Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 1, 2018 at 6:26 PM
    #9501
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Just got home with the 08. It was a fun drive 60 mikes going 20 to 45. Snow n winds terrible road conditions.
  2. Dec 1, 2018 at 9:08 PM
    #9502
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    Sure. Just don't use your balls as the ground...
  3. Dec 2, 2018 at 6:14 AM
    #9503
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Not sure if serious...:spy:
    tonered[QUOTED] likes this.
  4. Dec 2, 2018 at 7:32 AM
    #9504
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    A 2018 Subaru Forester (3.45 vs 3.98) , and a 2013 Triumph Street Triple (that thing tops out at 74 in first)
    Yeah, I tried it again, works fine. Must have been operator error
  5. Dec 2, 2018 at 7:59 AM
    #9505
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  6. Dec 2, 2018 at 8:19 AM
    #9506
    nevadabugle
    Elko, NV
  7. Dec 2, 2018 at 8:20 AM
    #9507
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  8. Dec 2, 2018 at 8:27 AM
    #9508
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Dont rev too high when in 4lo and shifting gears. There is a lot of torque going through the transmission and the synchros won't be able to handle that much torque if you rev to high. Try to shift before 1500rpm.
  9. Dec 2, 2018 at 9:42 AM
    #9509
    bdiz
    bdiz Member
    Im talking about going into gear from a stop. It almost feels a like a bike when you first click it into first and it kind of loads up the drive train..
    I’ve owned and built a few rigs before this and never really noticed this happen before...
    I feel like all the shifting issues and clunky feelings are due to the clutch not disengaging as much as it should in order to take the torque off the synchros to be able to shift smoothly. Especially the 1-2, 2-3 upshifts and downshifts to 2nd...
    I might be out to lunch, but this is my theory
  10. Dec 2, 2018 at 11:49 AM
    #9510
    specter208
    California
    Normal. There is still some torque in the transmission spinning which can cause a little bump when going into gear but this not because of a clutch dragging. Not all transmissions handle the same. Try to make the shifts before your RPMs drop more than 200-300rpm. Do the shift quickly with finesse, but dont try to jam the shifter into gear and force it.
    shakerhood likes this.
  11. Dec 2, 2018 at 11:57 AM
    #9511
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    nevadabugle[OP] and Beemaster like this.
  12. Dec 2, 2018 at 5:40 PM
    #9512
    BigHam
    BigHam dɹǝp
    So, since we're on the topic of shifting, in the last 3 days I've been unable to get into gear 3 separate times.
    The 1st and 3rd were going into reverse from parked, like it went half into the gate. Releasing the clutch led to some grinding until I popped it back into neutral.
    The 2nd time was trying to get into first from a stop, it would not budge into first until I put it in neutral and re-tried it.
    The only correlation between the 3 of these that I can think of is it was within the first 10 minutes of each trip in approximately 35 degree weather. Not too worried about it, just curious as to potential reasons this would happen.
  13. Dec 2, 2018 at 5:53 PM
    #9513
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Gear fluid is really thick. I usualy neex to speed match my releasing clutch in n and then going into gear.
    BigHam[QUOTED] likes this.
  14. Dec 2, 2018 at 8:01 PM
    #9514
    nevadabugle
    Elko, NV
    B
    Best meme ever.
  15. Dec 2, 2018 at 8:03 PM
    #9515
    nevadabugle
    Elko, NV
    So I had to try this. Did it with out 2014 Tundra. It actually works although my chin did nothing but putting it to my temple made it work from a long ass ways off. One of those things that makes you say...WTF...
  16. Dec 2, 2018 at 8:08 PM
    #9516
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Anyone has this rattle noise that appears at 3000rpm mark going uphill only? Can’t pin point it, I feel like it’s in the engine bay, while passanger thinks it’s near my seat. :annoyed:
    2018 with 26K miles
  17. Dec 2, 2018 at 8:10 PM
    #9517
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    And what Jck said^^^^^
    Also you could use a 75W80 synthetic like Redline MTL in the trans, it flows well below 0F
    https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
    BigHam[QUOTED] and shakerhood like this.
  18. Dec 2, 2018 at 9:34 PM
    #9518
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Yeah I've always heard the method of holding to the side of your head/temple before. Basically the explanation I've heard is that the back of your skull is working as a parabolic antenna to direct the signal towards your vehicle.
  19. Dec 2, 2018 at 10:05 PM
    #9519
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Interesting. I had not heard of doing it that way. It's all good if it works when you need it.
  20. Dec 4, 2018 at 4:52 PM
    #9520
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Anyone here that’s gone up a tire size to 265 75 16, care to share their findings?
    Any appreciable change in gearing, power loss?
