Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 29, 2019 at 11:50 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Air stomp > brake stomp > money shift
  2. May 29, 2019 at 12:23 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    that same sort of thing usually happens for me but in 1st gear......just push the clutch in once or twice while you've got it in neutral and that'll start moving things around, she'll slide right into gear
    TBV[QUOTED] and SilverBulletII like this.
  3. May 29, 2019 at 12:24 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    yep, definitely did that a few times after i first learned to drive a stick.......now when i'm in an automatic I have to tuck my left foot back against the seat so I don't go for the imaginary clutch.....
  4. May 29, 2019 at 12:49 PM
    trackdaybro
    trackdaybro Well-Known Member
    Just made the swap to 255/85/16 tall skinny tires and it improved starts in first gear. I’m no longer holding up traffic trying to smoothly get to 2nd off the line whereas before 1st felt a bit short and I had to wind it out.
  5. May 29, 2019 at 12:51 PM
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Care to elaborate on why that is?
  6. May 29, 2019 at 1:01 PM
    trackdaybro
    You’re moving faster at the same engine RPMs since the tire is taller.
    pinochle and TBV[QUOTED] like this.
  7. May 29, 2019 at 1:03 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    "Left foot should always be on dead pedal unless operating clutch" my dad used to tell me.
  8. Jun 2, 2019 at 1:27 PM
    ChiefTRDSport
    ChiefTRDSport Chief
    New Jersey
    2016 Tacoma Sport 3.5 DC 4x4 w/6sp manual
    TRD CAI and cat back, bug shield, rear step, and Black Horse bull bar.
    I can’t complain much on mileage. I had a pic somewhere of 25.3 mpg on a short 15 mi trip at about 50 mph keeping my foot out. On the highway, 70-85 mph (mostly 80) over 100 mile trip I got 19.4. With 430 gears, I figure that’s pretty good. Probably getting help from TRD CAI & Catback exhaust. Wish I had more lower end torque though.
  9. Jun 3, 2019 at 1:22 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Does anyone have issues with the reverse gearing on this truck? I am coming from my 16 Auto to the 19 manual and reverse gearing in this thing is a joke. I went camping and had to level out my truck for the rtt. I had a buddy put a piece of a log, maybe a quarter of it behind the front driver tire, I tried backing over and it almost stalled it, then gave more gas and less clutch causing the clutch to burn. Like christ. I've been driving stick sense I was 15yo, I am 33 now so I know how to drive stick. I guess I'll put it in 4lo for more torque next time.
    My truck has a little. More weight from the setup I have, maybe that attributes to it, not sure though. I do still like my manual, just embarrassing reverse gear. It's not a fuel economy thing either.
    GQ7227, denmen and su.b.rat like this.
  10. Jun 3, 2019 at 1:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With the not so tight turning radius, I sometimes back over end curbs in parking lots so that I don't have to swing wide or do an Austin Powers turn. I can get over them, no problem. I will attribute this to the TSB tune (04B13) and the accumulator delete. OVT is even better.
    But yes, the reverse gearing is nothing to joke about. It is just sad.
  11. Jun 3, 2019 at 1:31 PM
    eon_blue
    Azusa, CA
    Been that way with Toyotas across 1st - 3rd gens and probably even before then, reverse has always sucked. I have the same issue, doesn't help that Toyota puts such light clutches in these trucks that don't bite very well at all. I stalled mine 2 weekends ago trying to back onto 2 traction boards stacked on top of one another, to level out the RTT.
    Putting it in 4lo usually guarantees this won't happen lol. As long as you're on dirt or just going straight backward.
  12. Jun 3, 2019 at 1:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Also note that the 2Lo mod is coming!
  13. Jun 3, 2019 at 2:38 PM
    su.b.rat
    su.b.rat broken truck
    i just came here to say your setup is totally awesome. :cheers:
  14. Jun 3, 2019 at 3:13 PM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    Thanks! Did a dry run this weekend. Made sure the deep cycle battery worked with the fridge and other stuff plugged in. Figured out things needed and how I could organize stuff better. My little grill cooked breakfast for 13 people. Drunken good times.
    TD90S, tonered and shakerhood like this.
  15. Jun 4, 2019 at 7:57 AM
    denmen
    denmen Well-Known Member
    Dennis
    New Hampshire
    2013 4x4 V6 SR5 6-spd Spruce Mica AccCab
    Tube steps, bull bar and KC Hilites, trifold bed cover, variety of shifter knobs, comparing LED strip options, lift possibilities (prob 2 inch), and exhaust mods to tune growling on low end...
    this is off the rails awesome!!!!!!!
  16. Jun 4, 2019 at 9:36 AM
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    I made the change to 255/85/16's recently as well, and man what a difference. I thought the manual was geared too low from the factory, but it is much better now with these tires. Both in acceleration (not actual speed, obviously it is slower, but the gears don't feel so short) and cruising at freeway speed.
    denmen likes this.
  17. Jun 8, 2019 at 3:03 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    Scored a new Core short shifter from a member. Installed today, this is a seriously sweet setup. Front to back and side to side movement is the perfect distance IMO. The first to second shift was a slight annoyance to me with the stock setup. Especially in traffic with the short first gear/wonky factory tune. No more, 1/2 is quick without abusing the transmission.
    More noise is transmitted through the solid mounted stick, You can hear the syncros working and some gear whine :burnrubber:
    Some may consider this a drawback, if you’ve driven older manuals your used to it. Doesn’t bother me one bit.
    Now I need to figure out how to mount my @7r41lbr34k3r shift knob.
    Still using his Delrin boot ring and a couple of rubber grommets.
  18. Jun 8, 2019 at 4:26 PM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    TRD shift knob in mine
    Junkhead, GQ7227, spdyrvlvr and 2 others like this.
  19. Jun 8, 2019 at 4:30 PM
    sea2summit
    sea2summit Member
    '07 Pre-runner 4-cyl M/T, '19 TRD off-road M/T
    That's why I'm here...
    Checking in...
  20. Jun 8, 2019 at 4:32 PM
    obpmem
    obpmem Well-Known Member
    I want to see more pics of your setup. That things looks great. What bars/tent setup do you have? Where they separate or one bundle? Cheers.
    denmen likes this.
