Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Sep 15, 2019 at 12:48 PM
    su.b.rat
    su.b.rat broken truck
    i don't have that. but it is tricky to go smooth into first. i have not found double clutching to help with that although i double clutch about half the time going into first myself. i don't like pushing on the synchros and the gear jump 1 to 2 definitely does that w/o doubling.
    whatjones911[QUOTED] likes this.
  2. Sep 15, 2019 at 1:11 PM
    whatjones911
    whatjones911 Well-Known Member
    2018 DCSB OR 4x4 MT
    Yeah that 1-2 shift is spread wide. Hence why I need to go back into 1st on many occasions.
  3. Sep 15, 2019 at 1:33 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I think I was in my Subaru anyway onetime I was passing a 18 wheeler on a two lane and a car was coming , I had it timed good with third tacted and heading for fourth about half past the truck . So what do I do miss forth hit second perfect , now running 5 or 6k rpms and going nowhere , ran the other guy off the road .
    TRDCal[QUOTED] likes this.
  4. Sep 16, 2019 at 8:12 PM
    cbrcolin
    cbrcolin Well-Known Member
    Colin
    THOUSAND PALMS, CA
    19 QUICKSAND 7545
    NONE YET
    I recently sold my 2018 Automatic and bought a 2019 TRD OFF ROAD Manual. Could not be more happy with it. Doesn't even feel like the same powertrain. The cruise control now works properly, you can set it in second gear if you want to. The automatic was a big disappointment.
  5. Sep 17, 2019 at 9:18 AM
    jewboi
    jewboi Well-Known Member
    Who all is running the URD short shifter?
    Thinking about my next mods and havent heard much about this.
  6. Sep 17, 2019 at 10:38 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I have been running the URD short shifter for almost a year. I picked it on the black friday sale last year. I have had no issues with it. It was easy to install and made the shifting less sloppy and more positive.
  7. Sep 17, 2019 at 10:39 AM
    garander
    garander Well-Known Member
    2019 trd sport dcsb mt
    Almost 2 months (3,500 miles )on my trd sport manual and loving every mile I drive .
    I'm sure it's not as smooth. shifter as some the European sport cars but
    it's the best I've ever owned
    Junkhead likes this.
  8. Sep 17, 2019 at 7:22 PM
    trackdaybro
    trackdaybro Well-Known Member
    I’ve read you shouldn’t cruise in overdrive gears like 5th and 6th while towing or to accelerate, but what about hauling a motorcycle in the bed? Keeping it in 4th seems almost silly on the highway..
  9. Sep 18, 2019 at 4:26 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Motorcycle in the bed - no problem. What’s your bike weigh around 400lbs? My 4 banger 1st gen tows this little trailer down the highway in 5th gear at 70mph like it’s barely there.
    scouterjan likes this.
  10. Sep 18, 2019 at 9:16 AM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    I think that applies more for automatic transmissions and heat build up in the transmission/converter. If your not lugging the engine, your good.
    Just got back from a 4,400 mile round trip with a 300 LB motorcycle in the bed. Zero issues using 5th and 6th.
    trackdaybro[QUOTED] likes this.
  11. Sep 18, 2019 at 9:28 AM
    trackdaybro
    Nice! Yeah around 400lbs.
    Sweet thanks. What bike and where’d ya ride??
    FreshOldTaco[QUOTED] likes this.
  12. Sep 18, 2019 at 10:33 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Took mine in for 10k service and told them about the squeeky clutch pedal. They are going to replace the bushings it sounds like. Is that the normal fix (long term) or will it just start up again? Remember some talk about just lubing it up with a type of grease as a quick fix. As long as it's under warranty I'll have them deal with it for now.
  13. Sep 18, 2019 at 10:46 AM
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    White lithium grease has worked on mine for 36,000 miles so far
  14. Sep 18, 2019 at 10:49 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    They have just sprayed mine after telling me they can not repeat and I showed them in about 2 seconds. Let us know how the bushing replacement works. I actually told my service advisor they need to replace the dam clutch pedal with something not plastic. He didn't agree.
  15. Sep 18, 2019 at 10:50 AM
    GT_Charlie
    GT_Charlie Well-Known Member
    There's a TSB for that. They put the fix in my 2014 Taco shortly before I traded it, so I don't know how it worked out long term. I believe it's TSB number T-SB-0186-12.
    Charlie
  16. Sep 18, 2019 at 11:26 AM
    Aspen Thicket
    Aspen Thicket Well-Known Member
    Da U.P. of Michigan
    Considering a 2019 TRD OR manual...how bad is the rattle in neutral when coasting over bumps and between shifts?
    I live in an area of primarily bumpy gravel roads and have concerns with some of the threads on TW talking about manual transmissions rattling during the above mentioned conditions.
    TIA
  17. Sep 18, 2019 at 11:44 AM
    deusxanime
    MN
    I'll try to let you know in the thread. I've heard of greasing it and replacing the master cylinder I think, but not replacing the bushing. We'll see how it goes.
    Looked up the TSB and looks like it applies only through 2012 models. Mine is a 2019, so I wonder if they have a new TSB for newer model years. Obviously the "fix" from back then didn't work.
    Spare Parts[QUOTED] likes this.
  18. Sep 18, 2019 at 11:47 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    From the problems that get posted here about clutch pedal work at dealers and the TSB'ed one that I felt on a Lemon OR, I would not let a dealer touch it. Just poke your head in that area and think about a cheap tech at a dealer hamfisting it to get it done in an hour or whatever book time is.
    Disc brake grease first.
    Shellshock and pinochle like this.
  19. Sep 18, 2019 at 11:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    2nd Gens had a plastic master cylinder. The 3rd Gen was upgraded to metal. The master itself should be a problem for a few hundred thousand KMs.
  20. Sep 18, 2019 at 2:14 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Drove this guy last night. Every time I drive it I have to check the shift pattern. Not the fastest rig in the world, but still fun to drive.
