Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 12, 2018 at 5:52 PM
    #8321
    Beemaster
    Beemaster Well-Known Member
    Stanley
    California
    2016 Silver Tacoma TRD Sport 4x4 6MT
    Well, it could be a subtle test. If she CAN drive your truck, she might be a KEEPER!
  2. Jul 12, 2018 at 5:54 PM
    #8322
    Nunya Bizness
    That is a solid point my friend. I guess I should just drop the few and start the search! Take it easy guys, I'm off to search the mall parking lot for a 10 that can not only handle stick... but stick in a Tacoma! :)
    Beemaster[QUOTED] and tonered like this.
  3. Jul 12, 2018 at 6:27 PM
    #8323
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I married my wife for four reasons..
    1. She was a traditional bowhunter...
    2. She was better looking than a guy like me could hope for.
    3. Her truck was a manual. Albeit a Ford at the time.
    4. She could handle a stick well...this is very different than number 3...
    The Ford part almost ruined the deal, but we have been a 100% Toyota family ever since we got married
    mtip, Nunya Bizness, pinochle and 3 others like this.
  4. Jul 12, 2018 at 6:45 PM
    #8324
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Search the off road area and skip the mall, otherwise you're going to have to compete with the money between "shopping" and "modding". :ballchain:
  5. Jul 12, 2018 at 6:56 PM
    #8325
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
  6. Jul 12, 2018 at 8:32 PM
    #8326
    Nunya Bizness
    Glad to hear you two were able to work through such a travesty... Very fortunate that she was able to get help to get past her problems... always good to hear a happy ending.
    Where I'm from its 99% Ford junkies... just lining the street... I am trying to open up a rehab... cuz this is so sad :/
  7. Jul 12, 2018 at 9:21 PM
    #8327
    SpaceTrim
    SpaceTrim Well-Known Member
    SD
    1998, 2011, 2015, 2018 Tacoma DCSB OR MT
    I'm sorry, what is sans clutch and floating gears? Is that shifting without the clutch? If so, why would it be an issue?
  8. Jul 12, 2018 at 9:24 PM
    #8328
    Nunya Bizness
    Every clutch feels a little bit different (even in two identical vehicles) possible he was operating on muscle memory and that caused it. Never know.
  9. Jul 12, 2018 at 9:28 PM
    #8329
    Nunya Bizness
    I do it from 5th to 6th if I am not accelerating very quickly. In my opinion it is totally fine as long as your not grinding anything and it drops right in without an aggressive change in engine speed. I.e. at 55 to 60 I'll drop to 6th without using the clutch.
    I can do it from 4 to 5, or 3 to 4 also but I occasionally will have a bit more trouble getting it to drop in clean so I tend to use the clutch most of the time.
    TeecoTaco likes this.
  10. Jul 12, 2018 at 10:00 PM
    #8330
    SpaceTrim
    SD
    I use my clutch to start and downshift. Depends on what mood I'm in, and the occasion. I never used it when I had my old Nissan z so the habit carried over when I got my truck. Easier in the truck with the Rev hang. I just wasn't sure if you guys knew any reason not to with these new transmissions.
  11. Jul 13, 2018 at 4:02 AM
    #8331
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    If you perfectly match revs with your target gear the shifter will fall into place without the clutch. When upshifting like this you simply get to the right speed let rpms fall in neutral and let the shifter fall into gear. When down shifting you shift to neutral first and do a tiny rev to make it fall into place at the right rpm. I do this all the time in my Opel, but I typically only use it occasionally in my Taco.
    Nunya Bizness and TeecoTaco like this.
  12. Jul 13, 2018 at 5:12 AM
    #8332
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    My understanding is that it's never a good idea to float shift a synchronized transmission. Reason being the syncros will allow you to get it into gear even if your speed match isn't perfect, and causing increased wear on them.
    MOC221_ and OpelGT like this.
  13. Jul 13, 2018 at 5:26 AM
    #8333
    OpelGT
    Texas
    The gear will grind unless you are perfect even with synchros. I really don’t recommend learning it on a new pickup now that I think about it. It was fine to learn on my Opel because it will cost me like $50 to replace my transmission again myself in that.
    Floating gears does save you clutch, but in return it does damage your sychros and gears unless you are 100% perfect each time. I’m good at it, but I am human. Its one of those things that people can do all the time for 200,000 with no issue, but others will trash their trans doing all the time. I just do it for fun occasionally.
  14. Jul 13, 2018 at 6:12 AM
    #8334
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    My part time job is driving a dump truck with an Eaton Fuller 8LL transmission. I float gears all the time but thats because it's not synchronized. I've done it in the Tacoma just to see if I could, and it's possible but a huge pain in the butt. It's harder to "play" with the throttle and get smooth consistent shifts.
    I really don't see an advantage to floating gears in these trucks.
    But I'm biased. After spending 8 hours in a dump truck, pushing a clutch and never missing a gear is a dream.
  15. Jul 13, 2018 at 6:16 AM
    #8335
    drlocke
    drlocke Active Member
    Thanks so much for the response - good to hear I’m not the only one. Does your truck do this only on the first serious engagement too? When mine does this it doesn’t have to be “cold” - the overnight temp could be in the 70’s and it will still behave this way. I’ve never had a clutch behave this way over maybe 10 different cars/trucks, so I’m thinking I should try to get it more carefully looked at.
    MOC221_ likes this.
  16. Jul 13, 2018 at 6:25 AM
    #8336
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Mine does this too, as have other M/Ts I've owned. Sometimes the first engagement is rough and the truck shakes.
    It may be more to do with moisture/oxidation than temperature, not sure. As others have said, once you get it warmed up and "cleaned off" everything is fine.
  17. Jul 13, 2018 at 7:02 AM
    #8337
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Brakes will do this, too.
  18. Jul 13, 2018 at 7:02 AM
    #8338
    Taquitoqvola
    Taquitoqvola Well-Known Member
    2018 TRDORDCSB MT QUIKASFKSAND
    Just wanned to get in on pg 420.
    Peace!
    cosmicfires and TeecoTaco like this.
  19. Jul 13, 2018 at 8:52 AM
    #8339
    su.b.rat
    su.b.rat broken truck
    :rasta:
  20. Jul 13, 2018 at 9:08 AM
    #8340
    MGM3Pedal
    MGM3Pedal Well-Known Member
    Rob
    Appalachian Mountains
    2017 MGM DCSB 6MT TRD Sport 4X4
    Taught my wife how to drive manual in my '17 Sport recently. Thought you guys would appreciate this.
    Rule number 1 has always been to never try and teach someone you are in a relationship with how to drive three pedals. It can get very frustrating and lead to "social complications".
    She didn't want to wait on one of my friends so we went ahead and gave it a try. I gave her a very serious lecture first on why this is one of the few times she would have to take ALL of my instructions seriously and pay close attention. After all, I certainly didn't learn how to drive stick on a brand new $30k+ vehicle.
    She did great! In retrospect, teaching her myself led to me teaching her how I wanted her to drive my truck versus someone else. No chance to pick up any bad habits. We live in the Appalachian mountains and the hill assist feature on my Sport really came in handy while she got some practice on hills.
    Now she drives the Taco like a champ. Not clutch happy or anything. She has also now driven a 99 4Runner 5MT and a 92 Silverado 5MT and did great.
    Wouldn't have believed I could have done this without WWIII but all is well.
