Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Nov 11, 2017 at 6:39 PM
    #6541
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Interesting... The OEM tune was driving me nuts by the time OV came on the scene. It's possible though, that Toyota could have straightened some stuff out in later versions (so far there are only three that I'm aware of).
  2. Nov 11, 2017 at 6:58 PM
    #6542
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I don't know if Toyota has made any changes between the 16' and 17's regarding tunes. I do know what you are referring to, and I definitely felt it on a few of the manual trucks I test drove in 2016 and even the 2017s. However, when I mentioned it to the last salesman I was with when I felt the hesitation off bottom, he reminded me that this motor has the torque higher up in the rpms and to get the rpms up over 2.5 k before letting out the clutch. I started doing that in that test drive and the hesitation was reversed enough that it was borderline snappy, which I like. With the wireless throttle pedal/TB connection, we get some rev hang there. So, in my seat of the pants feeling dyno I would recommend just giving the throttle a nice tap to get the revs up to at least 2.5k before you let out the clutch. I've driven mine this way since day one, and it wants to go, and go now.
    When I let my wife drive it for the first time she stalled, stumbled on the second try and did fine on the next 4 or 5 starts. She's a really good manual driver and said it was weird. Then we both figured out that she was doing 3rd gear starts. She didn't pull the lever over far enough to get in line with 1st. After that, she was all good.
    tonered and MOC221_[QUOTED] like this.
  3. Nov 11, 2017 at 7:01 PM
    #6543
    MOC221_
    Frank
    I'm glad it worked out for you man, and oh.. your poor poor clutch with those 3rd gear starts!
    INSAYN[QUOTED] likes this.
  4. Nov 11, 2017 at 7:13 PM
    #6544
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    She didn't even smoke it.
    You should have smelled the clutch on my gen 1 roughly two weeks old after trying to climb a steep sand hill off the beach. Back in 1996/1997 winter, the Oregon coast got a nasty storm that took 15-20 feet of beach away leaving a huge wall that used to be a hill. Over the summer, some brave souls worked on pushing sand down in a few areas at Sand Lake, creating ramps essentially. Stupid me, I felt obligated to drive down and play on the beach. Tide was coming in while we were down there, and really needed to get back up very soon. In my attempt, I had it in 4Lo 3rd gear and gave it a run. Once at the top, I had a situation.... a big clump of Ammophila beach grass was in my way, and had to go left or right really quickly. In doing so, I lost a lot of my momentum and had to slip the clutch and keep moving forward without killing the motor, as there was no way I was going to be able to down shift to 2nd in time. Stopping and restarting wasn't going to happen. Backing down from where I currently was positioned wasn't going to happend (20' drop off directly behind me now). Smoked the living crap out of the clutch to the point it stunk for days.
    Oddly enough that same damn clutch can still spin rubber through second gear on the pavement, and chirp 3rd with 20 years of driving, towing and 218k miles accumulated on it. Go figure?
    Maybe I seasoned it? :burnrubber:
    jtmiller2011 and MOC221_[QUOTED] like this.
  5. Nov 11, 2017 at 7:18 PM
    #6545
    MOC221_
    Frank
    Yep, you definitely did lol!
    tonered likes this.
  6. Nov 11, 2017 at 7:50 PM
    #6546
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah that weird stumble/hesitation is very odd but only pops up here and there.
    Spare Parts[QUOTED] likes this.
  7. Nov 11, 2017 at 8:09 PM
    #6547
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    It is possible the stumble you feel is when the motor switches between the port and the direct fuel injection systems. I don't know exactly which is used when and what it looks for to switch between the two. Be it load, rpm, moon phase? It's in there somewhere.
  8. Nov 11, 2017 at 8:31 PM
    #6548
    shakerhood
    Southern Ohio
    No idea, you will probably experience it at some point too, I think it took a couple thousand miles before it happened the first time on mine.
  9. Nov 14, 2017 at 7:21 AM
    #6549
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Has anyone else's shift boot gotten "creaky" when it rubs against itself?
    I've always conditioned it with Meguiar's but never had this happen until recently. Maybe because it's 8 years old now. Does anyone have an aftermarket boot that they like?
  10. Nov 14, 2017 at 7:34 AM
    #6550
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    TACK...YOU CACK!!!!
    TACK[QUOTED] likes this.
  11. Nov 14, 2017 at 7:39 AM
    #6551
    TACK
    Nevada
    Haha, finally someone gets it!
    stun gun[QUOTED] likes this.
  12. Nov 15, 2017 at 1:23 PM
    #6552
    offthewallsurfer
    offthewallsurfer Well-Known Member
    Anybody that has the TRD PRO shift knob can vouch for it? How do you like it? Worth the money? Thanks in advance.
  13. Nov 15, 2017 at 1:42 PM
    #6553
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    @shakerhood does
  14. Nov 15, 2017 at 1:48 PM
    #6554
    shakerhood
    Southern Ohio
    I like the Pro Knob alone in looks over that weird Double Ball looking Stock Shift Knob. I got mine around Christmas time and it was like $15 off so it was worth it, maybe a similar deal will pop up again this year.
  15. Nov 15, 2017 at 2:56 PM
    #6555
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The ball style that came on the 2nd gens? Love it and well worth it.
  16. Nov 15, 2017 at 3:00 PM
    #6556
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
  17. Nov 15, 2017 at 3:01 PM
    #6557
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Omar RVA[QUOTED] likes this.
  18. Nov 15, 2017 at 6:17 PM
    #6558
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    :drunk:just because I can on a Wednesday night....carryon.
  19. Nov 15, 2017 at 8:42 PM
    #6559
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    You know, I thought it was weird and blocky at first, but now I really like it. It's a good handful unlike my TRD shift knob on my sandrail that I feel I'm supposed to grip between my thumb and index finger, it's so small. I really like the little lip on the front of it. I like to shift from 3rd to 4th with a little throw from my index and middle finger looped over the top and into the lip.
    Looks wise, I think it's a bit Frankenstein's monster honestly with all the different little pieces of plastic and "chrome" plastic boot keeper and mostly hidden stitching, but hey...cool monster.
  20. Nov 15, 2017 at 8:50 PM
    #6560
    BillyToy
    PNW
    Yep, nailed it.
    I backed a trailer up a hill with mine on the first day (after 500 miles of break-in). Stunk it up badly. I think all the flashing on that clutch from the factory should be taken care of now. Clutch is nice and broken in. :burnrubber::bananadead:
    I switched to 4Lo after that and it worked great, though speed was obviously limited. I'm sure one doesn't want to use 4Lo on pavement too much, but this was on gravel.
    Anyone with transmission knowledge know if backing up in 4Lo on rare occasions with a trailer on hard pavement is going to cause drivetrain problems in the long run? (for me it would be once or twice a year I bet at most and probably less than 15-20 feet). Maybe better to just burn a little clutch for those times.
