Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. May 23, 2023 at 2:58 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The sensors from the IMt system will allow it. The clutch master cylinder has a sensor along the length that allows the ECU know exactly where everything is concerning the clutch. 3 = magnets, 5 sensor yoke, 2 is the clutch stroke sensor.
    harlequin_forest and CygnusX191 like this.
  2. May 23, 2023 at 3:01 PM
    Shellshock
    Iowa
    Oh yeah. I forgot about iMT, that would do it. I haven’t gone down that rabbit hole yet to see how it all works.
    CygnusX191 likes this.
  3. May 23, 2023 at 3:04 PM
    Jowett
    Brian
    North Adams, MA
    Adjusting the free play on that system is going to require a visit w/ TIS. A rabbit hole for sure.
  4. May 23, 2023 at 3:55 PM
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    Since they have switched to the Honda hybrid system I suspect they will kiss the larger fuel economy gains goodby. The original Honda Insight secret was a super aerodynamics, low weight all aluminum construction, and an anemic gas engine. The problem is that gasoline engines are quite inefficient in most of their operating range. With the THS Toyota picked a peak part throttle torque point to maximize gas efficiency and them peak horsepower to give it some pep when you put your foot in it. As annoying to drive as CVT systems are you cannot really do that without them. They also uncoupled all the accessories from the engine -- even the water pump on the later versions (no fan belt).
    I don't want an inline hybrid that cannot even be an EV without turning the gas engine. I don't need all the normal car parts that can break and all the hybrid parts that can break too. On top of that WA punishes hybrids at registration time! I'll take slightly lower fuel economy in a normal drivetrain, or fully electric without any of the gas parts, thank you very much.
    MOC221_ likes this.
  5. May 23, 2023 at 4:58 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I agree - We are past the hybrid chapter in the auto story... Hybrids had their time, but no longer makes sense to carry TWO different (bit now combined?) drivetrains. The goal is towards simplicity - FEWER moving parts.
    I bet that if Toyota had not stubbornly stuck to Hybrids and tried to distract itself with Hydrogen, by now Toyota would now have a full EV Taco - and Tundra.
    I'll wait patiently for a competitively prices FULL EV 4x4...
  6. May 23, 2023 at 5:11 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    For my year, 2007 - the 5 speed manual transmission was rated as obtaining slightly better fuel economy that the 4 speed automatic for the 2.7L that year. V6 trucks though, show better economy with the 5 speed automatic than the 6 speed manual. With manual transmission vehicles I've owned, I typically exceed the EPA fuel economy ratings.
    shakerhood likes this.
  7. May 23, 2023 at 5:55 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This is not at all. How Toyota Tundra, Tacoma Sequoia and the upcoming 4Runner work whatsoever. They have real transmissions in them, not the two stage planetary/ CVT mix transmission that the Prius and Corollas use. Which by the way, is damn near indestructible.
    You just keep missing the mark here bud. Not trying to be that guy but you're wrong. This is nothing like the Honda insight or any of Honda's past hybrid attempt. In fact, if you want to talk about efficiency, the hybrid accords always got better mileage than the inside. Part of it had to do with more power in the system meaning it had to work less hard to move. The insight was a neat car but unfortunately it was following on the heels of the Prius and never did quite level up or match. As far as the Honda hybrid system, their early hybrids, the electric motors acted more like a boost to the gas system as opposed to an alternative EV drive line. This is not how Toyota's work at all.
    As far as complaining about a hybrid that can't have EV mode, I can see you haven't been in a Toyota hybrid since at least 2014. EV mode is a simple press of a button and if you have enough charge, the system will allow you to drive in EV mode. Whether you're in a Sequoia or a RAV4 or Prius.
    You're off the mark by several hundred miles here. Toyota will not go full EV. They've stated as such and they're going to stick to it. The resources just aren't available and they know that. They've secured what they need to to continue doing operations as they see fit. Their hybrid production is getting more and more efficient using less and less heavy metals every year. As far as simplicity goes, Toyota's hybrid systems use very few moving parts and have less wear and tear on even the ice components as compared to their fully ice counterparts. The hybrid is the way to go in the future, as it gives the best of both worlds while also using minimal amount of extraneous resources.
    Toyota hasn't used a 5-speed automatic and over a decade.
  8. May 23, 2023 at 6:09 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Referring to the year I have, 2007. I've always been a generation or two behind with vehicles I've owned. I feel confident owning a 16 year old Toyota.
  9. May 24, 2023 at 6:01 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Roger that. Frankly, that's where Toyota confidence comes from is the fact that their used cars last for about a century or two
    Stelcom66[QUOTED] likes this.
  10. May 24, 2023 at 8:56 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I mean it seems like they're exploring it and hit a wall with development based on the timing of this patent being filed.
    https://www.motortrend.com/news/toyota-ev-manual-transmission-sports-car-patent/
    Shellshock[QUOTED] likes this.
  11. May 24, 2023 at 11:02 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  12. May 24, 2023 at 11:38 AM
    6MTPro
    HI -> CA
    The timing is interesting especially since the 4th has probably been in the works since around the 3rd gen start.
    CygnusX191[QUOTED] likes this.
  13. May 24, 2023 at 5:57 PM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    ...Hmmm, would rather drive an automatic than a fake manual...
  14. May 24, 2023 at 6:29 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    CygnusX191 and Shellshock like this.
  15. May 24, 2023 at 7:40 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Right but the patent is only filed a year and a half ago and with the 4th gen having been a development for longer... But there's no reason to think just because they didn't implement a certain technology doesn't mean it's not going to happen
    StandardTaco likes this.
  16. May 25, 2023 at 9:24 AM
    6MTPro
    HI -> CA
    I agree I think they tried to get it to work and are still working on it (fingers crossed) and it will be part of the midcycle refresh for a manual with the hybrid.
  17. May 25, 2023 at 3:12 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Curious to see what happens with manuals once axial flux motors start gaining popularity in hybrid cars.
    They're super tiny, easy to physically package into existing transmissions, have good power density, and tach out at rotor speeds on the order of existing ICE motors.
  18. May 25, 2023 at 7:45 PM
    notrouble
    western Washington
    2004 single cab 2wd
    The original aluminum Honda Insight hybrid system was a gas engine with an electric motor bolted to it like a flywheel. Behind that was a 5-speed transaxle (it was FWD). How is that different than this Tundra type hybrid? It did cost Honda a bunch of warranty claims as the manual transmission owners would lug the hell out of the engine to force the electric part do too much of the work, cycling the small battery pack more than intended. The weak point of the Honda hybrid design -- if the electric motor was turning the gas engine was turning. How does the Tundra inline hybrid system change that?
  19. May 25, 2023 at 10:52 PM
    Sandthemall
    Sandamal
    2023 TRD OR MT
    So only manual in the SR and the TRD Sport? Now I’m really glad I’m getting my 2023 TRD OR MT. Sorta sucks not to offer the OR or Pro in a manual. With so many more Tacoma trim levels it would appear that Toyota is barely committing to manuals.
    wayupnort likes this.
  20. May 26, 2023 at 4:15 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's also in the OR :smack:
