Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 19, 2023 at 4:38 PM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    OP checking in. Been absent a long time but saw the news of the MT in the 4th gen and figured I better drop in and celebrate with all of you.
    What @Shellshock said with the torque numbers is music to my ears!
  2. May 19, 2023 at 6:54 PM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    My worry is that the manuals will still be unicorns and that most metropolitan dealers will tack on a premium (extra charge) above MSRP. You can't find a manual in the greater Los Angeles area without $5k+ over MSRP.
    Probably still won't find a 2WD manual either...but hoping Toyota turns a corner on this.
    CygnusX191 likes this.
  3. May 19, 2023 at 8:50 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    SR MT was last produced in 2017.
    That's..... Been a thing with Tacos since 2012.
  4. May 20, 2023 at 9:41 AM
    Shellshock
    Iowa
    That’s just what I’ve seen so far. I don’t really believe anything 100% until I see the brochure from Toyota.
  5. May 20, 2023 at 9:48 AM
    nevadabugle
    Elko, NV
    I was unclear on the release info. Can you get the manual in the Pro and Trailhwak? Or just in the TRD offroad?
  6. May 20, 2023 at 9:58 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Source is Motor Trend, so who knows....
    • Base 2.4-liter turbo (SR only), 228 hp/243 lb-ft and eight-speed auto
    • i-Force 2.4-liter turbo, 270 hp/310 lb-ft and six-speed manual
    • i-Force 2.4-liter turbo, 278 hp/317 lb-ft and eight-speed auto
    • i-Force Max 2.4-liter turbo hybrid, 326 hp/465 lb-ft and eight-speed auto
    • SR (XtraCab, Double Cab) - Base engine standard, available with the i-Force/six-speed manual combination, leaf springs, twin-tube shocks, 17-inch wheels
    • SR5 (XtraCab, Double Cab) - i-Force engine, multilink rear on Double Cab, leaf springs on XtraCab, twin-tube shocks, 17-inch wheels
    • TRD PreRunner (XtraCab) - i-Force engine, 4x2 with electronically activated rear rocking differential, leaf-springs, front lift, twin-tube shocks, 17-inch wheels
    • TRD Sport (Double Cab) - i-Force engine, (i-Force Max or iForce/manual transmission optional), red TRD sport tuned twin-tube shocks, TRD Sport 18-inch wheels
    • TRD Off-Road (Double Cab) - i-Force engine (i-Force Max or i-Force/manual transmission optional), Bilstein monotube remote reservoir shocks, multi-terrain select, electronically activated rear locking differential, optional front stabilizer bar disconnect and 33-inch tires, composite skidplates, 17- or 18-inch black TRD wheels
    • Limited (Double Cab) - i-Force engine (i-Force Max with full-time 4x4 optional), adaptive variable suspension, 18-inch chrome clad wheels, power running boards and tailgate
    • TRD Pro (Double Cab) - i-Force Max standard, 2.5-inch Fox internal-bypass manual modal Quick Switch 3 shocks, red "TRD" forged aluminum upper control arms, IsoDynamic Performance seat, electronically activated rear locking differential, front stabilizer bar disconnect, aluminum front skidplate, Rigid LED foglamps, ARB steel rear bumper with red recovery hooks, 33-inch Goodyear Territory R/T tires, 18-inch black TRD Pro wheels
    https://www.motortrend.com/news/2024-toyota-tacoma-first-look-review
  7. May 20, 2023 at 10:03 AM
    Shellshock
    Iowa
    Sport and off-road is it I think. The pro and trail hawk have the hybrid power train only.
    shakerhood and CygnusX191 like this.
  8. May 20, 2023 at 10:10 AM
    nevadabugle
    Elko, NV
    That's perfect for me. There will likely be better suspension options for far less than what the trailhawk and pro will be. It will be interesting to see the price of the offroad MT.
  9. May 20, 2023 at 10:13 AM
    nevadabugle
    Elko, NV
    And the sway bar disconnect is awesome! Did anyone hear if the offroad has the wider wheelbase? I hope not. They keep making my small trucks bigger and bigger.
  10. May 20, 2023 at 10:26 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The wider track width seems to only be trailhunter and pro.
  11. May 20, 2023 at 10:51 AM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I wonder how the long term reliability of the turbo will be. Turbos seem to be the trend. At least the displacement of 2.4L seems good, and that Toyota still offers the manual transmission with the Tacoma. Some new vehicles have very small displacement turbo engines for the vehicle size.
  12. May 20, 2023 at 1:52 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Y'all keep forgetting. The SR will also have a 6-speed manual
    It's trail hunter, not trailhawk. This isn't a Fiat.
    Toyota have been doing reliable turbos for 50 years. These will be just fine.
    Trail Hunter and possibly pro will have a 3-in wider track. Unclear if other ones will have that as an option or not.
    Canadian Caber and Firn like this.
  13. May 20, 2023 at 2:05 PM
    Shellshock
    Iowa
    I’m not worried. If you fall down the rabbit hole of toyota turbo development, the entire thing is super overbuilt
  14. May 20, 2023 at 3:36 PM
    nevadabugle
    Elko, NV
    It will be interesting to see the SR manual pricing. That may be a great platform to build from.
  15. May 20, 2023 at 5:07 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Probably as obtainable as an MT Corolla used to be.
    CygnusX191 and Shellshock like this.
  16. May 20, 2023 at 5:14 PM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    I think a turbo will be a problem with reliability and longevity. The more complex something is, generally you lose reliability and longevity.
    amyracecar likes this.
  17. May 20, 2023 at 5:36 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    What makes you think turbochargers are complex? Compared to an engine, turbochargers are stone-tool simple.
    CygnusX191 and Hardscrabble like this.
  18. May 20, 2023 at 5:44 PM
    petethemeat
    Pete
    Ontario
    2023 TRD OR AC MT
    Turbos themselves aren't complex, but they add more complexity to other systems like pcv and vacuum pumps to operate peripherals, which makes it less reliable.
    Junkhead, CygnusX191 and amyracecar like this.
  19. May 20, 2023 at 5:48 PM
    Firn
    Firn Well-Known Member
    White OR
    All those things already exist on our non-turbo engines.
    Turbos are pretty commonplace technology at this point. Nobody really bats an eye at a diesel with 300k on it anymore and those turbos work a lot more than they would in something like a taco.
    Plus, this is Toyota. It's always five years behind in features and "coolness" but makes up for it in exceptional reliability.
  20. May 20, 2023 at 5:53 PM
    petethemeat
    Pete
    Ontario
    2023 TRD OR AC MT
    This is true, Toyota will do well with a gas turbo, I've had Chevys that weren't so good, 125K and it's done.
