Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 18, 2023 at 9:01 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Everything is looking very promising for the 4th gen manual so far. I hope if it's the same gear box they at least tweaked the ratios. I'll be very curious to see some driving impressions and maybe some day I'll get to try one out myself.
    CygnusX191 and doublethebass like this.
  2. May 18, 2023 at 9:13 PM
    Shellshock
    Iowa
    Yup they said you can toggle iMT / stall assist
    Also if you get the manual, you get a ton of storage space you don’t have on the hybrid cuz the battery is under the rear seat
    And peak torque at 1700 rpm.. instead of 4600..
  3. May 18, 2023 at 9:18 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t think it’s the same gearbox, the Sheldon brown guy mentioned a new bellhousing and a cable. The new bellhousing doesn’t mean much but the cable does. I doubt they reused the same trans and applied cable shifting to it, but I suppose it’s possible. I do hope like you that the ratios are tweaked.
    personally I want only 1 OD (.70) and then a better 1-5 spread with 1 being about 4:1 and 5 being 1:1. Nice low R of like 4.5-5 would be great. Hopefully 4.30s still.
    if the ratios are good (for V6 also), it would be sweet if we could buy that trans and put our bellhousing on it and roll. But if it’s cable shifted that will be a problem unless our shift tower could somehow still attach.
    CygnusX191 and GBR[QUOTED] like this.
  4. May 18, 2023 at 9:21 PM
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Wonder if they did anything with the high reverse gear.
    Anything more than a gentle slope backwards and its a lot of clutching to reverse unless you go into 4LO (or do the 2LO mod).
  5. May 18, 2023 at 9:26 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’m reasonably confident there is something about the 4th Gen MT we can agree to dislike :)
    BC Hunter, StandardTaco, Firn and 4 others like this.
  6. May 18, 2023 at 9:29 PM
    GBR
    19 TRD OR
    Good catch on the cable, hadn't seen that yet.
    Honestly after years of ownership, my biggest beef with the 3rd gen ratios is 2nd gear. At least R can be mitigated with the 2LM. The ODs are too close together and I agree only one OD is really needed.
    CygnusX191 likes this.
  7. May 18, 2023 at 9:34 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    yeah hard to argue with that
  8. May 18, 2023 at 9:40 PM
    Shellshock
    Iowa
    I’m sure someone will complain about the trim they can’t get it in
  9. May 18, 2023 at 9:48 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I love how everyone's complaining about the push button start of the manual, like that hasn't been in the off-road premium for the last 3 years already... Come on guys. Lol
  10. May 18, 2023 at 11:58 PM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Bah still the same ugly knob though. First thing to replace!
    Yes, finally! Hopefully remote start and keyless entry too.
    Interesting. Didn't they say that they couldn't do pushbutton because of the CSC? Seems they found a solution...
    Pro is the high end with the best engine, which for this will be the hybrid. And since no MT on the hybrid, no MT for the Pros. Kind of sad, but understandable I guess.
    Did they release the power/torque band info on the new drivetrains? I was wondering if they improved that so you don't have to wind the thing out to get good torque out of it. If they improved that and the gear ratios, I'm going to be awfully tempted.
    Huh? No pushbutton on any 3rd Gen MTs, including OR with the Premium package, unless I'm reading wrong what you are trying to get across here.
  11. May 19, 2023 at 12:32 AM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    For those in that market, it appears that they are going BACK to the mentioned Xtra cab, and losing the access doors to the back of the cab. Having had that configuration on my old '90 SR5 wasn't the end of the world, but I'd have loved to have an access door to get to the back. I might be mistaken, but that's what I saw in the video, and if that is the case, I think it's a poor decision on Toyota's part.
    TartanEagle and CygnusX191 like this.
  12. May 19, 2023 at 4:50 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Ummm, sorry, that is incorrect, there were exactly zero 3rd Gen Tacomas with manual transmissions produced with a push button start. Personally I prefer the old-school key; we've had two cars now with 6MT and push button start, and I'm so happy my Taco has a key.
    BC Hunter, shakerhood, OZ TRD and 4 others like this.
  13. May 19, 2023 at 4:50 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    A cable shift version of the RC transmission already exists, the RC60J, and sees use in the Hiace Van. The older RA also had a cable shift version that was designed and sold to Porsche for the normally aspirated 911/997 generation.
    With a little luck, we’ll see RC60 ratios…. and the parts supply to convert the gen 3 will be USA sourced!
    Ratios:
    • First Gear: 4.784:1
    • Second Gear: 2.423:1
    • Third Gear: 1.443:1
    • Fourth Gear: 1.00:1
    • Fifth Gear: 0.777:1
    • Sixth Gear: 0.643:1
    • Reverse: 4.066:1
  14. May 19, 2023 at 5:05 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Toyota likely kept that dildo shift knob because they saw how many TRD shift knobs they sold. Aftermarket guys will be happy too.
  15. May 19, 2023 at 5:24 AM
    BLtheP
    Plano, TX
    That is great to know. Maybe they will give us those ratios….would keep me from having to go down the Hilux swap road which I pretty much have in the plans but really don’t want to deal with. As long as the input shaft is the right length in the new gen, it would be great. Though I’d prefer the RC61F over the RC60F but I would take either over the RC62F.
    that is the only other thing I want to do drivetrain wise since I have 5.29s.
  16. May 19, 2023 at 5:44 AM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    Nonsense.
    When I got my 128i @ 30k shifting felt "notchy" and less than smooth; drained/refilled the tranny fluid - the old stuff was light grey and gross. Once changed, it felt much better/smoother. To this day feels fine @101k now.
    Probably time to change it again but zero issues.
  17. May 19, 2023 at 6:22 AM
    Shellshock
    Iowa
    All I’ve seen so far is the power & torque number with the rpm it peaks for each drive train
    Yeah there’s never been push button on MT 3g tacos. Not sure what @CygnusX191 is smoking.
    doublethebass and CygnusX191 like this.
  18. May 19, 2023 at 6:46 AM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    Since this group has been so helpful.
    What motor oil ya’ll running? I am thinking of going to Mobil 1 Extended or Royal Purple performance.
    Also thinking of going Amsoil for the trans and diff.
  19. May 19, 2023 at 6:47 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Second the amsoil stuff. Put it in your t case too.
    TartanEagle likes this.
  20. May 19, 2023 at 7:04 AM
    Shellshock
    Iowa
    amsoil all the things in mine
    TartanEagle, 6MTPro and CygnusX191 like this.
