Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Oct 8, 2018 at 4:22 AM
    #9021
    trackdaybro
    trackdaybro Well-Known Member
    Regarding 4th to 5th gear shift-
    Do y’all move the shifter “up - right - up” or just push the shifter diagonally directly from 4th to 5th if that makes sense? My shift is smoother with the latter but I’m not sure if I’m going to wear something out over time gliding the shifter through the guides like that.
  2. Oct 8, 2018 at 5:18 AM
    #9022
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The shift forks will not like that long term.
    doublethebass likes this.
  3. Oct 8, 2018 at 6:38 AM
    #9023
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I probably skip 5th gear 90% of the time, 4th to 6th works pretty well. If I do decide on using 5th then I skip 4th gear by going 3rd to 5th.
    psmura likes this.
  4. Oct 8, 2018 at 9:20 AM
    #9024
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just an update, I got back from the dealer for the blower motor recall fix and asked them to check the TSB on updating the ECU for the manual trans. The service guy said there’s none for the manual only for the auto. I wasn’t going to argue, whichever the case my truck drives and shifts fine the way it is.
    oconnor and tonered like this.
  5. Oct 8, 2018 at 9:25 AM
    #9025
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you are happy, then it's all good, but there is a TSB for the MTs (just not the 2018s yet). The TSB is attached to this post:
    https://www.tacomaworld.com/threads/software-update-for-the-manual.562550/page-99#post-18788693
    It's applicable to your 2017.
    :cheers:
  6. Oct 8, 2018 at 10:20 AM
    #9026
    Grossomotto
    2017 4WDV6LB6MT
    tonered[QUOTED] likes this.
  7. Oct 8, 2018 at 10:31 AM
    #9027
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem!
    Note the warranty coverage on that TSB (Page 1) falls under the 96mo / 80k emissions warranty, so you should have a lot of time left on that.
  8. Oct 13, 2018 at 5:40 PM
    #9028
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Ok think something is going wrong. Recently after shifting the truck acts like im not applying any throttle. Let off the throttle and than fine. Scan tool reads everything ok even during that delay. So i dont think its a sensor.
  9. Oct 13, 2018 at 6:04 PM
    #9029
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
  10. Oct 13, 2018 at 6:05 PM
    #9030
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Anyone think the 2.7 5MT comes back? Maybe with a 6MT instead?
  11. Oct 13, 2018 at 6:10 PM
    #9031
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I just got my ecu updated at the dealership using the idle surge TSB.
    Honestly, this car is not drivable without the ECU update.
    This is something that all third gen MT owners need to do immediately.
    It's just a normal vehicle now.
    tonered likes this.
  12. Oct 13, 2018 at 6:53 PM
    #9032
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    I complelty agree, city driving is a different experience now. I also drove it on trails and it’s a big improvement. Prior to an update I would have to shift to a 1st gear on a more serious climbs, now I can stay in 2nd gear and it just crawls.
    tonered likes this.
  13. Oct 13, 2018 at 8:41 PM
    #9033
    ATC Taco
    ATC Taco Active Member
    Justin
    18 Off Road DC MT Blue
    Yea I’ve noticed that the 4-5 gear change feels weird. It’s like there is hardly a difference between the ratios. So I usually skip 5th too. I’ll also have to try the 3-5 change
    shakerhood[QUOTED] likes this.
  14. Oct 13, 2018 at 8:51 PM
    #9034
    ATC Taco
    Justin
    What TSB number is that? I’m taking my truck in for a routine 5000 mile service on Tuesday. I might as well bring it up since it the throttle does have a weird feel to it when changing gear. Thanks!
  15. Oct 13, 2018 at 9:40 PM
    #9035
    Kamille.bidan
    2017 Blue TRD OR MT
    The TSB is for 16-17 only. They may not do it for you.
    Check the software update for manual thread for the TSB number.
  16. Oct 14, 2018 at 5:10 AM
    #9036
    ATC Taco
    Justin
    Ok thanks. Maybe I’m just still getting used to the throttle...
  17. Oct 14, 2018 at 5:32 AM
    #9037
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    I have a 2018 and got the flash done. Showed them these pics from my post. Use them and be adamant that you want the flash.
    Post 1027
    https://www.tacomaworld.com/threads/software-update-for-the-manual.562550/page-52#post-18522543
    tonered likes this.
  18. Oct 14, 2018 at 5:58 AM
    #9038
    Grossomotto
    2017 4WDV6LB6MT
    tonered likes this.
  19. Oct 14, 2018 at 9:15 AM
    #9039
    JJ18ORDBSBMT
    Show the pics. I had to tell them 3x. It worked though. Tell them to look at the ECU numbers. The title of the tsb is wrong.
    tonered likes this.
  20. Oct 14, 2018 at 11:03 AM
    #9040
    Grossomotto
    2017 4WDV6LB6MT
    Will do I saved the pics
    JJ18ORDBSBMT[QUOTED] likes this.
