Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 11, 2019 at 3:54 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Never had to do it with any of the VWs we have owned.
    shakerhood[QUOTED] likes this.
  2. Sep 11, 2019 at 4:58 AM
    SnowB
    SnowB Well-Known Member
    Brad
    Detroit
    1996 Toyota 4Runner
    Suspension and intake and bigger tires
    My buddy has a 2002 F250 single cab long bed that is a manual transmission. It says the gear pattern is Creeper-1-2-3-4-overdrive. It's like they needed to tell people it had four on the floor. The shifter itself was like 5 feet long. Whenever we went people thought we were "the help". We went to a place to buy mulch one time and before we knew it a worker dumped 3 yards of mulch into the bed by accident. He just figured we were there from this golf course that had similar trucks.
    specter208 likes this.
  3. Sep 11, 2019 at 5:10 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I installed the URD short shifter on my truck. That definitely increased the effort required to engage reverse, but even before that I never found reverse accidentally. I drove a 2005 Corolla XRS for 8 years prior to my Tacoma with the 6 speed, that had zero tension and reverse was easier to find than first. Toyota's answer to that was a beeper in reverse of the back of the instrument cluster. I always felt some sort of locking mechanism would have been safer.
  4. Sep 11, 2019 at 6:07 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    That's what I was thinking too
    deusxanime likes this.
  5. Sep 11, 2019 at 6:57 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You mentioned having to do it in Post #10671, i didnt find it difficult having to push down on the shifter for Reverse.
  6. Sep 11, 2019 at 9:40 AM
    Spare Parts
    Southern Maine
    didnt realize I said I did it, thought I said it would suck to have to do it. My bad.
  7. Sep 11, 2019 at 9:55 AM
    mistareeman
    mistareeman Well-Known Member
    Your Mom
    2019 ORDCSBMT4x4
    I have yet to find reverse by accident but I have less than 1500 miles on it. Does it loosen up over time? If it doesn't I feel like you'd have to be Superman not paying attention to get R instead of 1.
  8. Sep 11, 2019 at 10:05 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I'm quickly approaching 10k and feel the same.
  9. Sep 11, 2019 at 10:16 AM
    shakerhood
    Southern Ohio
    Right my bad too probably just miscommunication.
    Spare Parts[QUOTED] likes this.
  10. Sep 11, 2019 at 10:18 AM
    Shellshock
    Iowa
    on my truck anyway if you go back in forth in neutral a couple times it will go right into reverse when you come across.
    if you just pull straight over from neutral, you'll hit the lockout and go up to first.
    SnowB and shakerhood like this.
  11. Sep 11, 2019 at 10:18 AM
    shakerhood
    Southern Ohio
    I am on my 3rd Tacoma in 11 years with that shift pattern and never accidently went in Reverse, the gate on all 3 trucks has quite a bit of resistance to pass thru.
    MtnFisher likes this.
  12. Sep 11, 2019 at 1:59 PM
    Spare Parts
    Southern Maine
    It’s interesting you say this, at times I feel like there is a steel wall there, and others I wonder if there is anything there. Never done a scientific experiment or even payed enough attention to care.
  13. Sep 14, 2019 at 3:16 PM
    whatjones911
    whatjones911 Well-Known Member
    2018 DCSB OR 4x4 MT
    I find myself needing to go back to 1st gear when I'm around 10-15 mph in order to get the truck out of its own way. Does anyone else find this to be true too?
    It's difficult to get back into 1st, for any vehicle, but I would double clutch/rev match. Sometimes it slides right in, but other times there's clatter/rattle(not a crunch sound) as if the gears meshed directly without a synchro.
  14. Sep 14, 2019 at 3:48 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    I’ve found my truck doesn’t like to go into first at those speeds. I’m not comfortable forcing it into gear.
    After 20k miles I’ve learned to work around it.
  15. Sep 14, 2019 at 5:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have no problem getting it by 20mph. It is a triple set of syncros, so they take some time to break in. Redline MT90 also helps.
  16. Sep 14, 2019 at 5:25 PM
    su.b.rat
    su.b.rat broken truck
    it took a few months of break in, a few months of practicing aim, and i think i have some Royal Purple in there that helps too. but the main two things for me are rev matching and throttle control. which. means ADM & OVT.
  17. Sep 14, 2019 at 5:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right on! The ADM was necessary for it to feel right and be smooth after the gear was notched in.
    su.b.rat[QUOTED] likes this.
  18. Sep 14, 2019 at 8:14 PM
    whatjones911
    2018 DCSB OR 4x4 MT
    Did you sometimes get a clatter if you get the rev match slightly off ( I want to say it does this only when I over shoot the rpm rather than under)?
  19. Sep 15, 2019 at 8:55 AM
    su.b.rat
    well i can make the clutch chatter in most temps at will just by taking it to the bite point. is that what you mean, clutch chatter? if that's your symptom I'm suggesting the ADM for better clutch modulation feel. if the 'clatter' you refer to is a metallic clunk sound when you punch down the clutch pedal, then that's normal on our trucks when you hit that pedal quickly. just not really sure what you're referring to: clatter.
  20. Sep 15, 2019 at 11:39 AM
    whatjones911
    2018 DCSB OR 4x4 MT
    The clatter I’m referring to is when slotting it into 1st from a double clutch/rev match. It’s from the gears meshing.
