Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 11, 2023 at 9:10 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Auto's guy's...wife pays his phone bill
    petethemeat and CygnusX191 like this.
  2. Jul 11, 2023 at 9:51 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think for 2024 you will have a switch to shut it off.
  3. Jul 11, 2023 at 9:57 PM
    shakerhood
    Southern Ohio
    How did you get a normal handbrake in-between the seats, custom install?
    CygnusX191 likes this.
  4. Jul 12, 2023 at 3:25 AM
    HPMaster
    HPMaster Active Member
    Suffolk Co., NY
    2011 2.7 5mt Access Cab
    Its not between the seats, but I can operate the parking brake with my right hand. It’s not the left foot pedal unit the V6’s have to deal with.
  5. Jul 12, 2023 at 6:42 AM
    shakerhood
    Southern Ohio
    My 1st and 2nd Gen V6's had the pull lever under the dash.
    Shellshock and CygnusX191 like this.
  6. Jul 12, 2023 at 7:21 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    If I remember correctly every Toyota truck I've owned since 1981 had the T-handle e-brake on the right side of the steering wheel under the dash. That includes both 1st and 2nd gen v6's. My 3rd gen has it on the console right beside the shifter.
    shakerhood and CygnusX191 like this.
  7. Jul 12, 2023 at 7:30 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    0/3 today. Looks like Toyota's do not have a bypass feature.
    doublethebass and 33yrsoftoys like this.
  8. Jul 12, 2023 at 7:32 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmmm. Worked on my 2021 :notsure:
  9. Jul 12, 2023 at 8:10 AM
    33yrsoftoys
    joel
    mid Michigan
    I believe you're right. The only "bypass" feature I'm aware of is the clutch start cancel on our MT's. :thumbsup:
  10. Jul 12, 2023 at 3:53 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    And it’s glorious. Love that when I want to start it up and start cooling down while I put my stuff in.
    I guess that could be easily used for a remote start too.
  11. Jul 12, 2023 at 4:44 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It can be. Just uh.... Don't leave it in gear :bananadead:
    33yrsoftoys and daveeasa like this.
  12. Jul 12, 2023 at 4:47 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Has anyone here gotten the accessorides remote start to work on their 2nd gen 6spd?
  13. Jul 12, 2023 at 4:54 PM
    33yrsoftoys
    joel
    mid Michigan
    ^^. Yep, it'll chug along like a mini diesel.:rofl::thumbsup:
    CygnusX191[QUOTED] likes this.
  14. Jul 12, 2023 at 4:58 PM
    33yrsoftoys
    joel
    mid Michigan
    Best I can remember,,, my 1981 didn't have a button. Turn the key without pushing in the clutch and she was a moving. Learned real quick to push in the clutch before turning the key!
  15. Jul 21, 2023 at 11:14 AM
    NachoTaco96
    NachoTaco96 Well-Known Member
    JK
    1996 Tacoma 2.41L & 2021 Tacoma Offroad
    Mostly 340,000 miles of wear on the '96. A sharp looking Gasshole for the '21
    Apologies if this question has been asked before - I searched and did not find a similar question: '21 Tacoma, MT, On hot days (85+, freedom units) when I change gears the clutch master cylinder area by my left foot makes a whine noise. No leaks or drips. Thoughts on what this noise is and remedies. To my old ears it sounds like a bushing or a seal. The clutch action is not spongy so it's normal, or normal as defined as no changes from the as delivered state. My wife says just turn up the music.
    thanks in advance
  16. Jul 21, 2023 at 11:17 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sport? Off-road? Pro?
  17. Jul 21, 2023 at 11:21 AM
    NachoTaco96
    JK
    Off-road
  18. Jul 21, 2023 at 11:27 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hmm. But it's not like an electronic whine?
  19. Jul 21, 2023 at 11:51 AM
    NachoTaco96
    JK
    It's like a sigh, not a motor whirl or pump sound. For comparison - When the key is off and I back the truck up a few feet just using the clutch and brake - the brake assist comes on and makes a whirl pump noise. That is a different sound than what I'm hearing.
    The whine is actually timed on foot coming up / clutch re-engaging stroke.
  20. Jul 21, 2023 at 12:11 PM
    Relyt4
    Relyt4 Well-Known Member
    Pennsylvania
    '20 TRD Off Road
    I highly enjoy driving a manual, every vehicle I've had besides my first ever was a a stick. Main reason I was drawn to the Tacoma was one of the only modern trucks with the manual trans
