Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 11, 2018 at 2:15 PM
    #8041
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Our saab was hard to get into 1st at a stop. Folks, including me, tried three different factory fluids until it was found that Redline nailed it.
    There are folks here that have used amsoil in the transmission. I've only used OEM fluids or Redline now and in the past. Redline has always exceeded my expectations and made slick shifts out of what were notchy boxes. I never felt that about the 2nd or 3rd Gens that I drove, but there was a bit of room for improvement.
    Yeah. It is dead simple to swap fluid:
    https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/
    It is just a good forearm workout with all the pumping.
    SpaceTrim[QUOTED] likes this.
  2. May 11, 2018 at 2:28 PM
    #8042
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    If you're moving around in 2nd at 4mph you are damaging your engine. The engine is making almost no power aNd oil pressure is very low at those RPMs.
  3. May 11, 2018 at 2:32 PM
    #8043
    SpaceTrim
    SpaceTrim Well-Known Member
    SD
    1998, 2011, 2015, 2018 Tacoma DCSB OR MT
    Stays at or above 1k rpm and it's not growling or stuttering but I'll take your word on it. Thanks for the heads up
  4. May 11, 2018 at 2:37 PM
    #8044
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, I disagree. Parking lot speeds / stop-n-go traffic in 2nd gear is just fine. It seems as long as the tach is around 1k, the motor feels happy, even in higher gears.
    Now, if I want to actually accelerate, 1,500rpm or above.
    SpaceTrim likes this.
  5. May 11, 2018 at 2:41 PM
    #8045
    specter208
    California
    Can't be true, 1000 rpm is 10.6 mph in 2nd gear. My 2017 growls at 8mph in 2nd on level ground. You wrote that you can drive smooth at 4mph Which from my experience is not true. my Truck feels very unresponsive at that speed and gear.
  6. May 11, 2018 at 3:20 PM
    #8046
    SpaceTrim
    SD
    Sorry I lied... i dont ever use the digital speedo. Still doesn't shutter and doesn't growl unless I go even slower. It is very low rpm so I probably won't keep doing this.
    tonered and specter208[QUOTED] like this.
  7. May 12, 2018 at 12:31 AM
    #8047
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Well the new master fixed it. The clutch feels better than before.
    Installing the master was very crappy. I needed to actually unhook the hard and soft line so the whole clutch assembly could be removed. There's two bolts that are very hard to get to and needed the lower dash taken apart and fuse box moved.
    New master:
    Dash taken apart:
    Old master:
  8. May 14, 2018 at 7:08 AM
    #8048
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It sounds like life is good in the end.
    Happy shifting!
    deeezy[QUOTED] likes this.
  9. May 15, 2018 at 7:10 PM
    #8049
    SpaceTrim
    SD
    Added 15% all the way around and 50% on windshield and did a faux pro grill to see if I'll like it more than my grater. Also used chemical guys clean slate and put on some fresh polish and wax to replace factory. Not sure what's next? Sliders? Skids?
    shakerhood likes this.
  10. May 16, 2018 at 5:44 PM
    #8050
    TheoNVtaco
    TheoNVtaco Well-Known Member
    Theo
    Lake Tahoe
    2016 black DC TRD OR manual
    3" lift with total chaos UCA King coil over bypass in front King bypass shocks in rear All pro expedition leaf springs Extended break lines 4ARE Z series shell Prinsu Roof rack on cab an shell Truck vault drawer system (waterproof) Relentless fabrication custom front bumper Relentless rear high clearance bumper with swing out tire career. Relentless sliders Baja design pro fog lights Scs custom 16" wheels 5 discovery stt pro 33" tires
    Manual is defiantly the only way to go and let’s be honest, real men drive manuals. I get to bored in an automatic F9F2CB1F-FA6D-4B9C-98E0-87BCF81CD344.jpg
    24-7 likes this.
  11. May 16, 2018 at 5:52 PM
    #8051
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I approve this message ^ :thumbsup:
    02Duck, 24-7, tonered and 5 others like this.
  12. May 16, 2018 at 6:00 PM
    #8052
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Where you get that?...why dinnit you order two lol
    shakerhood and Norilsk[QUOTED] like this.
  13. May 16, 2018 at 6:04 PM
    #8053
    Norilsk
    Eugene
    shakerhood and TeecoTaco[QUOTED] like this.
  14. May 16, 2018 at 6:04 PM
    #8054
    TeecoTaco
    SW Ontario
  15. May 16, 2018 at 6:07 PM
    #8055
    Norilsk
    Eugene
    :rain:
  16. May 16, 2018 at 7:00 PM
    #8056
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Truly, a fate worse than death.
    Norilsk and TeecoTaco[QUOTED] like this.
  17. May 16, 2018 at 7:02 PM
    #8057
    TeecoTaco
    SW Ontario
    He had it coming
  18. May 16, 2018 at 7:04 PM
    #8058
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    You get your magical Titanium shift knob yet?
  19. May 16, 2018 at 7:07 PM
    #8059
    TeecoTaco
    SW Ontario
    No man, need to get a few more peeps before it can be pulled off...mayhaps we should advertise titanium plate instructions?
  20. May 16, 2018 at 7:09 PM
    #8060
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    How many more does he need? I'm down for one if you only need a few more.
