Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 23, 2020 at 4:35 PM
    gut
    gut Active Member
    91 Toyota pickup .. 89 Toyota pickup
    I’m assuming you would suggest to do the ovt tune and the other thing I see mentioned amd ..
  2. Apr 23, 2020 at 4:38 PM
    BigHam
    BigHam dɹǝp
    Hey @gut, my truck is the first manual vehicle I've owned and only had a handful of experience driving stick prior to buying it.
    The truck is relatively easy to learn on and pretty forgiving for a newcomer, in my opinion. I bought an OR so I don't have the hill start assist, but starting off on steep inclines is an art form that you'll get the hang of eventually that even after 2.5 years I haven't mastered. Two things that I intend to do in the future are the OVTune and accumulator delete when I get a little more consistent with my footwork.
    Who knows, you could master it within a month. Or you could roast the clutch on your first try, but that's why they're replaceable!
    Junkhead, AKGSD, gut and 1 other person like this.
  3. Apr 23, 2020 at 4:47 PM
    Beemaster
    Beemaster Well-Known Member
    Stanley
    California
    2016 Silver Tacoma TRD Sport 4x4 6MT
    If I can find an excuse to change gears I do it. It’s the little things.
    Auzea, C41n, Junkhead and 5 others like this.
  4. Apr 23, 2020 at 5:08 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I‘ve not installed the adm, so i can’t comment on that. I actually would not recommend the ovtune as you’re learning, because the stock tune is much more forgiving on launch.
    I know on BMWs their accumulators were designed to slow clutch operation for beginners, so keep that in mind as well
    Junkhead and tonered like this.
  5. Apr 23, 2020 at 6:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think accumulators might be a good idea for a newbie for about the first week of daily driving. After that, I feel that it would teach bad habits and hide faults.
    In the end, a week of so-so shifting is not going to ruin a clutch as much as years of bad muscle memory and the ensuing extra slippage.
    Junkhead, C41n, AKGSD[QUOTED] and 2 others like this.
  6. Apr 23, 2020 at 7:22 PM
    ryan_tx
    ryan_tx Well-Known Member
    Tucson, AZ
    2018 TRD OffRoad MT
    Does double clutching do anything on these unless you're shifting to first? I always thought double cluthing was just for older transmissions and for semis to get your gear up to the speed of the driveshaft. These trannys have synchronizers to get them up to speed
  7. Apr 23, 2020 at 7:24 PM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I believe 1st and 2nd are even triple synchro'd.
    Junkhead likes this.
  8. Apr 23, 2020 at 7:57 PM
    ryan_tx
    Tucson, AZ
    2018 TRD OffRoad MT
    Even on first huh? Shows how much i know about what's going on
  9. Apr 23, 2020 at 8:10 PM
    gut
    gut Active Member
    What’s that mean?
  10. Apr 23, 2020 at 8:57 PM
    deusxanime
    MN
    Swear I read it somewhere, but now can't find it. But the idea was the extra synchros make the shift smoother and easier, especially in the lower gears since they tend to be harder to hit.
  11. Apr 23, 2020 at 9:15 PM
    mict450
    mict450 got heel toe?
    northeastern California
    2017 TRD Sport AC MT BBP
    Double clutching is slightly faster, especially if you skip gears or if your revs in the lower gear is quite a bit higher than your higher gear. It'll spin up your intermediate shaft so it feels like the stick gets literally sucked into the lower gear. You'll note if you single clutch in the above situations, there's a slight delay since you have to wait a slight amount for the synchro to do their job.
    But the best thing I like about DC'ing is the symmetry of the movement of your feet...one goes in while the other comes out. Can't really describe it better than that. But like I said, not really necessary, but another tool in your tool box. Plus, it's fun to do! Just my own opinion, of course. But OP, you're quite a ways removed from learning this stuff. Stick with the basics. Later if you want, come back & we can discuss the "other stuff".
    Junkhead and SilverBulletII like this.
  12. Apr 23, 2020 at 9:20 PM
    mict450
    This could be true, maybe....this is the ONLY vehicle I've been able to shift into first while moving. I'd hafta be pretty much at a dead stop to shift into 1st on any other.
  13. Apr 23, 2020 at 9:28 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  14. Apr 23, 2020 at 9:45 PM
    deusxanime
    MN
    Thanks! So multi-cone synchros for 1, 2, and 3.
    Holy crap though, look at those gear ratios on the Hilux version. I want those! Improvements in basically every gear, especially 1, 6, and R.
  15. Apr 23, 2020 at 9:50 PM
    shakerhood
    Southern Ohio
    Somebody on here was in the process of swapping one into a Tacoma, should be awesome when he is done.
    AKGSD, specter208, Junkhead and 2 others like this.
  16. Apr 24, 2020 at 1:24 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I agree... Get someone to help get it home. Once there you can take your time. A bit of practice is all it takes... you'll gain a skill you will will not regret...
    Enjoy your manual Transmission. It is a dying breed... If/when I get the Tacoma, it will be my very very last ever Petro-fueled vehicle. (other than our classic mini cooper!) - The other 'real' car is Electric. All future ones most likely will be as well... No MTs on EVs... In fact - no transmissions at all!
  17. Apr 24, 2020 at 4:41 AM
    OZ TRD
    Central Coast CA
    Interesting... Do you know who that was? I wonder if it is a straight bolt-on... or is there a huge amount of modification required?
    I could get my hands on a Hilux 4x4 6sp MT from a diesel Hilux. Those are used to much higher torque...
    shakerhood[QUOTED] likes this.
  18. Apr 24, 2020 at 5:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @Jowett and @RedBeard1 have messded with these in the past. @Jowett has an active thread.
    shakerhood likes this.
  19. Apr 24, 2020 at 5:46 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I'm very close to dropping out the stock transmission to compare it.
    AKGSD, specter208, OZ TRD and 3 others like this.
  20. Apr 24, 2020 at 5:59 AM
    MtnAltitude
    MtnAltitude AKA: Grump-a-saurus
    Colorado Mtns
    2020 Tacoma TRD Pro AG, 1971 FJ40 - all MT
    If you can figure that out let me know. I worked on that for almost a year and had several conversations with Toyota International. I found where I could get one, I also looked at the LC-76 that is still built. We can get them in the US but you cannot license them. The diesel is not the only problem yet it has better emissions than any diesel in the US, it is safety issues, airbags and other metrics required in the US that other countries do not require.
