Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Nov 13, 2023 at 7:08 AM
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    I think i got some domestic results by searching for 08885-81007
    Doesn’t say GL-4 on the side, but some places say it is ..?
    CygnusX191 likes this.
  2. Nov 13, 2023 at 7:12 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It's GL4 but it's not 75W90, it's 75W (LV), similar to the stock t-case fluid (LF).
    Sandthemall and CygnusX191 like this.
  3. Nov 13, 2023 at 7:17 AM
    MattiasdelTaco
    Illinois
    2023 trd sport MT
  4. Nov 13, 2023 at 7:34 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yes the pouch deal. Much cleaner and easier. First time I used one was with Amsoil.
    If I didn't work at a dealership and have access to cheap bulk fluids, I would use the Amsoil stuff exclusively. That being said.... My dealership sells Toyota fluid. But for the prices they want, you're better off buying something like Amsoil through @Pablo8 's links
    Pablo8 likes this.
  5. Dec 15, 2023 at 9:00 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I know a lot of people here don't like the accumulator and I guess it was a big enough complaint they decided to not include it in the 4th Gens. Thought that was interesting!
    (I can't find the timestamp anymore, but the chief engineer mentioned it in this video. edit: Found it - they start asking him about MT stuff just after 11min mark, and specifically he mentions the accumulator just after 14min mark)
  6. Dec 15, 2023 at 9:18 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    Maybe I should just trade for a 4th gen instead of installing the accumulator delete disk that's been sitting in my garage for a year
  7. Dec 15, 2023 at 9:38 AM
    Shellshock
    Iowa
    I can't argue with that logic
  8. Mar 19, 2024 at 4:51 AM
    Shiro213
    Shiro213 Well-Known Member
    Columbus, OH
    2019 Cement TRD Sport Manual AC
    Anyone with a 3rd Gen have a tune? I have the Peddle Commander and it helps with the lag in second gear, but wondering if it could be better with a tune. I've read about how much the tunes help the automatics with shift points, but haven't heard much from my manual transmission people.
  9. Mar 19, 2024 at 5:27 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Pedal commander is just a throttle dump.
    What I've noticed with the tune (KDMaxx 10.0 in my case)
    Greatly reduced rev hang, helps with shifting
    No Atkinson cycle in the engine, runs cleaner and a lot less valve ticking
    Throttle maps/response is much smoother and more predictable
    Slight power gains with the engine not focused on "efficiency "
    Been tuned for 70,000, mi and nearly 5 years (upgrading tunes along the way)
    I think when the tuning first got underway the manual tunes were a lot less noticeable. However, with the current iterations of the top end tunes, it's definitely worth it on the manuals. If you also haven't already done the clutch accumulator delete, highly recommend that.
  10. Mar 19, 2024 at 6:21 AM
    Shiro213
    Columbus, OH
    Very good information! Thank you. I have not done the accumulator delete, how involved is it? I am mechanically inclined, but at the same time I don't want to f@$k up my truck. I was thinking about having the dealer look at my squeaky clutch but I need to remove my Peddle Commander first.
    CygnusX191[QUOTED] likes this.
  11. Mar 19, 2024 at 7:22 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I've had my MT tune since 2019. 100% awesome.
    If you don't have a tune, get a tune. Period.
  12. Mar 19, 2024 at 8:23 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I've driven Tony's truck and while it felt like it had a bit more meat in 2nd, it wasn't night and day. The tire size difference and AC/DC plus two dudes vs me solo all possibly played some role. What I read about the tunes, always a WIP, makes me less enthusiastic to try b/c just keeping RPM's high seems to be the easiest way to reduce the sadpanda/notorque experience.
  13. Mar 19, 2024 at 8:31 AM
    BLtheP
    Plano, TX
    I've tried a bunch of tunes and haven't found any of them to help the lack of torque very much. That's not to blame the tunes...I think there is simply not much editing to the tune that can be done, and I think the computer has safeguards implemented that can't be bypassed with tunes in order to protect the motor against lugging at low rpm. I have found the tunes boost things a little bit, not a lot. However, they do adjust the throttle senstivity and response quite a bit, which definitely gives a perceived feeling of boosted torque...until you start to use the gas pedal more and don't get anything additional in return. My happy medium for tuning has been a stock tune with the redline rpm edited to 6800 instead of 6200, combined with premium fuel.
    However, being regeared affect my opinion on things as well. I enjoyed the tune when I had stock gears. The tunes did make the lower gears harder to control with the more sensitive throttle, whereas its very easy with the stock calibration so that's partly why I've gone back to stock.
  14. Mar 19, 2024 at 8:54 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Super easy. Heat shield is harder than the actual adm. Do recommend removing pedal commander, as a lot of dealer techs spend unpaid time removing 3rd party accessories to even begin diag/repair, no need to give them any ammo to be annoyed with
    :101010:
    These engines do love their high rpm lol
    Premium fuel won't help these engines (if it's ethanol free, that's a bonus however) but the tubes do have octane learning.
    Also
    Tunes can get set for certain gear sets. I've found this is paramount for the manuals. I do agree that while it's not night and day, It does help.
  15. Mar 19, 2024 at 9:01 AM
    BLtheP
    Plano, TX
    I am under the impression that the stock file has octane learning in it.
    All of my tunes have been set for the gear set as well, though I don't think that actually matters on a manual. I'm curious what made you think otherwise? I ran the stock file from the stock folder with my gears and I don't find the performance to be any different than if that is edited.
  16. Mar 19, 2024 at 9:04 AM
    WhiteBuddha
    WhiteBuddha Active Member
    23’ Pro Manual. Previous 16’ auto - not a huge fan. OTT TUNED and it really performs nice. My wife loves manuals as well. She had 06’ Barcelona Red. Should have kept it…
  17. Mar 19, 2024 at 9:15 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    For me those tunes and mods like the manifold spacer plates just aren’t worth it when I can do exactly what you said, keep the RPMs high.
    I feel like more people would enjoy the Tacoma if they just met it where it’s at instead of trying to turn the motor into something it isn’t.
    It’s a pretty common thing in this community for people to spend hours trying to convince people they can feel a 5hp difference, but that’s a imperceptible for everyone whose name isn’t something like Max Verstappen. I’d love to see a double blind study on people driving cars with or without tuned and see where the results end up.
    CDV deletes I wholeheartedly understand and get though, carry on with those.
  18. Mar 19, 2024 at 9:27 AM
    WhiteBuddha
    There is more torque no question. Hills I once had to downshift for now I don’t. That is my F1 analogy to a Tacoma.
  19. Mar 19, 2024 at 10:08 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    No idea on the new tunes, but the old OVT the torque is noticeably better. This was the MT pulling tune or whatever they called it in 2019. Not the first version. Anyone remember that? I'm almost 66, wife says I forget stuff.................sometimes!
    Shiro213 and CygnusX191 like this.
  20. Mar 19, 2024 at 10:24 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I had one of the earliest ones and it went from me hating first and second gear to actually pulling with the truck. I know some people don't notice but it's also easy to get used to how your truck drives now compared to how it was. I also had the benefit of being a Toyota Tech so driving other people's vehicles all the time and then getting back into mind... Was a nice change.
    Shellshock likes this.
