Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 8, 2017 at 10:00 PM
    #6741
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    Tons of pages here in this thread, quite a few posts, so I searched Sticky Shifter and found 4 posts, and of course references to the TSB for fixing this. Anyone done this TSB themselves? I firmly believe that you don't need to spend money for parts on this, you can modify your existing Pin and reinstall if you have a grinder and are interested. The dimensions of the upgraded/new part number pin are all identical to each other, the difference is only that there is a flat side ground down the pin itself which prevents hydrolocking of the pin in its bore. I put a lot more info and pictures in this thread.
    https://www.tacomaworld.com/threads...medy-tsb-0088-16-for-rc62f-6-speed-mt.522894/
    I've always had manual transmissions, I've rebuilt a ton of them as well, but none of the 6 speed Toyota series. Maybe the above thread could come in handy to this manual transmission fan club thread.
  2. Dec 9, 2017 at 7:50 AM
    #6742
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I think I've been more limited by my lack of armor, than not having a locker.
    This was myself and a few others in a recent run up a steep and rocky hill. Only one of the trucks was an Off-road, one SR5, and the rest sport models.
    https://youtu.be/h0IlpbbLgrc
  3. Dec 9, 2017 at 9:09 AM
    #6743
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Depends how serious you plan on wheeling. I don't have a locker, but would really like one to push my truck even harder. With that being said I've still taken my truck over some pretty tough stuff and I have wide open diffs. No LSD or anything.
    jtmiller2011 likes this.
  4. Dec 9, 2017 at 10:54 AM
    #6744
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thank you, sir!
  5. Dec 9, 2017 at 11:09 AM
    #6745
    MOC221_
    Frank
    Yep, 6 M/T means waaay more than any of that other stuff. I've used my locker a few times when off road, but not even sure if I really needed to (which probably means I didn't). It did make a difference when I hauled a car out of a snowbank once, but I mean.. how often does that happen?
    The suspension I guess would be the only one to really consider between the two, and only if you never plan on lifting your truck later and changing it out anyway. The OR is a softer, more compliant ride - which also means worse handling on the street.
    As for stock skid "plates" - lol, they are pretty damned thin and don't cover much (except for the pro). Most ppl who off road throw them away and buy real armor.
    I believe you get the bigger/beefier 8.75" ring gear in either locked or non-locked rear axles, so long as you're also M/T. So that's a wash.
    To sum up, M/T > the needz of anything else!!
  6. Dec 9, 2017 at 11:46 AM
    #6746
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Didn't look like there was much air down done one any of the trucks in the video. A good drop in air pressure would reduce the amount of wheel spin that causes trail damage.
  7. Dec 9, 2017 at 12:22 PM
    #6747
    replica9000
    2019 T4R ORP
    I can't speak for the others. I was at 18psi
  8. Dec 9, 2017 at 1:28 PM
    #6748
    THASHREDDA
    THASHREDDA Active Member
    Black 2017 TRD off road dblcb Tacoma
    I too would love to hear thoughts on this.. I'm considering the gear change.
  9. Dec 9, 2017 at 1:36 PM
    #6749
    ParkCity_Marty
    ParkCity_Marty Member
    2008 TRD Sport MT
    Great Vid. I covet the wheelbase of the standard cab in this vid. Mine is an extended cab cause at 6'2", I need to throw that seat back a little. Also, my Sport is a MT and as was stated above "...the MT really enhances the driving experience of this vehicle...all around."
    tonered and TeecoTaco like this.
  10. Dec 9, 2017 at 1:39 PM
    #6750
    replica9000
    2019 T4R ORP
    Mine is also MT. I'm 6'5". I haven't sat in a regular cab, so I'm not sure how much room I'd have. I find GM and Toyotas provide more interior room than other brands.
  11. Dec 9, 2017 at 1:47 PM
    #6751
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    Well ive been mislead dealer told me the 2017 had ORDCSB Mt6.
    You can still build one on toyota.ca but only in 2017 and sport model is shown but who knows if the site is right.
    MOC221_[QUOTED] likes this.
  12. Dec 9, 2017 at 5:20 PM
    #6752
    MOC221_
    Frank
    I think your dealer just may be full of it. I've never seen a DCSB OR M/T and as you've said, only the Sport/Pro are shown on the Toyota Canada website.
    Wedge[QUOTED] likes this.
  13. Dec 9, 2017 at 5:33 PM
    #6753
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Yup, as far as I'm aware, AC OR MT is only chance...dunno about 18 MY
  14. Dec 9, 2017 at 5:53 PM
    #6754
    Wedge
    Yves
    Kebekistan
    17 OR DCSB MGM
    You guys are right, no ORDC in canada ever for the 3rd gen. Im calling them monday. I guess ill try to source one ORDC MT in the US.
  15. Dec 9, 2017 at 5:57 PM
    #6755
    MOC221_
    Frank
    Yep:
    Notice also that the 4cyl M/T is missing from the list, as was predicted.
  16. Dec 9, 2017 at 6:28 PM
    #6756
    Wedge
    Yves
    Kebekistan
    17 OR DCSB MGM
    Sad times ahead for the manuals.
    Clay likes this.
  17. Dec 9, 2017 at 6:37 PM
    #6757
    TeecoTaco
    SW Ontario
    Indeed...grab what you can...
    shakerhood and TheSalvageMind like this.
  18. Dec 9, 2017 at 6:46 PM
    #6758
    Clay
    Clay Well-Known Member
    Clay/K7CR
    Auburn, Wa
    2016 7559 Tacoma
    My '16 Sport is now 2 years old and 40,000 miles. I was very disappointed when I ordered mine that I could not get the Locker - My choice boiled down to - Locker with AT, or no-Locker with an MT. At that point the decision was easy to make. As for suspension components...(This is my 5th Toyota PU) history has demonstrated that the factory shocks, struts etc will be failing before I get to 100K Miles. I figured that when that time comes, is when I will upgrade those items. I did that with my 2001 - Spent a bundle with ARB and the present owner has had to do nothing in the next 125K. Bottom line is that you can always add better under the frame components than you can get from the factory and it will be money better spent. If you are not in a hurry to beef it up, get your money out of the stock stuff first - My $.02- Clay
    tonered, Bigfsur and Wedge like this.
  19. Dec 10, 2017 at 11:20 AM
    #6759
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    That's what I'm interested in doing as well. I've been in contact with a dealer in Michigan for pricing and learning about the import process.
    I much prefer the look of the OR model plus the locking diff compared to the SPT even though the SPT has the MT. Bringing over an OR MT pretty much covers all bases.
  20. Dec 10, 2017 at 11:27 AM
    #6760
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    So driving home from hunting today got me thinking about a complaint I’ve read about the 3rd gen manuals here. Specifically, when descending a hill in low gear and the engine braking cuts out.
    Since I was already in 4WD (snow covered forest service road) I decided on the big hill I have to go down to put it in 4lo, 1st gear and see what happens.
    It went down the hill at idle speed ~750 rpm, without me touching the fat pedal at all. No loss of engine braking at all, and while nothing extreme it’s a pretty steep incline.
    Is this a 4cyl vs 6cyl thing?
