Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 21, 2019 at 12:29 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I can't even imagine how utterly useless reverse would be if you did this lol!
    My take on this (keeping the 4.30 axles):
    1. Make 6th just a touch higher to bring down the rpms on the highway (also makes 5th more useful);
    2. Change 2nd gear to be a touch closer to 1st; and
    3. MAKE REVERSE LOWER. LIKE, LOWER THAN 1st!!!
    Oh and lower 4lo Tcase ratio as well.
    There you have it.
    BillyToy, shakerhood and cosmicfires like this.
  2. May 21, 2019 at 12:35 PM
    Shellshock
    Iowa
    I second this
    cosmicfires likes this.
  3. May 21, 2019 at 12:40 PM
    MOC221_
    Frank
    Makes me wonder sometimes.. who was making the decisions with the gearing of the M/T and why.
    I'd love to see the "rationale" behind it.
    :facepalm:
    Shellshock likes this.
  4. May 21, 2019 at 12:41 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Motion carried!
  5. May 21, 2019 at 12:42 PM
    cosmicfires
    David
    Everett, WA
    You can downshift into 1st if you double clutch, that's what I have to do on my 2.7 L with 5 speed. And reverse is lower than first.
    SilverBulletII and MOC221_ like this.
  6. May 21, 2019 at 12:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am coming to believe that the Reverse issue is a packaging thing. I believe that I read that the case casting is common among other MT or something like that. Standard interfaces are a common thing these days, esp on low volume parts. To make reverse lower, a larger diameter gear would have been need, which might not have fit in the case? Probably the same with going lower on 1st and higher on 6th? Just guesses.
    Although, I think @RedBeard1 posted about a non-US gearbox with the ratios that we want.
  7. May 21, 2019 at 12:46 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Its interesting to see the gear ratio differences between the 2018 toyota 6mt and the 6mt in my 2007 nissan frontier. The toyota sacrifices closer gear ratios in order to have a second overdrive. Hmm.
    Nissan - 3.55 rear end , stock 265/70R16 tires.
    1st: 4.368
    2nd: 2.518
    3rd: 1.743
    4th: 1.283
    5th: 1.000
    6th: 0.769
    Reverse: 3.966
    Toyota - 4.30 rear end - ? tires
    1st: 3.98
    2nd: 2.02
    3rd: 1.32
    4th: 1.00
    5th: 0.85
    6th: 0.71
    Reverse: 3.39
    MOC221_[QUOTED] likes this.
  8. May 21, 2019 at 12:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is interesting that the 3rd Gen 2.7l MT had the 3.909 diff ratios though. What is yours?
    shakerhood and MOC221_ like this.
  9. May 21, 2019 at 12:49 PM
    MOC221_
    Frank
    IMO, the 3rd gen M/T V6 has two things baked in that make 1st gear downshift harder (not impossible).
    1. Throttle lag;
    2. Accumulator delay.
    I'm not saying it can't be done smoothly stock, but it's MUCH easier now that I'm tuned and the accumulator is in the dumpster.
    I will say that later versions of the OEM M/T calibration were better.
    tonered likes this.
  10. May 21, 2019 at 12:50 PM
    MOC221_
    Frank
    Every time I see that chart it's a WTF moment lol.
    Paul631 and tonered[QUOTED] like this.
  11. May 21, 2019 at 12:50 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good info, but with the Nissan diff gearing, the Taco has a lower 1st and 6th. I'll take the Taco ratios, esp give my MPGs, except for that enviable reverse gear.
  12. May 21, 2019 at 12:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I could only smoothly drop it into 1st while rolling only after the TSB tune and the ADM.
  13. May 21, 2019 at 12:55 PM
    0xDEADBEEF
    Yeah, I guess it depends on how you're using it. I've towed pretty much up to the weight limit of the truck and had no complaints about 1st gear being too tall. But if I were offroading it, then it would be a different story. Without a trailer though, its a highway monster, I love that.
    My taco has the 2.7 with the MT, 4.30 gears and adorable little tires and its entirely too low for long distance highway cruising, but around town its a blast. Next set of tires is going to be 10% bigger, I think.
    tonered[QUOTED] likes this.
  14. May 21, 2019 at 1:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is nice to have a choice.
    I am debating the next sidewall size myself.
    TeecoTaco likes this.
  15. May 21, 2019 at 1:03 PM
    0xDEADBEEF
  16. May 21, 2019 at 1:07 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Go my route...got some 16 OR rims, more sidewall with them. Same size overal diameter rubber. The ride is noticeably smoother than the 17 sport rim stock tire setup
    shakerhood and tonered[QUOTED] like this.
  17. May 21, 2019 at 1:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    0xDEADBEEF[QUOTED] likes this.
  18. May 21, 2019 at 1:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have been half-heartedly looking for either Sport or OR wheels. I like the feel on and off road, but just trying to decide if I really want a taller tire overall.
    Also, blacking out a spare set would be an easier route, which is the real goal.
    doublethebass likes this.
  19. May 21, 2019 at 4:32 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Me too!
    So........ my son moved into a rental house with a unbelievably steep driveway.
    When it was time to leave started backing up the driveway, perfect launch.
    Halfway up notice a car coming, had to stop. Second launch was less than stellar.
    Was like WTF is that smell.... this place stinks.....
    Realized it was clutch. Felt like a absolute fucking rookie.
    Reverse gearing sucks for sure!
    But this stock clutch has zero feel unless that is all your focused on. My biggest gripe with this truck.
    ADM and free play adjustment helps.
    I can’t wait to throw it in the trash.
    And that may be sooner then I thought, have a slight chatter now starting in first sometimes.
  20. May 21, 2019 at 4:36 PM
    TD90S
    GA
    ‘18 TRDOR 6MT
    Now that I’m thinking about this more it makes absolutely no sense.
    I understand a light clutch in a Accord or a Corolla.
    But what limp leg FNG is going to buy a MT truck and complain about the clutch is to heavy? o_O
    MOC221_ likes this.
