Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jan 4, 2018 at 4:37 PM
    #7041
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Nope, you're not wrong. My 85 4Runner was same as your 93 w.r.t gear floating. But then again I had an 81 Plymouth TC3 I never used the clutch beyond initial role...both vehicles I had to figure out due to catastrophic failures (t4r clutch exploded far from home, TC3 clutch cable broke)
    The newer gens dont seem as content to show us the sweet spot...couple tips to help ferret them out. Try for awhile to disengage gear without clutch on deceleration, work the throttle gently to find the RPM range where is pops out smoothly...thats the butter spot. Get that down pat first while clutching to upshift. Then when youre confy with the out of gear rpms sans clutch, work the ipshift to same rpm range but only halfcluch it, find the sweet spot. Soon after that, you'll find yourself clutching less and less.
    The fly by wire skinny pedal doesn't help the cause here either on this truck...a cable does what you want it to, a wire does what it thinks you want it to do.
    Lemme know how it works out
    shakerhood likes this.
  2. Jan 4, 2018 at 4:44 PM
    #7042
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    So the clutch isn't strictly necessary? That's fascinating.
    TeecoTaco[QUOTED] likes this.
  3. Jan 4, 2018 at 4:55 PM
    #7043
    TeecoTaco
    SW Ontario
  4. Jan 4, 2018 at 5:04 PM
    #7044
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    The 08 is not your grandpa's truck. Use the clutch like a normal driver.
  5. Jan 4, 2018 at 9:29 PM
    #7045
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Nice! That 4Runner sport hood can't be original though, how's the fit?
  6. Jan 5, 2018 at 5:35 AM
    #7046
    thdrduck
    thdrduck Well-Known Member
    Um... when driving a dump truck or semi no clutch between gears, when driving a car or pickup just use the clutch. It's really cool how the gears won't grind that way. A synchronized transmission will be difficult to shift without a clutch by design.
  7. Jan 5, 2018 at 6:49 AM
    #7047
    Biker88
    Biker88 Well-Known Member
    Len
    NYC
    '18 Off Road manual.
    Wondering how many of you guys are using Remote Starters?
    I've always have in every vehicle(manual or auto)...Since im the only driver no big deal, anybody using it?
  8. Jan 5, 2018 at 8:46 AM
    #7048
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Nope. Haven't understood the purpose of remote starters?
    Haven't had a carbureted motor for years, and no need to warm up these fuel injected motors prior to driving (shy of double digits negative temps).
    What's the purpose of a remote starter?
  9. Jan 5, 2018 at 9:42 AM
    #7049
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    I’ve got one. Very nice to warm up or cool off truck. Being in NC I use it to get the A/C going on hot summer days more than winter warm ups.
  10. Jan 5, 2018 at 9:43 AM
    #7050
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Comfort. Warm up or cool off vehicle before you get in and drive.
    Biker88 likes this.
  11. Jan 5, 2018 at 10:01 AM
    #7051
    Biker88
    Len
    NYC
    Exactly...warm up the truck for a bit and get comfortable....
  12. Jan 5, 2018 at 1:40 PM
    #7052
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I don't have a lot of experience shifting without the clutch. Doesn't seem difficult though. Upshifting is obviously easier. The shifter will tell you when you can't or can't shift. It should glide in relatively smooth when it's ready.
  13. Jan 5, 2018 at 3:34 PM
    #7053
    harlequin_forest
    harlequin_forest Well-Known Member
    Oregon
    TRD OR 6MT , 2.0 SFOB
    What remote starter do you have for the MT?
  14. Jan 5, 2018 at 4:50 PM
    #7054
    su.b.rat
    su.b.rat broken truck
    me walking my ass out in the cold
  15. Jan 5, 2018 at 6:24 PM
    #7055
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    Anyone else notice the shifter making a sticky vibrating sound while driving in the cold? It doesn’t happen while shifting just when cruising and the stick is doing its normal jiggle. It takes at least 45 min to go away and occurs in temps as warm as the mid-40s.
  16. Jan 5, 2018 at 6:30 PM
    #7056
    specter208
    California
    Haven't noticed anything on mine. Could be the plastic trim around the boot.
  17. Jan 5, 2018 at 6:52 PM
    #7057
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Not noticed anything on mine, and it was about 2°F out today.
  18. Jan 5, 2018 at 7:08 PM
    #7058
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Had the 08 for about a month n it only does that if i dont warm the truck up. Have not seen anything above 30 since i had it. N the 93 always did itbwhen temps are below 0.
  19. Jan 5, 2018 at 8:55 PM
    #7059
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Fortin Evo One.
    BigHam likes this.
  20. Jan 6, 2018 at 6:59 AM
    #7060
    BigHam
    BigHam dɹǝp
    How hard was it to install?
