Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 21, 2023 at 12:36 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It's not totally clear but it sounds like you are experiencing the clutch pedal squeak/creak issue which has been discussed many times. You can either lubricate the clutch pedal yourself, have the it replaced per the TSB, or turn up the music.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10164907-9999.pdf
    roboturner, CygnusX191 and shakerhood like this.
  2. Jul 21, 2023 at 12:56 PM
    NachoTaco96
    NachoTaco96 Well-Known Member
    JK
    1996 Tacoma 2.41L & 2021 Tacoma Offroad
    Mostly 340,000 miles of wear on the '96. A sharp looking Gasshole for the '21
    Thanks - One of my guesses was a unlubbed bushing. I'm at 32K miles so the dealer might do it under warranty... I'm not sure the clutch would cooperate whine for them. This definately matches the symptoms. As a side note - I approach clutch problems carefully - my rest in peace billion mile '96 had a slave cylinder wear out and it let the clutch out while I was at a red light. That was almost tragic.
    CygnusX191 likes this.
  3. Jul 21, 2023 at 1:13 PM
    mauctopa
    mauctopa Well-Known Member
    Not sure if you already have a build thread somewhere but can you tell me what bumper and fiberglass that is? Very nice btw!
  4. Jul 21, 2023 at 2:28 PM
    Shellshock
    Iowa
    Sounds like you need to lube up the bushing
  5. Jul 21, 2023 at 5:42 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Has anyone wired up a push button start for their manual?
  6. Jul 21, 2023 at 6:15 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Not sure why anyone would want to.
  7. Jul 21, 2023 at 6:46 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So, I figure in about 12 months we'll have a decent feel for whether or not T4R in MT is a possibility. I'm thinking maybe 10% chance it happens? It'd really mess up my math from 3 years ago where I figured buying 3rd gen MT used was the best way to get into MT before they die off. But with the 4th gen retaining MT it seems like there's really no risk of that so now it becomes a question of "what's the best MT" given I already have the s-box MT to f around with.
  8. Jul 21, 2023 at 7:04 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    We're all wondering the same thing in the shop
    daveeasa[QUOTED] likes this.
  9. Jul 22, 2023 at 12:11 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Here we go again...
    Junkhead and CygnusX191 like this.
  10. Jul 22, 2023 at 5:54 PM
    daveeasa
    David
    PNW
    If you get a chance I’d love to read your impressions of the 2024 Taco MT. It’s not a serious consideration for me but I’m definitely curious how it compares to 3rd Gen.
  11. Jul 22, 2023 at 7:47 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Will do once we finally get one in
  12. Jul 29, 2023 at 11:46 PM
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    thanx! The front bumper is custom and was built when I had the Trd pro skid on so the bottom is curved to fit that skid. Now I have the rci skid which bolts up to a lower position. And the fiberglass is fiberwerx 6” fender and bedside with milspec bedliner
  13. Jul 30, 2023 at 12:45 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I saw an article today on doityourself.com titled 'How Often Should Clutch Fluid be Changed?'
    In the section Fluid Change Intervals - 'The interval for changing clutch fluid will vary greatly between vehicles and drivers, along with environmental factors. If the system is not opened up to the atmosphere for checking purposes, it can be a long time and many miles between changes.
    EXAMPLE: The author has a 23-year-old vehicle with 244,000 + miles on it and the fluid has never been checked or changed, but the clutch still works very well. The vehicle is operated in a semi-arid environment and does not get exposed to moisture very often.
    Maybe the author has a Tacoma. I never had a manual transmission vehicle until this Tacoma with mileage more than 150k - so I've
    never considered changing the fluid. Hopefully the fluid will be good until it's time to get a new clutch, but there's no sign of that yet.
    33yrsoftoys and CygnusX191 like this.
  14. Jul 30, 2023 at 2:08 PM
    gudujarlson
    Minnesota
    I’ve never changed clutch fluid in my life, but it doesn’t sound like a bad idea if you have the time.
  15. Jul 30, 2023 at 3:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Some cars and trucks don't even have clutch fluid, but last time l changed fluid in one was during a clutch and slave cylinder replacement though.
  16. Jul 30, 2023 at 4:19 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I mean bleeding. The clutches on these trucks is super easy and it just uses DOT4 brake fluid
    shakerhood and 33yrsoftoys like this.
  17. Jul 30, 2023 at 6:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    gona need to know what wheels those are. also it looks like a supercharger fits in your budget
  18. Jul 30, 2023 at 9:56 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    Force of habit, for me. I normally flush brake fluid every couple of years, using ATE super blue and their amber DOT 4 fluids, changing the color every time, so it's easy to see when lines are running new fluid. I do the clutch at the same time. Simple peace of mind maintenance. Learned this on my BMWs, and applied it to all of my vehicles, since.
  19. Aug 5, 2023 at 8:40 AM
    Tacogeorge17
    George
    Socal
    They are kmc 445 impact forged 17x9. I’m getting it regeared then boosted
    kyle11863 and CygnusX191 like this.
  20. Aug 10, 2023 at 4:01 PM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
