mechanics of using the gears to save your breaks.
    specter208 and Braves95[QUOTED] like this.
  16. Oct 3, 2017 at 11:54 AM
    #6116
    jtmiller2011
    that's my favorite. I make it a mission to try not to use the brake. I think 4th is my favorite gear. I can slow down on the freeway with it and I can fly with it.
    Braves95 likes this.
  17. Oct 3, 2017 at 12:17 PM
    #6117
    specter208
    California
    I hate coming up to red lights and have them turn green right as I'm about to stop.
  18. Oct 3, 2017 at 12:21 PM
    #6118
    specter208
    California
    I've heard that technique is hard on the transmission, not to mention clutch.
  19. Oct 3, 2017 at 12:31 PM
    #6119
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    As above, if you are not feeling it, the truck isn't.
    Put it this way, in an extreme example, what is harder on the engine / transmission: full throttle 1st gear to redline or smoothly dropping it into 1st near redline and letting it engine brake? We can do the first one, a lot, without problems and the weight is shifted to the rear wheels. The second, it is just the engine compression loading the transmission and the weight has shifted toward the front.
    I am not saying to do this, just something to think about.
    Also, I've heard it several times that moderate engine braking early on helps the piston rings seat. Just an important as varying the cruising RPMs in the early days.
  20. Oct 3, 2017 at 12:50 PM
    #6120
    specter208
    California
    Maybe you can answer another question of mine. Occasionally when making turns and shifting to second I'll overshoot the correct rpm for my speed and upon engaging the clutch will make the engine growl and force the RPMs down. Is this harmful in anyway to the engine.
