Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Dec 24, 2015 at 2:07 PM
    #141
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I see. In that scenario I would just clutch in, rev match to 5k and go straight to 3rd. If I properly rev match is there any negative consequences to not double clutching?
    As for heel toeing in the Tacoma that makes sense. Having an awkward pedal setup can make it very difficult. And like you said heel toeing in a 4x4 truck is more for shits and giggles than anything else.
    Here's what I'm working with right now (not a Tacoma). It works pretty well, barely even have to rotate my foot to blip the throttle.
  2. Dec 24, 2015 at 2:07 PM
    #142
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I don't know the exact weight to it but yes it does make the throws flow a bit easier
  3. Dec 24, 2015 at 2:21 PM
    #143
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    That's just it, unless you actually double clutch you aren't spinning up the transmission input (or layshaft or intermediate shaft or whatever you want to call what isn't connected to either the output or the engine when the clutch is depressed and the trans is in neutral) that started losing reves as soon as you pushed the clutch pedal down. Releasing the clutch in neutral and blipping the throttle speeds the trans input up to better match the output speed, effectively lightening the load on the syncro.
  4. Dec 24, 2015 at 2:23 PM
    #144
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Same here on my 07'
    What gear ratio do you have in that crawlbox?
  5. Dec 24, 2015 at 2:30 PM
    #145
    Doggman
    Alabama
    2017 TRD OR MT
    Hm this layshaft or intermediate shaft is where my thought process was flawed. I was under the impression that when I was clutched in the transmission was spinning at a rate directly proportional to the wheels. In which case all I needed to do was match the engine to the rev required by whichever gear I wanted to be in and re-engage.
    So when I'm clutched in the transmission is disengaged from the engine output (obviously) AND the drive wheels?
    Edit: you say trans is disconnected to the output when clutch is depressed and in neutral but what about when clutch is depressed and trans is in gear? Is trans rotating proportional to the wheels at that point?
  6. Dec 24, 2015 at 2:46 PM
    #146
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    2.28 front 4.7 rear.
  7. Dec 24, 2015 at 2:51 PM
    #147
    Doggman
    Alabama
    2017 TRD OR MT
    I think I'm coming to a realization on how synchros actually work. Correct me if I'm wrong...
    With the clutch depressed...when I move the shifter from neutral to a gear the synchro smoothly matches trans to wheels. The synchro has accomplished its task before the clutch is ever released. Clutch is released to re-engage engine to trans. Thus rev matching the engine without rev matching the trans first (accomplished by double clutching) results in increased synchro wear. Yes?
    If so, I did not fully understand synchros until just now :oops:
  8. Dec 24, 2015 at 2:51 PM
    #148
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I've found the heel and toeing tricky (depends on the boots I'm wearing) on the 3rd gen compared to Subies, VW's, etc. However, the double clutch downshift I use for dropping multiple gears works ok, so the dbw throttle isn't terrible. Just had way too much practice last night with this will travelling 90 miles on polished surfaces to pull my daughters little car out of a ditch. Lots of snow, 2 20+ car pile-ups and general mayhem of one of our two lane state highways around here. 50" of snow this week.
  9. Dec 24, 2015 at 2:55 PM
    #149
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Think about it as three different simplified components; the engine, the trans, and the driveshaft. The clutch is the connection between the engine and the trans and the shifter is the connection between the trans and the driveshaft. Syncros ease the joining of the trans and driveshaft. Too much speed differential between the two means wear on the syncros.
    Doggman[QUOTED] likes this.
  10. Dec 24, 2015 at 3:00 PM
    #150
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Mines opposite. 4.7 in the crawler & stock ratio in the FJ case.
    Same results tho. :cool:
  11. Dec 24, 2015 at 3:03 PM
    #151
    Doggman
    Alabama
    2017 TRD OR MT
    Yeah, I think I got it figured out in post 155, yes? Learn something new everyday.
  12. Dec 24, 2015 at 3:03 PM
    #152
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I usually skip gears during upshifting, rarely use 5th gear and just go from 4th to 6th.
  13. Dec 24, 2015 at 3:14 PM
    #153
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Hey thanks man. The ball feels good in the hand lol. The numbering gets dirty kinda quick but i work out if mine and i do construction...soo the dirt is always around or on me.
  14. Dec 24, 2015 at 3:17 PM
    #154
    RedBeard1
    Red
    Thick coat of automotive clear coat on knob takes care of the dirt issue.
  15. Dec 24, 2015 at 3:20 PM
    #155
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    This thread is turning into exactly what i wanted. A good place to Bull Sh!t all things manual. The above banter is perfect, three separate detailed topics all teaching all of us the ins and outs of the art of the Manual. Keep it up gents!
    themadtaco and AdventureKid like this.
  16. Dec 24, 2015 at 4:01 PM
    #156
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I like manual trans but I hate them in traffic, or plowing snow.
  17. Dec 24, 2015 at 4:02 PM
    #157
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Yup, I was still typing my reply when 155 was posted, I missed it.
  18. Dec 24, 2015 at 4:16 PM
    #158
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    is there any other than a M/T!
  19. Dec 24, 2015 at 4:42 PM
    #159
    RedBeard1
    Red
    You ever get a chance to snap some pics of the transmission case?
  20. Dec 24, 2015 at 6:44 PM
    #160
    nevadabugle
    Elko, NV
    No sir. It's a blizzard here and I do not feel like crawling under the truck. Maybe tomorrow if the storm breaks.
