Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 23, 2015 at 10:01 PM
    #101
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Well excuse me for not updating you on my status. I'm not running a lift any longer and the truck is back to stock suspension. I've got smaller tires that are better suited to the truck. Still bigger than stock but nothing out of the ordinary. I see lots of Toyotas around town with similar wheels and tires. The braking and steering is perfect and I have just the ever so slight vibration at 31mph. Nothing I can't live with and something I'll have the dealer look at when I get the oil changed.
    What can not be understated is that the 4 cylinder is just that, a 4 cylinder.
    Again, my apologies for not updating you.
  2. Dec 23, 2015 at 11:04 PM
    #102
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Note...switches not stock
  3. Dec 24, 2015 at 4:24 AM
    #103
    DeiselDave12
    DeiselDave12 Active Member
    Josh
    2016 Super White TRD Off Road DC SB 4x4 M/T
    Stock... For now...
    Actually I believe we only loose 1 cup holder. Where we have 2 cup holders the auto only has 1 (Their gear selector is in our second cup holder location), and where the auto has 2 cup holders we have none. Therefore there is a difference of 1 cup holder.
  4. Dec 24, 2015 at 5:21 AM
    #104
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Thanks! I really appreciate you taking the time to take the picture. Did you get your mirror through RJP869? That will be one of my first add-ons, and I really don't understand why Toyota decided to include it only on the limited. My 14 Baja has it...
  5. Dec 24, 2015 at 5:21 AM
    #105
    mojavejohn
    mojavejohn Well-Known Member
    Mojave Desert, Ca
    2018 Dbl. Cab Off Road MT
    Is that a homelink mirror? If you didn't get it stock, they must sell them aftermarket? How much?
  6. Dec 24, 2015 at 5:22 AM
    #106
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Thanks! I appreciate it and love the switches.
  7. Dec 24, 2015 at 5:26 AM
    #107
    mojavejohn
    Mojave Desert, Ca
    What kind of mileage are you guys getting in the manual? I saw 18.1 posted a couple of times. Is this fairly typical?
  8. Dec 24, 2015 at 5:35 AM
    #108
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Interesting... I can do 100mph no problem. Same drive train as you...245/75/16 Michelins and TRD FJ wheels.
    ...seems your wheels and tires are the issue, must be heavy as sin
    nevadabugle[OP] likes this.
  9. Dec 24, 2015 at 5:40 AM
    #109
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    The mirror is out of my Subaru Outback I traded in for the truck, bought it online from a dealer that runs a discount parts service, can't remember which one off the top of my head though. Same as the Limited one but the compass is red. Thanks to the way Toyota wired the harness there's always power so I'm no longer cycling that stupid compass off everytime I start the truck.
    mojavejohn[QUOTED] likes this.
  10. Dec 24, 2015 at 6:23 AM
    #110
    nevadabugle
    Elko, NV
    Is there truth to this. I have skipped gears for different reasons on other manuals without ill affect. But I have always heard that it might cause problems. What's the consensus?
  11. Dec 24, 2015 at 6:25 AM
    #111
    nevadabugle
    Elko, NV
    18 is what I am averaging in mine with 265/75 r16. Click on my fuelly badge for the details. Best tank has been 19.8. Worst 15.
  12. Dec 24, 2015 at 6:30 AM
    #112
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Yes, synchros are made to go from 2 to 3 and 3 to 2... not 5 to 3 or 4 to 2...
    If you insist on doing so, make sure to you actually row the shifter through the gears you're wishing to skip over...
  13. Dec 24, 2015 at 6:31 AM
    #113
    forty2
    Cascadia
    2016 DCSB OR 6MT
    If your matching revs* it won't make a damn bit of difference. If you rely on syncros to do the work of making the revs climb on the input shaft then yes, you will absolutely wear them out faster by skipping gears. Well, it actually depends on how much they need to climb, but say your dropping sixth to third at 60 for a passing lane opportunity without blipping the throttle, that's going to hurt the syncros quite a bit. Slowing from 60 to 10 and going slowly from sixth to second with a long pause at neutral won't do a damn thing. It's all about not forcing the syncros to match the revs.
    *and double clutching
    Edit for clarity - spent a lot of time in non-syncro large trucks in my youth
    jviffer, Doggman and RedBeard1 like this.
  14. Dec 24, 2015 at 7:02 AM
    #114
    pino
    pino Well-Known Member
    I don't need to be updated, I notice your posts on this topic regularly enough. You posted twice yesterday about not being able to go above 65mph. That's not a subjective issue or me picking on you, that's a serious problem with your vehicle. If you post about it publicly and regularly enough, some people may comment.
  15. Dec 24, 2015 at 7:50 AM
    #115
    DakotaTacoma
    DakotaTacoma Well-Known Member
    So. California
    1996, 2.7, 4x4, 5-speed, extra cab
    3" Downey lift, K and N FIPK, NWOR Try Y header, 31x10.5 BFG KOs
    Not an OR, but here's a Sport. Probably similar. Showing close up of switches. From the Quicksand thread:
    Can't wait to get my new MT Sport :)
  16. Dec 24, 2015 at 8:06 AM
    #116
    nevadabugle
    Elko, NV
    Thanks for the info here. Good stuff.
    Isn't this discussion about honing our shifting skills? The reason we all like manuals is it gives us options on shifting patterns and strategies. Sometimes to hone skills takes some questions to be asked.:notsure:
  17. Dec 24, 2015 at 8:10 AM
    #117
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I like manual shift so much I added 3 more sticks.
    wmeyer116, WBF610, matt 157 and 2 others like this.
  18. Dec 24, 2015 at 8:50 AM
    #118
    nevadabugle
    Elko, NV
    My point was shifting more or shifting less is why we I like manuals. I choose.
  19. Dec 24, 2015 at 8:51 AM
    #119
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Rev matching and heal toe are related, but not the same thing. I rev match all the time in pretty much everything I drive, be that Tacoma, S2K, or dump truck.
  20. Dec 24, 2015 at 8:55 AM
    #120
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    :wave:
