Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 25, 2018 at 9:50 PM
    #8921
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I think it's the EPA tests they use to estimate MPG just don't favor MT anymore. They can integrate the engine and transmission controls with an AT such that it does exactly what it needs to do to ace the test. But an MT relies on more assumptions and maybe actual driving testings.
    In the real world a MT could get better or worse than the estimate, completely depends on the driver. Plus the engine can't anticipate what the drivetrain is doing with a stick. The knucklehead behind the wheel might not shift perfectly, hold a gear too long, shift too quick. It's pure chaos to the engine controller, the system never can achieve ideal efficiency.
    Mechanically there's no way I can see an AT being more efficient than a MT. It's a direct connection with a little bit of gear friction. No hydraulics or fluid coupling. The only time an AT is equally good is when the torque converter is locked up.
  2. Aug 25, 2018 at 10:31 PM
    #8922
    duckytw
    duckytw Well-Known Member
    If you have the exact same gearing, same ecu tune, same shift points, a torque converter auto will get worse mpg than a manual. It really is an elegantly simple, robust, and most importantly, efficient means of coupling a motor to wheels. When people cite modern autos blah blah blah, they always miss the gearing at minimum.
  3. Aug 25, 2018 at 10:39 PM
    #8923
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Flashed to the updated ecu yesterday and it is awesome. Shifting from 1-2 without having to rev out 1st, and all shifts are smoooth. 2nd gear very responsive in low rpm. Throttle response much improved and rev hang diminished. All 3rd gen MT should look into this. I loved my truck before. But man it’s even better.
  4. Aug 26, 2018 at 7:03 AM
    #8924
    thdrduck
    thdrduck Well-Known Member
    That is the clutch safety switch doing it's job and does not mean your clutch is out of adjustment. You should have about 3/4 to 1 inch free play at the top of the peddle. This being a hydraulic clutch, not sure if there is an adjustment but someone that knows more about this clutch system should let you know for sure.
  5. Aug 26, 2018 at 9:08 AM
    #8925
    D-Rock531
    D-Rock531 Well-Known Member
    Tucson
    2017 TRD "PRO" 6MT ACLB
    Bilstein 5100, ARB Single, 4.88 Gears, 33" on Method 305
    Same, when i go wheeling with my friends in their AT Tacos its a huge difference. They're always bogging it at low RPMs and cant get high RPMs when they need to. I love to gun it through the smooth sections, downshift, drop the clutch and 4 wheel drift around a corner.
    pinochle and Beemaster like this.
  6. Aug 26, 2018 at 9:14 AM
    #8926
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Free play spec is 5-15 mm
    shakerhood likes this.
  7. Aug 26, 2018 at 10:44 AM
    #8927
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    That's about the free play I have about 12mm I'd say. Just curious if everyone else was having to depress the clutch all the way to the floor to get it to activate.
  8. Aug 26, 2018 at 1:43 PM
    #8928
    specter208
    California
    Normal, but sometimes it feels like I can press the pedal maybe 3/4 of travel and it will still trip the switch.
  9. Aug 26, 2018 at 2:26 PM
    #8929
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I'm 34, sold my last manual at 21 until I got my 2017 at 33 years old. The first six months of driving it felt like I was getting runners knee...
    I'm not sure how you would fix it. But what helped for me was exercise and driving more!
  10. Aug 26, 2018 at 2:31 PM
    #8930
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    trackdaybro likes this.
  11. Aug 26, 2018 at 2:59 PM
    #8931
    specter208
    California
    You can also watch the blue MPG meter and shift when the meter hits peak MPG usually around 2000rpm. Would only recommend on flat roads with little traffic.
    2016trdtacoma[QUOTED] likes this.
  12. Aug 26, 2018 at 4:00 PM
    #8932
    johnnyblender
    johnnyblender Active Member
    Seacoast, NH
    2018 Cement Tacoma DCSB 4x4 TRD OR MT
    It’s all about the final drive ratio
    Roundarc likes this.
  13. Aug 26, 2018 at 4:31 PM
    #8933
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    This is how it should be. But to reduce some of the dead travel, I removed the green stopper from the clutch pedal and used a body clip with a few washers.
  14. Aug 26, 2018 at 4:36 PM
    #8934
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    I shift at 2500 frequently and as long as I am easy on the gas the truck does well. I think (THINK) shifting at 2 would cause the motor to bog.
    If I'm pulling my trailer I'll shift at 3 or more.
    tonered and specter208[QUOTED] like this.
  15. Aug 26, 2018 at 7:11 PM
    #8935
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Hahahhaaaa... I'm surprised that guy can drive, talk, film, talk with his hands, and shift!!!! Holy hell, put your hand back on the wheel.
  16. Aug 26, 2018 at 8:35 PM
    #8936
    specter208
    California
    That's why only flats or downhill while driving nice and relaxed, no traffic and unloaded/no trailer.
    Masterofnone[QUOTED] likes this.
  17. Aug 26, 2018 at 9:23 PM
    #8937
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Lol! I normally shift around 1800rpms. I seldom rev it up unless I’m going up a really steep hill.
    tonered likes this.
  18. Aug 26, 2018 at 9:34 PM
    #8938
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I was on a back road (in Mexico) this morning on my way home from work, and wanted to see what 2nd gear would do if I ran it up tbe RPMs before shifting.
    Freaking 62mph....in 2nd gear at just over 5500 rpms. 3rd was quickly approaching 85mph, so I slowed it back down so I didn't take out a small village or random wild donkey crossing the road.
    tonered, Dctaconny and pinochle like this.
  19. Sep 3, 2018 at 5:57 PM
    #8939
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    New knob installed.
    tonered and TeecoTaco like this.
  20. Sep 3, 2018 at 6:01 PM
    #8940
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Looks like a Tootsie Roll sucker. Nice!
    shakerhood, specter208 and elduder like this.
