Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Feb 9, 2018 at 9:26 AM
    #7241
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Old trucks and manual hubs ftmfw! :woot:
  2. Feb 9, 2018 at 9:28 AM
    #7242
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    +1. I wish it could have been that way.
    I tried to find a 1st or 2nd Gen before buying the 2017. It is great that they hold their value, but it was more than I could pull the trigger on.
    jtmiller2011 likes this.
  3. Feb 9, 2018 at 9:35 AM
    #7243
    kyle11863
    Kyle
    Big Bear, CA
    Yeah its crazy. Been trying to get a few friends into them and their tone completely changes when they see the prices
    I know the first gens can, but can the 2nd gens get manual hubs?
    tonered[QUOTED] likes this.
  4. Feb 9, 2018 at 9:40 AM
    #7244
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At least, it's great to know these things will run forever. I don't plan on parting with mine now that I finally have one.
    No. For the 2nd and 3rd Gens, the actuator is in the front diff not the hubs.
  5. Feb 9, 2018 at 10:55 AM
    #7245
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I have the 3.5 with tow package, 6,400 lbs.
    shakerhood[QUOTED] likes this.
  6. Feb 9, 2018 at 10:58 AM
    #7246
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Gotcha, that makes a lot more sense as you quoted a 4 cylinder post on the previous one.
  7. Feb 9, 2018 at 12:19 PM
    #7247
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Happy to join the club :canada::burnrubber:
    venezian, TBV, TeecoTaco and 2 others like this.
  8. Feb 9, 2018 at 12:21 PM
    #7248
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice!
    Did you trade in the 2nd Gen? Probably hard to leave it behind?
  9. Feb 9, 2018 at 12:21 PM
    #7249
    kyle11863
    Kyle
    Big Bear, CA
    Right? My 90 has 262k, 96 has 315k and the camry has 257k. They never die.
    That's what I thought but wasn't sure since you mentioned lookig at 2nd gens. I don't know about 1st gens but I know with some last gen pickups and 2nd gen 4runners the actuator is in the diffs but the hubs were the same so you could still install manual hubs if you desired
  10. Feb 9, 2018 at 12:29 PM
    #7250
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Welcome buddy...the ying to my yang!
    Norilsk[QUOTED] likes this.
  11. Feb 9, 2018 at 12:30 PM
    #7251
    Norilsk
    Eugene
    I did, me and this truck went thru a lot of deep mud (literally) & the stories I have... But after moving from 05 to a 15 I got tired of the same interior comforts.
    Time to take this little truck on the trails as soon as I get a chance. :burnrubber:
    tonered[QUOTED] and wytwich like this.
  12. Feb 9, 2018 at 12:31 PM
    #7252
    Norilsk
    Eugene
    Thanks!
    We got to meet sometime later this month, compare things and teach me to shift better since you know this truck already well enough. :thumbsup:
    TeecoTaco[QUOTED] likes this.
  13. Feb 10, 2018 at 7:12 AM
    #7253
    New York Bozo
    New York Bozo Member
    Yes, the first and reverse gearing are about the only things I can't stand about my truck. I really don't know what they were thinking with those gear ratios. Was trying to back up a tandem-axle enclosed U-haul trailer and I burnt my clutch for the first time ever. I could barely make it work.
  14. Feb 10, 2018 at 8:18 AM
    #7254
    Beemaster
    Beemaster Well-Known Member
    Stanley
    California
    2016 Silver Tacoma TRD Sport 4x4 6MT
    I did the same thing backing up my boat last Fall. If I don’t get more efficient backing up my boat and trailer, I’ll burn out the clutch by this Summer’s end. I’ve never destroyed a clutch by burning it out. How much can a clutch take before it needs to be replaced? Anyone burn out a clutch beyond repair?
  15. Feb 10, 2018 at 8:30 AM
    #7255
    shakerhood
    Southern Ohio
    I think in really, really old cars that didn' make enough power to climb steep hills the driver would back up the hill because Reverse was the steepest gear.
  16. Feb 10, 2018 at 10:33 AM
    #7256
    thdrduck
    thdrduck Well-Known Member
    If you smoke your clutch you also smoke your pressure plate and flywheel. Standard procedure is to replace the clutch plate, pressure plate and throw out bearing and have the flywheel turned. Usually failure to do any of the above results in "clutch chatter" and a redo. PS... if you smoke a clutch you were doing something you should not have been doing. If you need to fry your clutch to back a trailer, don't back the trailer.
  17. Feb 10, 2018 at 12:32 PM
    #7257
    Explosively
    Explosively Well-Known Member
    Rob
    Haven't heard that but I could see it being true. You might be thinking of the Model T which used gravity fed fuel, but the tank was behind the engine so going forward up a steep hill no fuel would drip into the engine.
  18. Feb 10, 2018 at 12:35 PM
    #7258
    su.b.rat
    su.b.rat broken truck
    i remember being in the back seat with my dad reversing up a hill in ATX. a POS Malibu company car that couldn't go. he took a running start at that hill in reverse every time. lots o drama. like 1973 maybe.
  19. Feb 10, 2018 at 3:08 PM
    #7259
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Drivers backed Model Ts up hills because the gas tank was behind the engine and gravity feed. So it could go up a steeper hill in reverse than forward because it didn't get gas going forward.
  20. Feb 10, 2018 at 3:30 PM
    #7260
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    And while you are in there, may as well replace the transmission input shaft pilot bearing there in the crankshaft.
    thdrduck[QUOTED] and MOC221_ like this.
