Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 1, 2021 at 10:42 PM
    MRMcTaco
    MRMcTaco Member
    Huntsville, AL
    2001 Tacoma 4x4, 4ycl, 5speed, FOR SALE (dm me)
    Bilstein 5100, Bastard pack leaves 235/85/16 tires Rebuilt title (lower insurance :P ) Evap delete
    If you aint bouncin' off the rev limiter you're doing it wrong :bananadance::kona::jellydance: jk, dont listen to me.
    Vala[QUOTED], Junkhead and CygnusX191 like this.
  2. Dec 2, 2021 at 5:42 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    Hey OP - welcome to TW! Like many things in life, it depends. The spread and overlap of the gearing is not uniform. So, it depends on which gear you are shifting from/to. I tend to rev it higher (~3000 RPM) going from 1st to 2nd than from 5 to 6 (2250-2500 RPM) for example. Don't obsess on the tach, let the feel of the truck guide you. It knows!
    Vala[QUOTED], Junkhead and deusxanime like this.
  3. Dec 2, 2021 at 7:00 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    For regular everyday driving I shift 1->2 and 2->3 at around 3000. 3->4 and up is more around 2500. If I feel the need to scoot away from a stoplight I'll shift 1->2 closer to 4000. And if I want to have a little fun I run 2nd up to 4500.
    Vala and CygnusX191 like this.
  4. Dec 2, 2021 at 7:26 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I've never actually looked :anonymous:
    I shift at whatever feels good at the time. Low, high, I don't get caught up in the numbers. I shift by conditions, mood, Mercury in retrograde, who knows.
    mict450, MRMcTaco, sdshack and 9 others like this.
  5. Dec 2, 2021 at 8:04 AM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    Definitely, go by what feels right for your zodiac sign or whatever. But when I do happen to glance down at the tac, my shifts are happening near those numbers I mentioned above.
  6. Dec 2, 2021 at 8:07 AM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    Also just noticed you're driving a 2nd gen, so probably disregard my 3rd gen shift points... I've never driven a 2nd gen :anonymous:
    Vala[QUOTED] and CygnusX191 like this.
  7. Dec 2, 2021 at 8:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks @StandardTaco for pointing that out.
    @Vala . There is a TSB update out there for your Taco, if your a 4.0l. TSB-0110-14. It makes a world of difference.
  8. Dec 2, 2021 at 8:39 AM
    Vala
    Vala You don't make friends with salad
    Ontario
    2013 TRD Sport
    Yes its a 4L 6cyl. is this something i can do at Toyota?
    CygnusX191 likes this.
  9. Dec 2, 2021 at 8:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    They certainly can, but if it is out of powertrain warranty, it might cost you?
    Junkhead, Vala[QUOTED] and CygnusX191 like this.
  10. Dec 2, 2021 at 10:01 AM
    Vala
    Ontario
    2013 TRD Sport
    its closing in on 200k km so definitely out of warranty. I guess ill call them for an estimate and run it by my mechanic as well. Thanks Tonered!
    CygnusX191, Junkhead and tonered like this.
  11. Dec 2, 2021 at 10:01 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    It takes 10min of actual time to do the TSB updates.
  12. Dec 2, 2021 at 3:04 PM
    MRMcTaco
    MRMcTaco Member
    Huntsville, AL
    Im an old fogey, I shift low and dont drive over 55. Ive heard good gas mileage only comes from driving over 3000rpm in our trucks, but Ive got HEAVY 32s and never shift past 2500 and I get a CONSISTENT 21mpg in town.
    4.30 gears
    /).- Im a first gen tho. :facepalm:
  13. Dec 2, 2021 at 5:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I get similar. I basically hoon corners if they're clear and drive normal otherwise.
  14. Dec 3, 2021 at 9:37 AM
    Kronan49
    Kronan49 Well-Known Member
    Ronan
    2020 Tacoma Trd Pro 6M
    Hey lads just wondering whats the best tune for manual? I have a chance to get kdmax pro, wondering what everyone's thoughts are on it or if I should possibly looked into a different one.
    Thanks
  15. Dec 3, 2021 at 9:41 AM
    su.b.rat
    su.b.rat broken truck
    KD Pro is by far the best i've tried for the MT. but i had mine tweaked a bit to make it drive right for me and that made it my current tune of choice. i've been a huge Coyoza fan, and used a few older versions of KD before that. the Pro tune is a big step forward. more filled out and consistent than Coyoza, easier to drive all around, less peaky and inconsistent with throttle and power.
  16. Dec 3, 2021 at 10:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a locked vF Ultimate test tune that I cannot get away from, other than wanting to run the YotaWerx S/C beta tunes on my N/A for longer than a handful of miles.
    CygnusX191 and Shellshock like this.
  17. Dec 3, 2021 at 12:23 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I probably need to update my 2 year old SFOB tube, it runs great but still falls flat in 2nd a bit.
  18. Dec 3, 2021 at 12:30 PM
    Kronan49
    Ronan
    Anyone have experience with the tunes in 4 lo?
    I do quite a bit of offroading so I'm curious of what it does for that
  19. Dec 3, 2021 at 12:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Ultimate tune might be out early-ish next year.
    :fingerscrossed:
  20. Dec 3, 2021 at 12:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The vF tunes make wheeling nice. A bunch of extra torque, control, and consistency. 1st gear DFCO is still being worked on though.
    I can creep over stuff the way that I want to.
    Shellshock and CygnusX191 like this.
