Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 3, 2019 at 9:45 PM
    #9901
    ThatsExactlyWhy
    ThatsExactlyWhy Well-Known Member
    NorCal
    2019 OR 4x4 MT
    I have a 19 TRD OR w/ 6MT. Love the truck for the most part. The one slightly annoying thing is the driveline noises when shifting sometimes or going at slow speeds over a speed bump or something. I would describe the sound as a combination between a “clank” and a “clunk”. I believe it is coming from the ever so slight amount of play in the output spline of the transmission where it mates to the driveshaft. It’s not super loud or anything, but definitely noticeable. I was hoping that there would be a grease fitting there to inject some grease, but no luck. Anyone else have this issue?
  2. Apr 3, 2019 at 9:48 PM
    #9902
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is lash. I had that problem also, but seriously the TSB ECU update killed 90% of it.
    shakerhood likes this.
  3. Apr 3, 2019 at 10:23 PM
    #9903
    trackdaybro
    trackdaybro Well-Known Member
    Curious, how does an ECU update help driveline lash? Does it apply constant/slight load? I’ve learned to do that when going over slow bumps- as long as I’m even lightly on the gas I can prevent all the clanking and rattle.
  4. Apr 3, 2019 at 10:28 PM
    #9904
    Leeman22
    Leeman22 Well-Known Member
    Leo
    SoCal
    2019 Tacoma trd or 6mt 4x4 Cavalry blue
    Stock
    Every time I drive an automatic vehicle accelerating from a stop I tend to push on an invisible clutch ‍♂️
    GQ7227 likes this.
  5. Apr 3, 2019 at 10:30 PM
    #9905
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    No clunks noticed on my 2019 Access Cab but I did notice the rear driveline is void of grease fittings. It also has only 3 u joints instead of 5 like my first Gen. The front drive line (on my 2019) does have grease fittings in each u joint. Alot less lube maintenance on these new Tacomas.
    GQ7227 likes this.
  6. Apr 3, 2019 at 10:42 PM
    #9906
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Nice. I owned a Heads/Cam 02 Sunset orange z28. Converted it to 6 speed. Then I sold it =( I miss that car.
    GQ7227 and shakerhood like this.
  7. Apr 4, 2019 at 5:23 AM
    #9907
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just like it was strange that it improved shifting. The original tune was just garbage, and I didn't have half the problems that the earlier 3rd Gens had.
  8. Apr 4, 2019 at 7:04 AM
    #9908
    ThatsExactlyWhy
    NorCal
    2019 OR 4x4 MT
    Not sure if the TCU TSB applies to my truck. I searched Toyota’s TSB lookup website with my vin last night and it didn’t come up. Thinking that maybe since it’s essentially a brand new truck, the new tune was applied at the factory? Or is it something that they essentially pretend isn’t a problem until you complain about it?
  9. Apr 4, 2019 at 7:04 AM
    #9909
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I notice something similar on my 2019. Seems like it happens just as the clutch engages when I'm not on the accelerator. If I'm a bit more cognizant to give it some gas (not a lot, just ease into it) as I'm letting off the clutch then I don't get it.
    Shouldn't be that I don't think. The 2019s should already have the latest ECU updates, shouldn't they? The TSBs are all pre-2019, so they would have been integrated from the factory.
  10. Apr 4, 2019 at 7:10 AM
    #9910
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The TSB tune was supposedly rolled into the factory production sometime in the late 2018 Model Year. No one has posted ECU IDs from the late run 2018s yet though.
  11. Apr 4, 2019 at 9:24 AM
    #9911
    deusxanime
    MN
    I posted my early 2019 (originally was supposed to be a 2018 when I ordered and ended up being one of the first 2019s instead) ECU a while back. It had a totally new/different ID number, so nobody really knew or could correlate what that meant as far as TSBs.
  12. Apr 10, 2019 at 9:24 AM
    #9912
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    Hi, is there a TSB for squeaky clutch that was put out? I told dealer about mine squeaking on my 16, and they said there was nothing they could do. I have just been greasing it myself. The grease does not last long though. With summer right around the corner, I bet mine will start squeaking again.
    GQ7227 likes this.
  13. Apr 10, 2019 at 10:07 AM
    #9913
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Grease all the pivot points with Disc Brake Grease, it will not melt away in high temps and cures the old barn door creaking.
    GQ7227, MOC221_ and tonered like this.
  14. Apr 10, 2019 at 10:08 AM
    #9914
    shakerhood
    Southern Ohio
    Disc Brake Grease will not melt away
  15. Apr 10, 2019 at 10:24 AM
    #9915
    jeffmansion
    16UTILITY4x4MT2.7
    ''The latest TSB I can find only goes up to the 2017 model year''
    Is there an actual TSB you speak of?
  16. Apr 10, 2019 at 11:32 AM
    #9916
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    I don't know the TSB number, but the tech looked at a '17 TSB, and was approved to replace the pedal assembly on my '18. It has been nice and quiet since it was replaced last August. Hopefully it does not return with the warmer weather.
  17. Apr 10, 2019 at 11:38 AM
    #9917
    trackdaybro
    Don’t waste your time at the dealer. Or with white lithium grease.
    Go straight to that black thick disc brake grease. My creak was coming from the pin under the pedal, hit that and the pivots. Silent ever since.
    shakerhood, MOC221_ and tonered like this.
  18. Apr 10, 2019 at 11:41 AM
    #9918
    jeffmansion
    16UTILITY4x4MT2.7
    it is a bit of a pain to grease yourself. tough spot to get to effectively. How did you get it up there? is that a spray type grease? I will try a better grease next, tried several things so far that have only worked for short term.
    If there was a TSB on this issue, I would inquire about it. I don't believe there is an actual TSB on it though until someone shows me otherwise.
  19. Apr 10, 2019 at 11:44 AM
    #9919
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    Hello fellow man tranny lovers!;)
  20. Apr 10, 2019 at 11:44 AM
    #9920
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is a TSB.
    So, you say it is difficult to get to. Now, imagine a tech in there who is told to get the work done in an hour. How good of job do you think they are going to do? There have been posts about missing nuts, leaking fluid, and other issues post-TSB that also include the squeak coming back since the exact same part is getting put back in.
    Your choice.
    Tacoma816, GQ7227, 0uTkAsT and 2 others like this.
