Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jan 6, 2020 at 7:24 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    ADM = accumulator delete modification basically takes an orificed puff box out of your hydraulic clutch line and restores true 1:1 clutch feeling.
    Gvsukids, Shellshock and Junkhead like this.
  2. Jan 6, 2020 at 7:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    You're welcome.
    Also, all dealer customizations noted toward the end of the OM can be done with the Carista app or TechStream. TS can be downloaded from my signature. With TS, you'll need a quality cable as an interface, like a Tactrix adapter.
  3. Jan 6, 2020 at 7:26 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I second the RWD LO only mod as well.
  4. Jan 6, 2020 at 7:35 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    First gear is nice and low, not quite a granny gear, but still works well and I feel is nice to have in a truck. Unfortunately it seems like second gear is still a pretty standard ratio and so there is a bit of a gap between the two. So you need to wind out first a bit before going into second, otherwise you end up bogging down a bit when you shift up into it. Not a big deal, just takes a bit of getting used to.
    Reverse on the other hand...:annoyed: Anyway, if you find R frustrating, especially if you tow/haul, then that is what the 2LO mod is good for.
  5. Jan 6, 2020 at 7:36 AM
    su.b.rat
    su.b.rat broken truck
    this little thing, spinning up the motor after 1st going into second, actually changed my life. this truck is not slow and doesn't bog at all if you drive it like a 3.5 and not a bigger motor.
  6. Jan 6, 2020 at 7:38 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I'm getting used to engaging reverse. I had a Jetta at one point, so that helps. Sometimes I'm pushing down on it when I just need to push over more.
    I also noticed I'm shifting a bit early. I'm used to going by sound, and I'm thinking 2k is sounding more like 4k. Just something to get used to like you said. 3k sounds like 6k in my other vehicles.
  7. Jan 6, 2020 at 8:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have found riding out 1st gear the best method too.
    Junkhead and su.b.rat[QUOTED] like this.
  8. Jan 6, 2020 at 8:11 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Welcome to the club:hattip:
    Other members have already versed you on the mods possible for your truck and I would like add one more.
    Short shifter. There are 2 options,
    the Core shifter ( https://core-shifters.com/collections/shifters-for-toyota-tacoma )
    and the Under Dog Racing shifter ( https://www.urdusa.com/urd-short-throw-shifter-2016-tacoma-3-5l-v6/ )
    The core shifter is a complete shifter with a new lever and base, while the URD unit is a mod to the factory base and lever.
    I have been running the URD unit for almost 2 years and am happy with it.
    TheCochese[QUOTED] likes this.
  9. Jan 6, 2020 at 8:13 AM
    shakerhood
    Southern Ohio
    Reverse location is not really an issue, the problem is it's geared like a highway gear, not good for backing uphill with weight in the bed or with a trailer.
  10. Jan 6, 2020 at 8:16 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    This might be odd but I find short shifting 1st smoother. I find the combination of the torque curve of the engine and first being low can be touchy and prefer getting into second and using it for a longer pull while accelerating in traffic.
    BigHam and skier like this.
  11. Jan 6, 2020 at 10:42 AM
    deusxanime
    MN
    Yep that is what I meant about R. Getting into it you learn pretty quick, but trying to use it without burning up the clutch (especially with weight in or behind the truck), is the true struggle.
    Junkhead and shakerhood[QUOTED] like this.
  12. Jan 6, 2020 at 11:16 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I wind up 1st gear to 3k rpm if i need to go quick 3.5k rpm and higher if i really need to rip it, but if im taking my time i shift around 2k rpm. I use second if my truck rolls forward even the slightest. It took me few months to be pretty quick and smooth with this tranny.
    The throttle response does not help, but ive learned to deal with it. In the beginning was a wtf moment.
  13. Jan 6, 2020 at 12:54 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    How do you fight the rev hang if your really want to rip it (3500-6k RPMs). The higher RPMs the worse the hang is. To the point where if I say f*ck it and just dump the clutch the tires chirp.
    Shellshock and Junkhead[QUOTED] like this.
  14. Jan 6, 2020 at 1:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You don't have to dump the clutch. Just pause the stroke briefly at the very beginning of the friction zone and it will bring the revs down.
    deusxanime, shakerhood and Junkhead like this.
  15. Jan 6, 2020 at 1:04 PM
    dr4g1116
    I've done that too. TBH hard to tell what will wear the clutch more.
  16. Jan 6, 2020 at 1:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    To me, it feels like it is barely engaging and quickly matches revs. In my mind, it is less wear than a dump and less shock to the driveline. When I do that, I can bare feel it.
    I don't have a video of that, but this was harsher than I would like:
  17. Jan 6, 2020 at 1:19 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    It took me some time to get used to, but i agree with what @tonered said. Just release clutch a bit slower, it is what is is.
    Ive dumped the clutch a few times when the tires chirp, but i just feel so bad when i do that, haha!
    shakerhood and tonered like this.
  18. Jan 6, 2020 at 1:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    No harm in a chirp from time to time, but I would not be happy chirping every time the revs hung up / every shift above 4k.
    Junkhead[QUOTED] likes this.
  19. Jan 6, 2020 at 1:38 PM
    dr4g1116
    Agreed.
    Most of the time I slow shift it. 2500 RPMs or so. Amazing how many drivers are up my ass when I'm shifting. We live in the city and you won't see speeds over 25 usually...calm down and stay off my ass.
    tonered[QUOTED] and Junkhead like this.
  20. Jan 6, 2020 at 1:49 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Everybody is in a rush nowdays.
    tonered likes this.
