Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 3, 2021 at 1:06 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Worth it. Makes crawling even better. Almost never kill it
    :bananadance:
    Can confirm
    tonered[QUOTED] likes this.
  2. Dec 3, 2021 at 2:00 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Please DO tell!
    Where, who, what, How??
    CygnusX191 and tonered[QUOTED] like this.
  3. Dec 3, 2021 at 2:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This is from the vF Forum:
    That was in response to some pitchforks that were coming out, but good info.
    This is about all that we know about Ultimate other than folks who were given the test tunes:
    https://www.tacomaworld.com/threads...al-development.495735/page-3553#post-25506365
    CygnusX191 likes this.
  4. Dec 3, 2021 at 4:19 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  5. Dec 3, 2021 at 8:53 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    I really like Valley Runner, but it is also the only tune I have tried. I can accelerate from under 20 mph in 4th gear with the tachometer showing a hair under 1000 rpm on a low grade (guestimate about 3%) so I feel like that is good torque down low. That said, it is not a powerful acceleration and you can tell the engine is at a lower rpm than it likes.
  6. Dec 4, 2021 at 12:51 AM
    TerdFergy
    TerdFergy Active Member
    20 TRDOR MT
    Toytec 2.5 coilovers
    Curious what mods you had done? Getting ready to pull trigger on Pro for my G3 6MT.
  7. Dec 4, 2021 at 4:12 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Sadly I keep asking about when the tune pack files for 3GR-FKS will be updated with the latest knowledge for current customers on facebook whenever they post their marketing updates, and was told that not only is there no current plans for those tune pack files to be updated but that customers seem to think free updates means forever.
    Take that as you will. Unless they deleted the comment it is still up on fb if you want to verify...I could find it and copy/paste if you need me to.
    Needless to say I was kinda crushed. I've been waiting for a year (or longer?) for those files to be updated with the latest tune knowledge and new areas of the ECU they have opened now, so that "SFOB 2.0" can be updated. Wondering if they get so much money from coyoza/kdmax licensing that they don't want to produce a tune that would compete? Why did I purchase the tune pack for $300 or was it $350 for a single file back then if it isn't ever going to be updated?
    /sorryforwhining
  8. Dec 4, 2021 at 6:56 AM
    su.b.rat
    su.b.rat broken truck
    the main things that relate to the tune are solid motor mounts and a custom free flow exhaust with dump tubes. but i have lots of other stuff going on, just not all drivetrain.
    https://www.tacomaworld.com/threads/daves-drivers-truck.659667/
    CygnusX191 and daveeasa like this.
  9. Dec 4, 2021 at 8:03 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm not sure what to tell you other than the MT tunes were considering to be complete. I feel that this Ultimate thing is bonus time for us and will be grateful to get it whenever it happens. I have other feelings on the AT side, but that is a different story.
  10. Dec 5, 2021 at 4:56 PM
    TerdFergy
    20 TRDOR MT
    Fantastic build. I was wondering what tweaks you had done to the tune?
  11. Dec 5, 2021 at 5:39 PM
    su.b.rat
    the throttle efficiency target map was adjusted to sharpen the release on throttle lift, and this was the main thing i needed to keep running this tune. that had the minor side effect of losing some of the overall smoothness, but that's more how i like it to drive anyway. I'm now running a second adjustment to cylinder filling to alleviate a gas smell on idle, and I've run rich on all these tunes, so this is nice... truck seems to run better but it's still early days. I'm comparing 3 adjustment levels on 3 different tune files right now. Kreg's service is above & beyond.
    TWTaco, PapaRee and CygnusX191 like this.
  12. Dec 12, 2021 at 8:17 PM
    p_sando
    p_sando Well-Known Member
    utah
    2020 DCSB TRD OR 6MT
    I scratched my shift lever so I want to remove it and see if I can touch up the scratches.
    Has anyone removed their shift lever before? From what I've read:
    1. Remove shift knob
    2. Pop out center console assembly and pull the assembly and boots over the shift lever and e-brake lever
    3. Remove 2 screws + 2 plastic clips from rubber shift boot
    4. Press down on metal shift lever collar and rotate counter-clockwise to free shift lever
    5. Reverse steps when done (?)
  13. Dec 16, 2021 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  14. Dec 27, 2021 at 3:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I finally felt it! :D
    It was 20F leaving work today and I finally felt the slow clutch. I'm sure we had at least one similar day in the past four years, but I don't recall that feeling. Even at a stoplight up the road, it was still slow. No issues with the clutch slipping, so that's good.
  15. Dec 27, 2021 at 3:37 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Hahaha..hahaha...lulz...hehe
    BWAHAHAHAHAHAHAHA!
    Tween December and March, we typically call that Tuesday
    Now you know, the struggle is real...but ya, there is no slippage at all as a result.
  16. Dec 27, 2021 at 3:43 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm not to thrilled with these temps. I almost have to put the flip flops away.
    I couldn't imagine dealing with real winter weather again.
  17. Dec 27, 2021 at 3:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Hm interesting. We are at 15F right now now and I haven’t experienced the slow pedal yet.
  18. Dec 27, 2021 at 3:47 PM
    TeecoTaco
    SW Ontario
    LA Nïna...enjoy!...I'm sitting at 37ish this week
    Haven't had sub 32F yet really
  19. Dec 27, 2021 at 3:52 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I got in my truck this morning, pushed in the clutch to start it, and it didn't raise when lifted my foot!!! I pushed back down and started cycling it until it started moving... first time it has done that!!! Clearly temperature related...
  20. Dec 27, 2021 at 3:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This was my first time. I know we have seen slightly colder temps in the past 4yrs. Also, folks say that they have felt it at much higher temps.
    Just a thing.
    CygnusX191 and Junkhead[QUOTED] like this.
