Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jun 13, 2018 at 11:05 AM
    #8161
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Same with our trucks, no clutch required
  2. Jun 13, 2018 at 11:12 AM
    #8162
    Explosively
    Explosively Well-Known Member
    Rob
    Yeah I've tried to heel toe the Tacoma and... sheesh it's not useful haha. Especially with the lag (I don't have the OVTune yet).
  3. Jun 13, 2018 at 11:19 AM
    #8163
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    specter208 likes this.
  4. Jun 13, 2018 at 7:52 PM
    #8164
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Check this guy out, 1 Arm and still having fun racing with a Manual!
  5. Jun 13, 2018 at 8:12 PM
    #8165
    JEE
    JEE Well-Known Member
    2016 Tacoma SR Access 4x4 2.7L 5-speed
    Intermittent wipers, cruise control, receiver hitch.
    San Antonio. :hattip:
  6. Jun 14, 2018 at 12:51 AM
    #8166
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    I have a MPG question. I just switched from 265/75/16 ko2 e load, to 265/75/16 Falken wildpeak at3w passenger. I was getting about 18 mpg with the bfg’s and thought I would increase a bit with the falkens coming in at almost a full 10 lbs apiece lighter. I am maybe getting .5 mpg more? I am a little disappointed but the ride quality is better for sure. I really liked the ko2’s but just thought they were overkill. Also the same day I purchased the tires I went in for a 10000 mike service and told them not to worry about rotating n as I just purchased the tires. Could they be out of balance? Allighnment issue causing mpg loss. I’m not sure but think I should be seeing better gains over the e rated tire.
  7. Jun 14, 2018 at 6:52 AM
    #8167
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    I'm one of those! Not only is it unnecessary, it's tough to heel and toe on the street. You don't need to blip the throttle either. If you're downshifting just give it a little more gas so the gears mesh easily on re-engagement. People like to call that "rev-matching." In my book, it's how you always drive a stick. Upshifting or downshifting it's just part of the situation that some people seem to have "re-discovered."
    Now about heel and toe. The Tacoma isn't really very good for it - it's a truck. I have a GT350 and even it isn't great - on the street. On a track, heel and toe works because you're hitting the brakes hard at the same time you want to downshift. That takes three feet if you don't heel and toe. It's easy since your foot is applied hard on the brake giving a firm position from which to hit the gas at the same time. You're also pushing the brake pedal down farther so the gas is easy to reach. Again, heel and toe is best suited for aggressive braking and downshifting; on a track. Try it with light braking force in a Tacoma and I bet you'll have a hard time learning how to do it.
    In your Tacoma, if you're trying to get from 2nd to 1st without stopping the truck, you'll find your synchos will do the job but it will feel like you're forcing things. When you feel that, think about it. You're wearing your synchros. The way to downshift easily is an old technique from non-synchro (dinosaur) transmission days. Double clutching. Google it, but in a nutshell, you push in the clutch, shift to neutral, let out the clutch, blip the throttle, then push in the clutch and shift to 1st. Done properly, the shifter pops right into 1st. This works because your using the engine to speed up the transmission counter shaft rather than making your synchros do the work.
    specter208 and tonered like this.
  8. Jun 14, 2018 at 9:05 AM
    #8168
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I find many times I'll slide into 1st gear when I do it at exactly 3mph.
  9. Jun 14, 2018 at 11:24 AM
    #8169
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Like blondes, manuals are much more fun (going the speed limit) 4th to 5th and 5th to 6th are awesome which I cannot demonstrate while obeying the speed limit law in the video.
    https://youtu.be/izyXTwSfEZM
  10. Jun 14, 2018 at 1:40 PM
    #8170
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    @Grossomotto, ok so couple questions...i just watched your video...1. were you on a relatively smooth paved road? 2. does your truck jump everytime you change gears or just when your race truckin?...... nice truck by the way
  11. Jun 14, 2018 at 1:57 PM
    #8171
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Looks like it's because he's racing it.
  12. Jun 14, 2018 at 2:00 PM
    #8172
    Grossomotto
    2017 4WDV6LB6MT
    Pretty much, the stock sport suspension is bouncy for me, even off road, I’m changing to stiffer everything at some point. You have the same truck. Yes all paved smooth road.
    I’m certain bigger tires with a lift would move more on and off road.
  13. Jun 14, 2018 at 2:04 PM
    #8173
    Grossomotto
    2017 4WDV6LB6MT
    Toyota put a high rev 3.5L engine, it’s what I have to do. I’m not afraid to drive the shit out of my vehicles (within the speed limits) especially in the 60k powertrain warranty.
    Jckdnls and tonered like this.
  14. Jun 14, 2018 at 4:02 PM
    #8174
    su.b.rat
    su.b.rat broken truck
    mine jumps like that at gear shifts too if I'm on it
  15. Jun 14, 2018 at 4:28 PM
    #8175
    TeecoTaco
    SW Ontario
    Had yours north of 5500 rpms? Its what it does...dont worry, it can handle it
  16. Jun 15, 2018 at 6:20 AM
    #8176
    ArmandHammer83
    Raymond
    Alabama
    none yet
    :rofl::burnrubber: shit yeah....only a couple times.... mine does it too is why i was asking didn't know if you figured out how to smooth it out was all..
    TeecoTaco[QUOTED] likes this.
  17. Jun 15, 2018 at 9:38 AM
    #8177
    su.b.rat
    broken foot. manual transmission.
    fvck. [​IMG]
    shakerhood likes this.
  18. Jun 15, 2018 at 9:40 AM
    #8178
    Explosively
    Rob
    Good thing the third gens have a light clutch! Lol. Is your foot in a cast? Probably just gonna be a leg workout to use it.
    su.b.rat[QUOTED] likes this.
  19. Jun 15, 2018 at 9:41 AM
    #8179
    su.b.rat
    getting it sorted as we speak. not sure if I'll be driving soon or not yet.
  20. Jun 15, 2018 at 9:44 AM
    #8180
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    You need a walking cast!
