Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Mar 16, 2018 at 5:10 AM
    #7541
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Two words: Crawl box.
    Hell, my truck made it up Killington with a welder and full tooling setup. Haha
  2. Mar 16, 2018 at 6:44 AM
    #7542
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are you talking about the air dam? It is just held on with screws in nut clips. If you are catching it on stuff, even snow, it be good to remove it. It will do damage if it gets torn loose.
    Mine is off, but I will put it on for any long road trips.
    shakerhood likes this.
  3. Mar 16, 2018 at 8:33 AM
    #7543
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Is there a noticeable difference in mpg with it on?
    tonered[QUOTED] likes this.
  4. Mar 16, 2018 at 8:37 AM
    #7544
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I took mine off with less than 1k on the odo, so I can't say for sure. My MPGs increased a bit during break in and have leveled off at just shy of 20mpg average (probably 70-30 city/highyway split in this hilly area).
    Other folks say that it either doesn't change at all and others say that it is good for 1 or 2 MPG.
    It is an easy experiment to try.
    I put the screws back in the nutclips so that I didn't loose any.
  5. Mar 16, 2018 at 12:02 PM
    #7545
    Isotopic
    Isotopic New Member
    San Francisco bay area
    2017 Tacoma TRD 4x4 Sport gunpowder gray, access cab
    None to date.
    Purchased my 2017 Taco access cab this past August. I had hoped for a six speed but the Toyota dealer here in Palo Alto said that ~95% of truck purchases are for automatics in the area. My test drive ended up being in a Taco with an automatic transmission. I found that at highway speed the shifting patterns are unpredictable if not erratic which convinced me to wait for a six speed rather than the impulse purchase the day of the test drive. Having owned three other Toyota 4x4 (1992, 1996, 2000) pickups I can say with a degree of personal assuredness that the shifting on my 2017 is by far the smoothest of all of them. I'm really pleased with my choice. An aside here... I think that my 2017 is the first one I can think of where the estimated mpg was actually less than the automatic versions. Any input?
    TeecoTaco, shakerhood and tonered like this.
  6. Mar 16, 2018 at 12:09 PM
    #7546
    eon_blue
    Azusa, CA
    My Scion had less estimated MPGs than it's automatic counterpart. These days, automatics are first and foremost designed with efficiency in mind, gone are the days of when manuals dominated in the MPG arena. Automatics are almost always quicker off the line nowadays too, whereas it used to be if you had a manual you would be faster. Autos have come a long way.
    However, one thing an auto will never have over a manual is the number of smiles per gallon...a manual always has and always will win in that department.
    Plus I think it's easier for them to measure MPGs with more precision with autos...with manuals it really depends on who is driving it.
    specter208, TeecoTaco and tonered like this.
  7. Mar 16, 2018 at 12:09 PM
    #7547
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good on you for holding out.
    The MPG difference is due to gearing:
    Even with a 4.88 gear swap, the AT is still higher than the MT.
    That said, I can hit the EPA numbers with an MT. In an AT, they are goals, not destinations.
    For the minor difference at the pump (if any in real life), gimme joy behind the wheel.
  8. Mar 16, 2018 at 5:09 PM
    #7548
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Ok I believe I've seen it posted in here before. Which one of you has figured out the best way to eliminate the creek in the clutch? There has to be a specific lube point. It's heard, so far, mainly when letting off in first gear or reverse
  9. Mar 16, 2018 at 5:15 PM
    #7549
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Use Disc Brake Grease on all the pivot points and it will cure the old barn door creak.
    su.b.rat and Casper66[QUOTED] like this.
  10. Mar 16, 2018 at 5:16 PM
    #7550
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    You mean like the CRC red spray anti squeak lube? Thanks BTW
  11. Mar 16, 2018 at 5:19 PM
    #7551
    shakerhood
    Southern Ohio
    No, grab some Disc Brake Grease, it is a high temp grease that will stay where you put it.
  12. Mar 16, 2018 at 5:20 PM
    #7552
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    :thumbsup: Thanks again
    shakerhood[QUOTED] likes this.
  13. Mar 16, 2018 at 5:23 PM
    #7553
    shakerhood
    Southern Ohio
    AutoZone has little packets of it so you don't need to buy a container, i also find that the long wooden Q-Tips help in reaching all the pivot points.
    Casper66 likes this.
  14. Mar 16, 2018 at 5:28 PM
    #7554
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I may have some in one of the tool boxes if not I'll swing by and pick some up. I got stuck in traffic for a 2hr commute home this evening and it got annoying
  15. Mar 16, 2018 at 6:13 PM
    #7555
    su.b.rat
    su.b.rat broken truck
    get some latex or nitrile gloves and get the grease fully inside the coil.
    Casper66 and shakerhood[QUOTED] like this.
  16. Mar 16, 2018 at 7:54 PM
    #7556
    skiscience
    skiscience Member
    Erik
    Just picked up my 2018 OR MT last week. Now in Moab. Still have my off-road training wheels on but have already driven stuff that would have cracked my old Subaru in half. Thanks for all the info TWers, helped me seal the deal. 8D00236C-00F0-48BF-957B-99D3A1A466F1.jpg
  17. Mar 16, 2018 at 7:55 PM
    #7557
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Congrats good lookin truck!
    skiscience[QUOTED] likes this.
  18. Mar 16, 2018 at 8:07 PM
    #7558
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Manual all the way. I dont know how to drive automatic LOL
    tonered, Beemaster, pinochle and 3 others like this.
  19. Mar 17, 2018 at 12:37 AM
    #7559
    JARStacoma
    Alaska
    Love the softopper!
  20. Mar 17, 2018 at 9:58 AM
    #7560
    BlackWagon
    BlackWagon Well-Known Member
    Ronju
    South East PA
    2018 Black TRD Off Road DCSB MT
    Just here waiting for my TRD Off Road DCSB 6 speed MT to come in, had to place an order, automatic wasn't even an option. Lol
    ChronicTaco and shakerhood like this.
