Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Oct 17, 2024 at 6:48 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    even towing. wouldn't having 5th be a slightly lower ratio be better in that case too. just above what 4th is now. in my tuned truck with no extra weight it holds 6th gear no problem even up grades on the highway. in cases of very steep hills i just go to 4th anyways as 5th is only a couple hundred rpms difference than 6th so it barely makes a difference.
    CygnusX191 likes this.
  2. Oct 17, 2024 at 7:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    When I had stock gears, I found 5th useless for towing. 4th was my towing gear, 65 @ 3200 rpm.
    now with the regear, my 5th gear is about exactly where stock 4th was, and 6th is where 5th was. I like that setup. I use 5th for towing anything currently, same 65 @ 3200. 4th provides a nice decently powerful downshift when needed.
    All this to say that I found 5th to be a mostly useless gear in stock form, although I did use it for cruising congested highways at highway speed for a bit more pickup when needed.
  3. Oct 17, 2024 at 7:15 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    5th is my stroad gear. It’s perfect for routes marked at 45mph.
    There are also tons of places in the mountains around here that 6th lugs on but 5th walks right up.
  4. Oct 17, 2024 at 7:50 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This is the goal
    BLtheP[QUOTED] likes this.
  5. Oct 18, 2024 at 4:20 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    My Tacoma is bone stock, and when not towing 6th was just too tall for some of the 50-55 mph grades where I used to live in New Hampshire; 5th was perfect. When towing a heavy load, even on level ground 6th was too tall and caused the engine to lug; 5th worked quite well, and 4th was frequently called upon when climbing mountain grades, in fact, so too was 3rd for the steepest of the grades. Like it or don't, believe it or not, those "couple hundred rpms" make a huge difference.
  6. Oct 18, 2024 at 5:05 PM
    Over600kclub
    Over600kclub New Member
    2000taco2.4manual
    670,000 miles on my manual trans.
  7. Oct 18, 2024 at 6:55 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Whoa. Excellent!
    CygnusX191 and shakerhood like this.
  8. Oct 19, 2024 at 9:25 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The Taco is an auto, my daily is a 6 speed. What I knew would happen, finally happened just now.
    I was using the truck for my weekend grocery run. I hopped in without thinking and had a brief moment of confusion when my right foot pressed the brake, while my left foot slammed into the floor pan without any resistance.
    That's something that I haven't done in years. I guess I'm a manual driver again.
    :anonymous::anonymous:
  9. Oct 19, 2024 at 10:35 AM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    There was a point when I have to drive various automatic cars for work. I did the same thing for a while, and even reached into the center console to shift until I found out it is an automatic…
  10. Oct 19, 2024 at 11:21 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I often pull up to a stop in my ‘02 Tundra and worry about stalling before I remember it’s my one AT.
  11. Oct 19, 2024 at 1:58 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Ever go to push the clutch in and hit the brake by accident?
  12. Oct 19, 2024 at 8:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I remember my Mom doing that once in a Dodge Colt when l was a kid.
    CygnusX191 and TeecoTaco like this.
  13. Oct 19, 2024 at 8:25 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    I remember your mom in a Dodge Colt for a different reason...
    ...too soon?
  14. Oct 20, 2024 at 7:17 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :rofl:
    Also, not even a Dodge. That was a rebranded Mitsubishi
    shakerhood and TeecoTaco[QUOTED] like this.
  15. Oct 20, 2024 at 9:25 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
  16. Oct 20, 2024 at 5:28 PM
    devinzz1
    devin
    2023 aclb trd or mt
    try driving an 18 speed 12-15 hours a day for weeks straight without ever using the clutch. then flying home to hop in your 6mt corolla at the airport and absolutely grinding the hell outa the gears forgetting to use the clutch while shifting.
  17. Oct 20, 2024 at 5:40 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Any vehicle can be shifted clutchless. You just don't have to be so mindful about rev matching on the big tractors.
    :cookiemonster:
    I often half-clutch it when grandma driving the car. Sometimes I miss and grind the shit out of 3rd. I hate it when that happens. It feels like I just kicked my dog.
  18. Oct 20, 2024 at 6:49 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah.... Ive had passengers question my professional credentials when I do that :anonymous:
  19. Oct 29, 2024 at 3:17 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Almost 3 full years with my Tacoma. Still LOVE driving it. Running through gears, challenging myself to smooth shifts, pushing the truck hard...so much fun to drive. Never regretted choose a manual, EVER.
    Interestingly, very few aftermarket all weather floor mat options for front mats. OEM mats are OK but would possibly like to upgrade soon.
    I did get the squeak but a application of brake grease fixed it and hasn't come back.
  20. Oct 29, 2024 at 3:32 PM
    Shellshock
    Iowa
    I had weather tech in mine and all my other vehicles.
