Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 19, 2023 at 7:05 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Ugh, Scamzoil, no thanks, you can't pay me to use their products.
  2. May 19, 2023 at 7:06 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    We know
    CygnusX191 likes this.
  3. May 19, 2023 at 7:09 AM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    Redline? Royal Purple? Space Goo?
  4. May 19, 2023 at 7:10 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Either OEM toyota or LM with Molygen (the green stuff) for engine and red line for everything else. 170K kms on 2018 and zero issues with the engine, everything else is falling apart while trying to keep those 37s rolling tho…
  5. May 19, 2023 at 7:31 AM
    Firn
    Firn Well-Known Member
    White OR
    Personally I think SAE has defined motor oil so well that anything that meets the required specs is more than good enough.
    For the transmission make sure you use the right oil, I believe Toyota demands a different spec than used in the differentials (spec, not just viscosity)
    Worth checking the owners manual but I found this thread that talks about it a little bit
    https://www.tacomaworld.com/threads/how-to-6-speed-manual-transmission-oil-change.287566/
  6. May 19, 2023 at 8:22 AM
    Horseshoez
    Dale
    Maryland
    Of that group, Redline.
  7. May 19, 2023 at 10:29 AM
    Shellshock
    Iowa
    Which 2024 Toyota Tacoma trims come with the six-speed manual gearbox?
    • SR (Double Cab only)
    • TRD Sport (Double Cab only)
    • TRD Off-Road (Double Cab only)
    shakerhood and CygnusX191 like this.
  8. May 19, 2023 at 12:44 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I was hoping for a DCLB with the manual but I am almost sure I will be dissapointed again
  9. May 19, 2023 at 12:59 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Interesting. SR MT was what I wanted to buy back in 2020 if it could be had with SX around 28k. That's what I spent on my '16 OR used, it's my general price point of interest.
    I'm not sad I got 4wd now that I've moved to the PNW where it snows though. But I didn't need it for San Diego.
  10. May 19, 2023 at 1:10 PM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    Seems like that's the configuration everyone wants, yet it's the one they won't offer :frusty:
  11. May 19, 2023 at 1:16 PM
    daveeasa
    David
    PNW
    Could be worse, what if DCLB MT was only for Canada?
  12. May 19, 2023 at 1:26 PM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    :goingcrazy:
    BC Hunter and CygnusX191 like this.
  13. May 19, 2023 at 1:44 PM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I thought the PreRunner 2WD access cab was going to have the MT as an option as well? Maybe I am remembering/heard wrong.
  14. May 19, 2023 at 2:10 PM
    Gear Jamin Jamie
    Gear Jamin Jamie Well-Known Member
    Jamie
    Lacey, WA
    2022 Access Cab Sport MT Super White
    Gun safe, predator steps, rear bumper step
    Double cabs only? That's piracy damit! It belongs in the access cab:D Oh well.... If I got one I could bring along friends in the back seat and show off how good I can drive a manual...
  15. May 19, 2023 at 2:12 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    is that confirmed - no SR Xtra Cab 6MT?
  16. May 19, 2023 at 2:20 PM
    Gear Jamin Jamie
    Jamie
    Lacey, WA
    Hey folks I used the search but could not find anything on stainless steel pedals for our third gen Taco's. Any one have them??
  17. May 19, 2023 at 2:29 PM
    TacoMTga
    Brian
    I would import one, the exchange rate aint bad
  18. May 19, 2023 at 2:31 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
  19. May 19, 2023 at 3:39 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Great the 2024 Tacoma can have a manual transmission. It looks quite unusual seeing a manual shift lever with a touch screen.
    nevadabugle[OP] likes this.
  20. May 19, 2023 at 4:16 PM
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    That’s definitely a good score!
