Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Apr 16, 2016 at 3:23 PM
    #1161
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Depends. Sometimes as low as 2k RPM or as high as 3k. If on the lower side, I've found I just have to be a little slower with shifting and releasing the clutch to keep things smooth.
    Also, if shifting low there are a lot of clunking sounds going on. Apparently it is normal.
  2. Apr 16, 2016 at 10:46 PM
    #1162
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    Totally normal. Every stick I've driven did this at one time or another. Don't let the clutch out with the shifter halfway in or you'll get grinding. All you need to do is pop it into 2nd and then back to first or pull it back to neutral, let the clutch out for a second, then push the clutch in and pop it into 1st. It may get better after you've driven it for a while, but it's the nature of a stick.
  3. Apr 16, 2016 at 11:19 PM
    #1163
    Syncros
    Syncros Well-Known Member
    Meh. I just give it a little rev and it will slide right in.
  4. Apr 17, 2016 at 5:22 AM
    #1164
    Sil
    Sil Of the Earth
    Georgia
    2017 Tacoma SR MGM i4 5 speed 4x4 aka. Vulcan
    Pending..
    This is what works for me I also let the clutch out a bit and let it slide in.
    Another thing I do at long stoplights is leave it in neutral check the other lights for yellow, shift into first, and by the time it turns green your ready to go.
    Just drove 1500 miles and did not skip a beat, and no stalls, grinding, or stuck in gear. Manual FTW!
  5. Apr 17, 2016 at 5:27 AM
    #1165
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    Wow that is a long time. At first I got low mpg maybe 19ish mixed use, but after this trip I got close to 23 on the hwy between NC and Ga i85
  6. Apr 17, 2016 at 7:02 AM
    #1166
    harryk
    harryk Well-Known Member
    Maryland, near Chesapeake Bay
    2016 Tacoma V6, MT, 4WD, Blue
    First, the good news (I think):
    I'm getting 20 mpg in mixed suburban driving, hilly, stoplights, speeds up to about 55 mph on occasion, some stop and go driving, this on my V6 Taco with manual transmission. Got 23 mpg yesterday on I-66 going west at 70-72 mpg.
    Now, the "I dunno" news. Truck wouldn't start a couple of times, error message whining about brakes, but I think I figured it out. Seems the floor mat shifted and a corner of it slipped to where it interfered with the clutch pedal reaching the floorboard when I pressed it down. Does this seem possible? Once the got the mat out of the way, and I could "bottom" the clutch pedal, the problem seems to have disappeared.
    Guesses?
  7. Apr 17, 2016 at 7:05 AM
    #1167
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Yep. All Toyota manual trucks have a clutch switch. It requires the clutch to be ALL the way to the floor to start. That is what that little button you have on the left side of the steering wheel does. Clutch Start Cancel. Push that button an you can start it with the clutch not pushed.
  8. Apr 17, 2016 at 7:09 AM
    #1168
    harryk
    Ahh, thanks. I learned to drive on a '32 Ford truck and a postwar jeep, neither of which had such "fancies." The jeep didn't even have a heater. :)
  9. Apr 17, 2016 at 7:27 AM
    #1169
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    1-2 at 2300 for me and no trouble. First is really high I guess for pulling?
    I figure shifting high in this engine should be okay. It is a modified Lexus IS 350 engine right?
    The reason you like it... Because manual.
  10. Apr 17, 2016 at 7:44 AM
    #1170
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I learned to drive on a stick.
    Love them.
    For 1st to 2nd grinds,slow down on your shifts.
    It's a truck,not a Porsche.
  11. Apr 17, 2016 at 7:49 AM
    #1171
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Should be able to shift as fast as you want.
  12. Apr 17, 2016 at 12:40 PM
    #1172
    Skippydog
    Skippydog Active Member
    2016 trd sport double cab long box
    Ok I need some advice.... I have a 3rd gen automatic now....I was not impressed with the automatic at first with the constant gear hunting. I have the truck figured out now with using the sport mode and ect etc. My big complaint is cruise, the constant downshifting on the slightest grade. I'm wanting to trade it in for a manual. My question is....is the manual that much better to drive? is it worth taking the financial hit? I had a 2004 with the 5 speed and loved it. I'm worried about the higher rpm's on the highway with the manual..any input would be appreciated. Hopefully somebody that has a little bit of experience with both can chime in..Thanks !!!!
  13. Apr 17, 2016 at 12:44 PM
    #1173
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    If your auto is downshifting constantly, you'll arguably be running lower RPM's on the freeway. Put it in 6th, set cruise and roll out!
  14. Apr 17, 2016 at 12:45 PM
    #1174
    nevadabugle
    Elko, NV
    I like mine on the highway. I put it in 6th set the cruise at 75 and just go. I down shift to 5th for the long steep grades and it maintains speed fine.
  15. Apr 17, 2016 at 12:47 PM
    #1175
    ex4runner
    ex4runner Well-Known Member
    Pat
    Central New York
    BLK '16 TRD OR DCSB 6MT
    Dipped and De-badged
    Does anyone know if the MT weathertechs are coming? still not showing on their web site and I am supposed to have my DCSBTRDOR next week. I had the Huskeys in my 4Runner and they were good, however the fit on the fronts, at the door sill, was not great with about a 1/8" gap. I have seen the WTs and I always wished I got those instead...I really would like some WTs for my MT.
  16. Apr 17, 2016 at 1:55 PM
    #1176
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I got the Huskeys for my MT and have been very pleased, lots of overlap, good coverage. Mud earlier this week, lots of snow and slush today. Have months of snow and slush on these and couldn't be more pleased.
    truckstrada likes this.
  17. Apr 17, 2016 at 2:56 PM
    #1177
    Skippydog
    What do you rev at 75?
  18. Apr 17, 2016 at 3:24 PM
    #1178
    nevadabugle
    Elko, NV
    I have 265/75 R16's and this makes it exactly 2500 RPM. It was slightly higher than that with stock tires.
  19. Apr 17, 2016 at 4:26 PM
    #1179
    Kiwi fella
    Kiwi fella Member
    Phil
    Calabasas
    2015 double cab 4x4 TRD tacoma
    None yet
    From NewZealand where 80 percent is manual and you won't find an auto highlux , to get an auto there cost more and special order, when it came to finding a manual v6 taco I was gob smacked.... Hate autos
  20. Apr 17, 2016 at 4:32 PM
    #1180
    ex4runner
    Pat
    Central New York
    Thanks for the quick response! I really liked mine but they just wouldn't sit flush on the door sill. Do your huskey's fit flush?? I always wondered if I just got a bad set.
    Thanks
