Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Nov 28, 2017 at 11:11 AM
    #6661
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hate to add confusion, but the 2007 Taco that I test drove didn't have the pattern on the knob. Since there are threads and Toyota is smart about production, I would like to think that they are the same threads.
    Of course, none of that probably really helps anyone.
  2. Nov 28, 2017 at 11:14 AM
    #6662
    su.b.rat
    su.b.rat broken truck
    i got mine and the owner was pretty helpful about it. i know those reviews, so i emailed him first to see if they are up and running and a little discussion about the piece... we got a little email dialog going and i got my knob a bit later. you can also look at Anarchy Motive for knobs like that. i have 2 knobs from each, Flossy & AM.
    MOC221_ likes this.
  3. Nov 28, 2017 at 11:43 AM
    #6663
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Good to know that some have had positive experiences. I've looked at a lot of options for shift knobs, and I keep coming back to the Flossy Grip Tape Shorty I posted above. I may just have to give it a whirl and pray for a quick turnaround. As a side note, do you (or anyone else) have any experience with Flossy's shift boot retainer? I know there's always the Home Depot grommet option, but this just looks a little cleaner.
    https://www.shopflossy.com/collections/accessories/products/flossy-boot-retainer?variant=277224242
  4. Nov 28, 2017 at 12:45 PM
    #6664
    su.b.rat
    i haven't tried that myself. looks ok to try, but you'll still need something to hold it all together.
  5. Nov 28, 2017 at 1:06 PM
    #6665
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Do you have a link to that 8ball? I want to do that to mine!
  6. Nov 29, 2017 at 8:50 AM
    #6666
    CrashN'Burn
    CrashN'Burn I used to have a life
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    Do the MT have a higher gear ratio for 1st gear than the AT? I've noticed that I have to switch over to 4lo earlier than some of the AT guys I wheel with.
    Braves95 likes this.
  7. Nov 29, 2017 at 9:08 AM
    #6667
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Here you go! https://www.hotrodshiftknob.com/8-ball-classic-black-shift-knob/
    Mine's the 2-1/4". I like the size, but it's not for everyone. It's the size of an actual pool ball. You will want to make sure and order it with the 12mm x 1.25 thread reducer as well.
    As for the grommet.... I got on at the hardware store for like $.87 - just need to make sure the inside diameter fits your shaft :anonymous:
  8. Nov 29, 2017 at 9:54 AM
    #6668
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No:
    But, the torque convert lets the driveline slip where the clutch is a solid lock. When the A/T goes into full lock in 1st gear, the M/T will be moving slower at the same RPM.
    So to going slow under load in 4hi, the A/T will be heating up the ATF where you are running cool in 4lo.
    Willbeck and CrashN'Burn[QUOTED] like this.
  9. Nov 29, 2017 at 11:11 AM
    #6669
    jtmiller2011
    You're killer m8. Do you remember the grommet size you got? I am a 3rd gen
  10. Nov 29, 2017 at 11:33 AM
    #6670
    CrashN'Burn
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    had to re-read to make sure I understood.... do I have this right?
    So in my example an A/T with similar setup (weight/tires etc) to my M/T will be able to make it up an incline in 4H where I have to switch over to 4LO to avoid stalling. This is because the A/T torque converter allows the drive line to slip whereas the M/T does not slip (unless you're burning your clutch)
  11. Nov 29, 2017 at 12:01 PM
    #6671
    su.b.rat
    iirc that's a 3/4" grommet... someone correct me if I'm not remembering right.
  12. Nov 29, 2017 at 12:04 PM
    #6672
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. The TC is adding more gear reduction at the expense of wasted energy / heat. Think of it this way, the A/T in gear at a stop is holding back the motor at idle (about 600rpm or so). You feel that drag by having to keep your foot on the brake. That is where A/Ts make life somewhat simpler at the expense of control.
    In the end, you have a lot of speed range in 4lo. 1st gear at idle is slow as walking pace and 6th is pretty freaking fast considering. My only complaint is that I'd like to be able to drop in and out of 4lo at a speed higher than 2mph. Even then, the system doesn't cooperate. Stopping to switch in and out is more reliable.
    Gimme that twin stick!
    jtmiller2011 likes this.
  13. Nov 29, 2017 at 12:10 PM
    #6673
    jtmiller2011
    I would kill to have a twin stick and lockers where you get out of the truck and turn the lockers.
  14. Nov 29, 2017 at 12:11 PM
    #6674
    CrashN'Burn
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    Miss the twin stick, my '91 had one.
    yeah the only real issue I have is the auto LSD doesn't work in 4LO, so if I get crossed up on a hill climb I loose all power to the wheels.
    tonered[QUOTED] likes this.
  15. Nov 29, 2017 at 12:28 PM
    #6675
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah, manual hubs would be freaking nice considering the lack of a gizmo'ed 2lo. The front is actuated inside the clamshell, so that isn't even possible. Hopefully some day, someone can make a module like the one that Up2NoGood created for the 2nd Gens.
    At least there is a solution for that. I have my sights set on an ARB locker at some point.
  16. Nov 29, 2017 at 1:22 PM
    #6676
    CrashN'Burn
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    Same same
  17. Nov 29, 2017 at 4:06 PM
    #6677
    Reluctanse
    Sam
    Newberg, Oregon
    Sounds right... I'll see about slapping my calipers on there tonight when I get home.
    IIRC I bought a misc pack of different sizes and just used the one that fit. Again just a few $$..
    TeecoTaco likes this.
  18. Nov 29, 2017 at 4:40 PM
    #6678
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    CrashN'Burn likes this.
  19. Nov 29, 2017 at 4:54 PM
    #6679
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Sigh, I hope you're right because I really want the Grip Rod Heavy. Damn, those reviews are horrendous.
  20. Nov 29, 2017 at 4:59 PM
    #6680
    su.b.rat
    don't think that's a problem unless you're looking for one. be kind and not an entitled a-hole and you'll get your piece. he's aware of those reviews btw... that was the ice breaker when i asked him about it.
    TeecoTaco and MOC221_[QUOTED] like this.
